Help me, dish network hd monitor,model 34-310. made in 2004. wont turn on,on button blinks and attempts to,turn on but screen remains blank. tries three times and blinks a green light. no picture,no sound. won't turn on. plz help
    Top Expert:
  • 14,553 Answers
It is the right age for failure---IF you are able look inside at the power supply for bad caps---I will attach photos of what to look for.
The three tries is what is called a three strikes and you are out (no joke)----the unit has built into it (many do) a feature where it will try 3 times to make it up and on and if fails shuts down or stops trying.
help me, dish network hd monitor,model 34-310. - 12_7_2012_3_05_35_pm.jpg12_7_2012_3_05_53_pm.jpg
Posted on Dec 07, 2012
PaulRepair
  • 66 Answers
SOURCE: NEC MultiSync lcd 2010 monitor blank screen
This is the common bad capacitor problem. The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 02, 2009
benwabnick
  • 2404 Answers
SOURCE: Light on power on switch keeps blinking, screen blank.
Definitely a problem with the monitor. If you can get the back open then look at the main board and the power board. You will want to look for puffy capacitors. Instead of a flat top it will look puffy like its pregnant.
If you find any like that then you need to replace them with new capacitors that have the same Uf rating and at least the same voltage or higher.
This will take some unsoldering and soldering skills. Make sure the stiped edge gets aligned with the striped edge on the board.
If you replaced them then the monitor should turn back on. If it doesn't then its a screen problem and you'll need to get a new monitor.
Posted on May 01, 2010
SOURCE: Mag innovision LT716s monitor model 700p blank screen
Have you installed the drivers for it? I had the same problem and when I installed the driver, problem solved.
Posted on Mar 02, 2008
tantong
  • 138 Answers
SOURCE: Monitor wont turn on, green power light on
Hi you can inspect that what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 09, 2008
  • 4 Answers
SOURCE: blinking monitor power button and flashing image
I buy and sell these monitors (Dell E17FP) the problem is with the transisters (Q739, Q740, Q759, Q760) they short out and the monitor will just blink on and off. You have to desolder them and test them with a simple battery and light circuit. The reason they blow is because of the dirty solder joints by the transformers. If only on pair of backlights work the problem maybe transisters Q751, Q743. I home this answers your questions.
Posted on Sep 12, 2008
Samsung 906vw blank screen
if the power light indicator is just blinking with no display, you must checked the power supply the common cause bulging electrolytic capacitor. just replace with the same value and rating then the problem solved.
Jul 22, 2012 | Samsung Computers & Internet
I have a AVEX URC-R6 Remote controller that was working fine for almost 3 years with a DISH 722 Reciever/DVR. One morning the receiver IR would receive no signals from either the AVEX remote, or the...
trwck
I have provided instructions on how to save setting on the receiver and remote plus instructions for learning mode. I hope this helps.
Ray Calo
DISH Network
Back Up Remote/Receiver Data
  • Receiver: 222k and 722k
    1. Verify that the customer has an unobstructed LOS and is within 10 feet of the receiver. The customer will need to direct the remote toward the receiver for the duration of the System Wizard setup.
    2. Press and hold the number 0 until the pop-up 380 appears on the screen.
    3. Verify that the System Wizard says the remote is configured correctly.
    4. Select Advanced on the screen.
    5. Select "Backup My Settings Now".
    6. Verify that the purple gem is displayed beside the correct selection.
    7. Select Next.
    8. Select the type of backup to be performed:
      • Full system backup
      • Back up receiver settings
      • Back up remote settings
    9. Verify that the purple gem is displayed beside the correct selection.
    10. Select Continue twice to initiate data transfer. Maintain unobstructed LOS while the green progress bar fills.
    11. Select Continue to resume programming.
  • Restore Receiver Data
    4. Select Restore on the screen.
    5. Maintain unobstructed LOS while the green progress bar fills.
    6. Select Continue to resume programming.
  • Teach Learning Commands
  • Receivers: 222k and 722k
    1. Ensure the DISH Network remote control is programmed to the desired remote address to operate the DISH Receiver.
    2. Place both the DISH Network remote and the original equipment's remote control on a flat, stable surface.
    3. On the DISH Network remote, press and hold the mode button for your equipment for about three seconds until all of the mode buttons light up, and then release it. Your selected mode button will blink.
    4. Select the type of learning you wish to perform:
      • Hybrid Mode
        1. Press and release RECALL, then hold the RECORD button for about three seconds until the mode button is lit again. The button remains lit while learning.
