Question about Frigidaire GLTF2940ES Front Load Washer
IWasher starts but woudn t drain and stops working.did press start and pause Cancel buttons simultaneously and it shows me E23 which means that the drainpumprelay On controle boardfailed
Do I have to change thebwhole board or is there an easier and cheaper way to fix the problem
  • Ivan Kelly
    Ivan Kelly Dec 07, 2012
    Mr PJ Fixit,I did what you suggested me to do.It didn t fix ,but at least I hear a sound from the pump.Do you have any other fixes?
  • Ivan Kelly
    Are there more solutions for my problem?
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Drain pump relay on control board failed. You will need to replace the control board. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Dec 07, 2012
  • 3 more comments
  • Ivan Kelly
    Ivan Kelly Dec 09, 2012
    I changed the board ,but now when I press to start the machine the startlight keeps blinking.I cheched the problem by pressing both start and pause cancel ,and it shows me the error E5E,which means that there is a communication problem between the controle board and the speed controle board which I don t know where to find it. Can you help me with this problem?
  • Richard Roth
    Richard Roth Dec 09, 2012
    E5E Communication problem. Check the connections.
  • Richard Roth
    Look for a worn or shorted wire.
  • Ivan Kelly
    Ivan Kelly Dec 10, 2012
    I have checked all the wires ,oke. I changed the board.checked the pump and found it pluged,clearedi it tried to start the washer and now I get errorcode E31,which means that I have to replace thepressure sensor or replace the board again.I don t understand it anymore .Can you help me?
  • Richard Roth
    Richard Roth Dec 10, 2012
    OK, replace the pressure sensor. Here is that part to order.http://bit.ly/VyV4wq You did say the control board is new correct?
3 Suggested Answers
  • 1294 Answers
SOURCE: blinking lights and failure to start
Suggestion: 1 Press and hold down 'spin' & 'dry' buttons to unlock controls. 2 Have u overloaded the machine with clothes? Reduce load. 3 Try 'spin' only after putting the clothes. Then put off machine & continue with main cycle. Three suggestions here........ What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Posted on Apr 16, 2007
SOURCE: Error / Pause Affinity ATF7000
I had the issue with my Affinity ATF7000 washer displaying err pause err pause .... clicking any button would give me 3 beeps and lights would flash but would get no real error message. Repair man wanted to replace entire computer for $250 plus service call rate. So by dumb luck I did this and got it working.
1. Unplug washer
2. Take off top (screws on back)
3. Unplug connector to the pressure sensor (carefully). Looking at the washer it is mounted to the right side near the front and looks round when looking at it from the top.
4. Plug in the washer and it should display E31. E31 is just saying it cannot communicate with the pressure sensor (which makes sense because you unplugged it).
5. Unplug washer and reconnect pressure sensor.
6. Put top back on and plug in washer.
7. Washer should work but E31 error will remain in memory so if you do call a repair man he may think the pressure sensor needs to be replaced. There is a way to clear error codes but I could not get it to work.
This is my theory on why it worked. The computer program on the washer is stuck in a loop that will not allow the washer to function. When we unplug the pressure sensor we give it a real error and it exits the loop it is stuck in. I am a programmer by day so this may not make sense to some.
Posted on Feb 23, 2012
It pauses with error code E20 and doesn't seem to drain or spin, could it be the filter is cloged?
The E20 error code is a class code that indicates a drain problem in the washer. This is consistent with the drain and spin problem that you are observing. To determine the exact error code, follow these steps:
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the START and PAUSE/CANCEL buttons simultaneously
The exact error code (E21, E23 or E24) will be displayed.
If E23 or E24 are displayed, you will normally need to replace the control board due to a failed drain pump relay.
If the E21 code is displayed, I recommend that you follow these troubleshooting tips:
Check the washer drain to see if it is clogged.
Check the washer drain hose for a clog or restriction.
Make sure that the washer drain system complies with the installation instructions for the washer.
Try to gravity drain the washer by placing the drain hose in a bucket on the floor. If the washer will gravity drain, you may be able to
unplug the washer
and remove the bottom front service panel using the procedure in the image below. Arrange towels to catch residual water that may be in the washer and check the pump filter and drain trap for a clog or debris. If you find no clog or debris, then you may need to replace the drain pump. NOTE: You should not attempt this procedure unless you are completely confident in your technical ability to safely access and check the pump. Do not disassemble the drain pump hose if the washer is full of water.
