Question about Toro Garden
Out of transmission fluid in my toro workman 4200 4wd
What kind of gear oil to put in
    New Friend:
  • 3 Answers
According to the service manual, the transaxle uses 8 quarts of DEXTRON III transmission fluid. It also is the source for fluid for the hydraulics.
Posted on Dec 30, 2012
2 Suggested Answers
  • 173 Answers
SOURCE: what kind of oil do you put in a toro mower 3.75HP
Put SAE 30W oil in it and do not mix with gas.
Posted on Dec 29, 2010
My 2003 cadillac cts automatic transmission will not change gears pulls off slowly but will reach high speed
please do not have your transmission flushed , have someone take the oil pan off and replace the filter as well and what ever trans oil you take out replace it as well . no automotive repair shop will warrenty your trans if it should suddenly stop working , but just for your satisfaction ask the transmission repair shop who flushs trans if they guarantee it and have them put it in writing . ive never understood why flush dirty oil and leave the dirty filter in the trans , it collected all dirt and metal wear which is what is causing it to plug up causing it to restrict the oil flow
Mar 21, 2014 | 2003 Cadillac CTS
Toro workman 3200 wont crank
Try a little starting fluid directly into the carb. If that works, then you have narrowed it down to a fuel flow problem. On mine, the fuel pickup hose cracked where it came through the gas tank. I replaced it and it fired up on the third pull.
Mar 08, 2014 | Toro Garden
Where can I buy Toro Workman 3200 carburetor?
go to Toro commercial service center. They are expencsive. I have the same set up as your workman for fertilizing and spraying. Where are you located? I am in Holland,, Michigan
Dec 12, 2013 | Toro Workman 3200
Golf sdi 99 gear manual oil
Since you say gear oil I assume that it is a manual transmission. Here are codes and fluid type/capacity
Transmission fluid Capacity 2.0 liters
Transmission code: DYP, ECW, EFG, ERS, FBV, FBX, FBY, EGY, EVR, EZK, FCF Type G51 SAE 75w-90 (synthetic oil)
Transmission codes: DQY, DBZ, DZQ, DZC, EGC, EGF, EKG, EMR, EMS, ENH, ENJ, EBJ, EBP, EBQ, EZH, EWW, FBW, EGR, EBN, EGT, EGX, EGU, EHC, FDS, EHA Type G50 SAE 75w-90 (synthetic oil)
Dec 04, 2013 | Cars & Trucks
Change transmission fluid buick rendezvous
just jack the car up go get 5 quarts of good quality transmission fluid ,,change the filter put in new fluid easy to do with the filters that are like the oil filters
Oct 26, 2013 | Cars & Trucks
What kind of transmission fluid do you put in a manual 1996 saturn sl model?
You put gear oil in a manual transmission, not automatic transmission fluid. Look in your owners manual for the proper weight, or ask the guys behind the counter at a parts store.
Jul 12, 2011 | 1996 Saturn SL
I need to know what kind of tranny fluid goes in a manual transmission on a 1989 gmc seirra with 305 its a stepside to. i put amsoil synthetic manual synchromesh transmission fluid in it but im worried...
Muncie 4 (117MM) speed---Lubricant Type---------80W-90 Gear Oil
Muncie 5LM60 (HM-290) 4 & 5 Speed ---------Lubricant Type------Syncromesh Trans Fluid T2850
Oil Capacity= 5 Speed (85mm & 109mm)--3.6 pt (US)
(New Venture Gear 4500)--8pt (US)
4 Speed= (85mm)--3.6pt (US)
(117mm)--8.4pt (US)
Hope this helped you ??
Jun 14, 2011 | 1989 GMC Sierra
What kind of transmission fluid for 2003 ford ranger manual 5 speed
DONT USE GEAR OIL IN A MANUAL TRANSMISSION. it will blow your seals out. the gear oil is too heavy and will block passages in the tranny
Nov 30, 2009 | 2001 Ford Ranger Regular Cab
What kind of oil do I put into the transfer case? Is that why the computer keeps saying check 4 wheel drive?
no, DO NOT use gear oil. The transfer case uses the same type of automatic transmission fluid that the transmission uses. Is the display saying "service 4x4 switch"? If so it is common and the 4WD indicator light switch is bad and needs replaced. It's only purpose is to tell the driver info center what 4 wheel drive mode the transfer case is in. This switch will not affect the function of the 4 wheel drive. The correct fluid for the transfer case is +4 automatic transmission fluid.
Jul 18, 2009 | 1993 Jeep Grand Cherokee
Epic 2005 auto gear car which oil to be use for GEAR
Automatic Transaxle Fluid (GM part no. 89021903)
Jun 14, 2009 | Chevrolet Chevy Cars & Trucks
Garden Logo
142 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
