Boot failure insert system disk, but it wont load
  • 2,878 Answers
You need to check both in BIOS by pressing F key during boot. First check to see if HD is there. If OK, then change Optical drive to first boot, save and reboot.
IF MISSING HD -
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and re-seat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Posted on Dec 07, 2012
ShaC
  • 16 Answers
SOURCE: system recovery
Non system disk When a computer boots, the bios will look for any media so that the computer can boot. The default setting is that Floppy>CD rom > Hard disk. But we can change this boot order in the bios. So, when the computer boots it will first look for system files in the floppy, if it doesnt find any system file it will show the above error message "non system disk, replace the disk and press any key". So, please check whether u have inserted any floppy in the drive. If there is no floppy it will go in search for a CD, if there is no CD it will go in search for a Hard disk. If the hard disk's first sector is damaged(bad sector) the same error will be shown Solution- Replace with a new HDD and you have to install a fresh copy of windows. If the system file has been corrputed the same error message will be shown. Solution- Reinstall windows. Solution provided by ShaC
Posted on Jul 26, 2007
  • 82 Answers
SOURCE: Disk Boot Failure
Any system can be recovered, although it depends on what is wrong.. this error can mean no info on the hard disk, or damaged hd...more than likely whoever had the computer erased it for data's sake...I would've...get an os and load it.
Posted on Aug 08, 2009
alxz
  • 89 Answers
SOURCE: disk boot failure
sounds like a hard disk drive problem. If you are comfortable with working inside your computer, you can open the case and remove the cables to the hard disk, and re-connect them again firmly.
Posted on Jul 07, 2008
  • 57 Answers
SOURCE: acer aspire x3200 error reading
Check to make sure you don't have anything in your floppy drive. (3.5 drive or 5.25 if really old system).
If you can boot from bootable CD then probably your Hard Drive is not working and all other periferals are OK. If it is making clicking noises then the drive arm or the head is most likely shot and you need a new hard drive.
The one chance you do have is if your Hard Drive just needs to be made bootable again. Load up the XP cd as if you where to reinstall XP but instead goto the recovery console, type "fixmbr" at the command prompt once you have entered the XP logon, its very simple once you get there very well laid out.
Hope this helps. Best Regards,
Posted on Nov 09, 2009
  • 942 Answers
SOURCE: disk boot failure insert system disk and press
When you encountered this kind of failure this is a HDD error, so check the HDD if it is properly connected. Use another IDE or SATA cable, use also the another SATA or IDE slot of your motherboard. No another way to fix it that is only the hard disk you need to check. Maybe the IDE or SATA cable is bad or the HDD itself. Good luck!
Posted on Jan 24, 2010
Boot disk failure. Insert system disk and hit enter
Remove the CD player, open it and try cleaning the lens then put it back and try again if it doesn't ,convert the cd image to Flash disk using Rufus a free tool from the internet, then install your o.s using Flash disk.
Jul 17, 2016 | Microsoft Windows 2000 for PC
Getting message "Disk Boot Failure Insert system disk and press enter" using window xp platform and have MCA fee antivirus software
this happens either the boot sequence have changed or your hard drive is not recognised by the BIOS
Jan 26, 2013 | Computers & Internet
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
Disk Boot Failure
Aug 08, 2009 | Computers & Internet
Still wont boot
Disk boot failure is usually a sign that your operating system has become corrupt in some way.
If you've got your Windows disc, put that in the CD rom, then boot the computer.
There's a "repair" option that you can select, instead of re-installed Windows.
That *should* fix the problem.
It's also (thought unlikely) possible that your hard drive has died completely.
Mar 19, 2009 | HP Compaq Presario SR1303wm PC Desktop
Hi i am tryning to load an operating system onto my brand new hard drive. It keeps coming up with disk boot failure, insert system disk and press enter.. what do ido
Hi, By brand new harddrive, I assume that its fresh and empty.
You need to install the Operating System (OS) in that harddrive.
You can do that my inserting the OS installation CD/ DVD into the drive before you bootup.
If you still get the error, get into the setup mode and change the boot sequence to boot from CD-ROM first.
Hope it helps :)
Sep 21, 2008 | Computers & Internet
System is no boot neither with cd-rom nor hard disk
Hi, Based of your post/description and assuming not hardware problem, you may have to set up the priority boot device in the BIOS to CD. This will tell your mb to look for a boot medium from the cd first. This is normally in the Advance Setup/1st Boot Device. Of course soon as installed, you have to boot from the HD next time. Good luck and kind regards.
Aug 14, 2007 | Intel Motherboard
Disk boot failure
After making 100% sure you have no diskette or CD in any drives the conclusion may well be that the disk is ruined. You ay try to boot from a diskette or CD and see if you can access the disk then. (see www.ultimatebootcd.com for instructions to make a boot CD) "The ultimate boot CD" has a few tools that might help you out. Since you can't boot you must make it on a different computer, though. You may also try to insert the disk in a diffe rent computer to see if it can be booted there. Also make sure all cables are properly connected.
Apr 03, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
