Question about Philips CDR775 2-Disc CD Recorder
The righthand (player) side of my Phiips CDR775 will play cds that I have recorded but will no longer play originals. I have used a cd lens cleaner but problem remains.
  • Barrie Murphy Dec 18, 2012
    Thanks. Obviously, when I buy a pre-recorded cd I can't select the brand of audio disc.
    Laser is being replaced. Hope this will solve it!
  • 1,258 Answers
It may need a better cleaning by a professional as well as some lubrication at points in the unit. This is a job for a Technician.
Posted on Dec 11, 2012
  • 112 Answers
SOURCE: Phillip CDR778
You can try other brands of audio cdr but it sounds like your laser is on it's way out. Some find cdrw's still work after cdr's have stopped being recognised.
Posted on Jan 22, 2008
  • 112 Answers
SOURCE: Philips display went out when power outage occurred
I can supply a replacement display from a scrapped unit, I'm in the UK, search on ebay for seller fluffcat1 and contact me.
Posted on Dec 07, 2007
  • 112 Answers
SOURCE: Recorded finalized CD's will not play on standard CD player
Are you using the same brand of discs you used to? Do they palyback on the machine in both the record and the playback deck? Do your old cdr's you recorded still play in the standard cd player? You can try the diagnostics - hold down the 'play' and 'fwd' keys on the record side as you power it on.
Posted on Dec 09, 2007
  • 567 Answers
SOURCE: Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Posted on May 07, 2010
SOURCE: When I insert a CD-R
The message NO DISC may appear for several reasons:
1.No disc is loaded->Load a disc into the player, close the door and press PLAY
2.The disc may be defective->Try a different disc
3.The disc is placed improperly in the tray->Make sure the disc is properly placed and centered in the tray and if the disc has a label on one side, make sure the label is facing up
4.The disc is dirty->Use a soft cloth to clean the disc by wiping in a straight line from the center of the disc to the outside edge
5.If the player cannot read CDs/DVDs correctly, try using a commonly available cleaning CD/DVD to clean the lens before taking the device to service. Other cleaning methods may destroy the lens.
6.Using non supported discs may lead to playback problems or jamming in the slot loader or drive.
Philips CDR775 service manual download here
Posted on Apr 13, 2011
Thanks everyone. I should clarify that the cds that will not play in the right hand tray (originals) are as pre-recorded by a record company; for example, an ABBA cd which I used to be able to play, I...
What does the lower surface look like? Does it have a lot of scratches or is it perfect? Many times the condition of the optical surface of the disc can affect the results you have. The disc is scratched can be polished. Burned disc only have about 70% of the output that a pressed disc has so sometimes you need to burn a new one.
Dec 09, 2012 | Philips CDR775 2-Disc CD Recorder
Samsung DVD-R130 will not load dvds, but will play CDs
Hey,
have you tried a lens cleaner? the lens may have gone bad and would need to be replaced. Do you have warranty on the player?
Sep 02, 2008 | Samsung DVD-R130 DVD Recorder
Does not read Cds or DVDs
most sony CD and DVD players have a digital signature design to play CDs and DVDs that are original and licensed. some CDs or DVDs dont work since the player does not recognize or scan any digital signature embedded in the CD or a DVD. 2nd, lens problem causes most players not to read CDs nor DVDs. you can try to buy CD or DVD lens cleaners to have your lens cleaned.
Nov 01, 2010 | Sony Computers & Internet
When i try to record a cd it keeps comin up no disc, not in the recordable side the right hand side,
make sure you are useing the philips brand audio cds thats the ones the machine needs had the same trouble hope this helps if not go to philips internet site then click on support
Apr 30, 2010 | Philips CDR775 2-Disc CD Recorder
My dvd player plays cds but wont play dvds says disc error or unknown disc
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all DVD's with no problem at all.
Good luck.
Apr 22, 2010 | LG RC897T DVD Recorder/VCR Combo
My cd player in my 07 pontiac g6 wont play my cds it keeps saying check disc
If this is a consistent symptom that occurs with all your cds....I would have to say the laser in the cd player is no longer working. You may try cleaning it, there are cd cleaners that are 15$ that u can try.but i think you'll find its out . sorry
Apr 13, 2010 | 2007 Pontiac G6 GT Convertible
When i play cd's the player frezzes
Hi, the tracking motor on the lens Assembly is faulty, you will need to either replace the tracking motor or the entire optical lens assembly.
May 25, 2009 | Philips CDR775 2-Disc CD Recorder
Denon DCM 390 not longer reads discs--HELP!
Hi there, this lens may be dirty or it may have a thin layer of heat film that is causing it to not read in a consistent manner. i would try to clean the lens with a good CD lens cleaner. if the cleansing doesn't restore the lens to its original reading state, this will confirm lens assembly failure and you will need to replace this assembly.
May 17, 2009 | Denon DCM-390 5-Disc CD Player
Oct 04, 2007 | Philips CDR775 2-Disc CD Recorder
How do i record an make my own cds? i put a brand new cd in an it says wrong disc what do i do?
DOES YOUR MANUAL SPECIFY WHAT TYPE OF CD TO USE OR NOT, FROM THE TYPE OF CD NOT RECORDING IF YOU RECORD THEM ON A PC WILL THEY PLAY ON YOUR RECODER
May 15, 2007 | Philips CDR775 2-Disc CD Recorder
Philips CDR775 2-Disc CD Recorder Logo
135 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