        2. Point the front of the original equipment's remote to face the small square (IR window) on the front left-hand side of DISH's remote. Remotes must be within 4 inches of each other.
        3. On the DISH Network remote, press the button you want to teach.
        4. On the original equipment's remote control, press and hold the button you want learned. If the DISH Network remote learns the command, the mode light blinks off and then back on. If the mode light blinks three times or remains lit, the DISH Network remote did not learn the command. You may need to press the button on the original remote several times for the DISH Network remote to learn the command.
        5. After a button has learned a command successfully, repeat steps 3 and 4 until all commands you want have been learned.
        6. To end the learning sequence:
          • Press one of the mode buttons on the DISH Network remote. This saves all of the commands for that mode and exits learning to return to normal remote control operation.
      • Normal Mode
        1. Press and hold the RECORD button for about three seconds until the mode button is lit. The button remains lit while learning.
  • Mar 25, 2011 | DISH Network ViP722 DTV Receiver /...
    Programme remote to work with sony tv
    To program your DISH Network remote to your Sony TV you will simply- press and hold the TV Mode button until all the other mode button back lights illuminate, then release.
    -Now while the TV mode button is blinking please enter in the remote code 500 which is the remote code for your Sony TV after entering 500 then press the pound (#) key.
    -After pressing the # key on the DISH Network remote, the TV mode button should blink 3 times and then turn off completely. This will mean the programming of the DISH remote to your TV has been completed successfully. While still in TV mode try any of the functions on the remote, such as turning the volume up or down on your TV or attempting to press the power button.
    -The DISH Network remote should now be programmed to control your TV.
    -If the remote code 500 doesn't program the DISH Network remote successfully you can also try each of the following using the same procedures, 000, 590, 640, 502, 002, or 567.
    I hope this resolved the issue for you! Please feel free to contact us if you need any additional assistance.
    -Kirstie DISH Network
    Sep 16, 2010 | DISH Network IR Remote Control
    Blank LCD laptop does turn on
    I beleave you may need to press the function key as well as the F-4 key to bring up an external monitor.
    Try holding down the Function key and tapping the F-4 key while watching the screen on the external monitor.
    Is your unit within warranty, HP offer an extended 1 year on top of your normal 1 year warranty for video and motherboard issues.
    Hope this has helped.
    Sep 27, 2009 | HP Compaq Presario CQ50-210US Notebook
    Blank screen upon startup
    Try taking out the hard disk, plug in power and see if you have a display on your screen or external monitor. if same thing happen, try taking out the memory card. If you hear a beep sound it's a faulty mem. card, if no beep sound appears I suspected it's a motherboard faulty.
    May 31, 2009 | Lenovo ThinkPad T61 Notebook
    When monitor power button is pressed, a small white image appears and alternates briefly between an alalog and digital icon in black then the screen goes blank, no color.
    My issue is similar.. however after trying a couple of times it will work. (yes everything is plugged in) It will function for a good 10 minutes before just powering off (blackout) screen.
    If you attempt to turn it on after it blacking out, the blue led for the power button will blink a couple of times and it will remain off.
    However if you wait 5-10 minutes and turn it back on, it will repeat itself...
    I have it hooked up to a radeon X1650 graphics controller as a secondary digital controller, and its hooked up by VGA cable.
    I also have two other displays besides this one (one primary and extended that dont have any issues whatsoever.. they continue to function while the syncmaster 193p takes its time snoozing.... please help.
    Mar 17, 2009 | Samsung SyncMaster 193P 19" LCD Monitor
    HP L1706- screen is blank when I switch on
    First if you have a extra monitor try to plug it in and see if it works. If not then check your video card. or get into the computer and try and remove and reseat the memory. Sometimes by just doing that can solve the problems
    Feb 06, 2009 | HP L1706 17" LCD Monitor
    Monitor blinks and then remains blank after computer turns on
    THERE OR AN DEVICE THAT IS CALLED A CHOCK AND IT IS A MAGNET IN A SQAURE HOUSING THE A CORD FITS OVER YOU CAN PICK THEM AT ANY ELECTRONIC STORE THIS MAY HELP WITH AN INPEDANCE PROBLEMS SOME TIMES
    CANDYMANGANDY
    Dec 13, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
    Dell172fpb 17" monitor
    Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
    1. Turn off both your computer and the monitor.
    2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
    3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
    4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
    Thanks
    proton
    Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
    Computers & Internet Logo
    61 people viewed this question
    David Payne
    David Payne
