Question about Maytag Appliances Over-the-Range Microwave Oven
Maytag microwave mmv4184AAQ not heating
Our microwave is not heating. Everything else seems to be functioning normally.
    Top Expert:
  • 14,553 Answers
The common reasons are a shorted diode many use, the inverter board used for control and power, and the Magnetron which does the work
Posted on Dec 07, 2012
  • 579 Answers
SOURCE: microwave won't heat.
Magnatron is suspect. Need to put a voltmeter and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Posted on Dec 31, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave won't heat food.
This would be under warranty, so Maytag should take care of it for you: http://maytag.com/support/index.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
MicrowaveSvc
  • 9047 Answers
SOURCE: My Maytag MMV4205 Microwave Oven runs but does not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 15, 2008
SOURCE: mICROWAVE WILL NOT HEAT
23 month old. MMV4205BAS MAYTAG MICROWAVE. WILL NOT HEAT AT ALL. Lights work, turn table rotates, blower works. Everything else seem to work fine. Haven't done any troubleshooting.
Don H
Posted on Sep 06, 2008
  • 36 Answers
SOURCE: Maytag MMV4184AAW Microwave not heating
If you are looking to repair this yourself (along with assoceated risks) to cut test time in half the first test point would be to check for both live and neutral feed to the high voltage transformer. If you have both live and neutral here then the control circuit is working and the fault will lie within the high voltage circuit.
Hope this helps
Posted on Jan 07, 2010
Maytag model MMV4230DS00, everything seems to work but nothing heats, no humming or noises.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 05, 2011 | Maytag MMV4203D Microwave Oven
MMV5207AAB, no heating, operation seems normal otherwise, slight roughness sound. Probably magnetron?
If the microwave works normally but no heat is being made, then the magnetron is faulty.
Jun 18, 2010 | Maytag MMV5207A Microwave Oven
My Maytag microwave stopped heating. Everything
Generally the magnetron (the part that heats the food) is the cause if everything else still works. Unfortunately replacing the magnetron is barely cheaper than buying a new microwave though you can check out repairclinic.com to decide whether you want to attempt replacing the part.
Let me know how this works out for you.
Benjamin
May 24, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
Maytag microwave oven model mmv4205bab not heating food
maytag microwave model # mmv4184aaq operates normally but will not heat food or water
Mar 07, 2010 | Maytag MMV4205 Microwave Oven
Loader than normal noise but no heat,every thing else seems to function properly
If you are hearing a loud buzzing noise then it may be the Power Diode, Magnetron, or High Voltage Capacitor. This link will tell you how to test & replace the defective part. http://www.partselect.com/repair.aspx?appliance=microwave&part=no-heat
Dec 02, 2009 | Maytag MMV4205 Microwave Oven
I have a Maytag microwave, model# MMV5165BA and it has no heat.Everything displays and vent works but no heat.Can you suggest anything before I toss it out?
If it operates as normal but items don't seem to get hot it probably is a Magnatron failure (microwave producer). More times than not the repair / replacement of a Magnatron these days is not worth the investment, especially if the microwave is 4 years old or older ! You should be able to replace your microwave with a similar featured microwave / hood for about $300 to $400. You might try a JVM1750DMWW by GE great micro/hood for about $300, includes one touch sensor cook capabilities,300 CFM vent fan,removable rack,option to turn the turntable on or off, 1000 watts of cooking power. Good luck !
Nov 28, 2009 | Maytag MMV5165 Microwave Oven
The microwave functions properly but does not heat. It made a power surge type noise and now it sounds normal but nothing heats
heatman101
erywtytw
Nov 11, 2009 | Maytag MMV4205 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Kenwood KEN GJ/SS25 microwave doesn't heat food
Q= my Microwave some time start and some time not; went push start swith it caming sound or click, click. thanks for your replying.
Nov 16, 2008 | Microwave Ovens
Appears normal
ya this is the same problem i too had...everything will seem to right but the part required for heating might be damaged internally...try changing tat...here i did the same...
Sep 19, 2008 | Frigidaire GLMV168K Microwave Oven
Maytag Appliances Over-the-Range Microwave Oven Logo
368 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