May 15, 2015 | Washing Machines
My maschin stops in the midel of a program and E20 comes on the screen. What is wrong?
Sandra: According to ShopYourWay.com: "The E20 error code is a class code that indicates a drain problem in the washer. This is consistent with the drain and spin problem that you are observing. To determine the exact error code, follow these steps:
Wait 5 seconds
unplug the washer
and remove the bottom front service panel using the procedure in the image below. Arrange towels to catch residual water that may be in the washer and check the pump filter and drain trap for a clog or debris. If you find no clog or debris, then you may need to replace the drain pump. NOTE: You should not attempt this procedure unless you are completely confident in your technical ability to safely access and check the pump. Do not disassemble the drain pump hose if the washer is full of water. " There is also a video that may help you, Sandra: https://www.youtube.com/watch?v=s0Wrc2LiCK8
May 10, 2015 | Washing Machines
PT reads on display and it will not drain
Frigidaire does not have a "PT" technical error for any of their units. Please try to recall the error exactly by doing the following:
* Wake the washer by pressingany button.* Wait 5 seconds.* Press and hold the Start andPause/Cancel buttons simultaneously.* All LED's will go blank and after a few seconds the controlwill signal the stored code using audible beeps and blinking LED's. The controlwill repeatedly signal the code, as long as the Start and Pause/Cancel buttons are pressed. A two second pausebetween repeats affords you the ability to make accurate counts to identify thecorrect error codes.
Aug 01, 2012 | Frigidaire Affinity ATF7000E Front Load...
The dryer just stopped and now wont turn on
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER THAN NINE: A=10 B=11 C=12 D=13 E=14 F=15 "
"EXAMPLE CODE F1: THE FIRST DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN TIMES AND THE START INDICATOR LIGHT WOULD
Jul 28, 2012 | Frigidaire GLET1031FS Top Load Stacked...
What wrong when washer machince stop in the middle of cycle and leaving water inside make humming noise read err
To recall an error code,
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons simultaneously
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
you may also have a code such as E47 or E24 etc..
Comme back with the code and I will explain what is the meaning of the code
Nov 28, 2011 | Frigidaire Washing Machines
Machince stop in middle of cycle leaving water inside make humming noise
Wait 5 seconds
Nov 28, 2011 | Frigidaire GLTF2940ES Front Load Washer
The washer stops half way through all cycles and displays "oL" .
Error oL means overload.
If the "oL" error code appears, the washer has been filled with a load that is too large for its capacity, causing it to drain.
*Remove some items from the washer and add more detergent since the previous amount will have drained with the water.
*Close the washer and press the START/PAUSE/Cancel button to remove error displayed and restart the cycle.
If Pause/Cancel does not work:
*Unplug washer or disconnect power for one minute.
*Plug in washer or reconnect power.
*Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Hope this helps.. :)
Jun 08, 2011 | Washing Machines
My kenmore 417 94082500 dryer keeps pausing and shutting off with no errors between 5 and 10 min from starting.
Rotate the cycle selector knob three clicks clockwise (3 o'clock position) from the Normal cycle option then press and hold the Select and Pause Cancel buttons simultaneously for six seconds.Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds. Rotate the cycle selector knob one click counterclockwise (2 o'clock position) and the error code will appear in the digital display as an "E" followed by two numbers, a number and a letter or two letters. Post back the error code for further advice.
Feb 23, 2011 | Dryers
Error code e10
Communication failure =E10
1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
position.
2. Press and hold the Select and Pause Cancel
buttons simultaneously for (6) seconds.
3. Immediately after, press and hold the START and
Pause Cancel
buttons simultaneously for (4)
seconds.
4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
position.
The STATUS indicator lights will flash the number of
times for the first digit of the code and the START indicator
light will flash the number of times for the second digit.
The code is obtained by counting the number of times
the lights flash. Example E24: the STATUS indicator
lights would flash twice indicating the 2 and the START
indicator light will flash four times indicating the 4. The
STATUS indicator lights and the START indicator light
will start flashing at the same time. The control will then
pause for 2 seconds, then repeat the code.
Troubleshoot the problem by using the chart on next
page.
To move to the next code, press the OPTIONS button.
To clear code, press the Select botton.
To exit this mode, simultaneously press and hold the
Select and Pause Cancel buttons for (6) seconds to
reset.
if this does not work need to replace control
Sep 07, 2008 | Frigidaire Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
65 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
