Question about Radio Shack Pro-2018 Scanner
No recieving Hello When i leave my pro 2018 off for overnight and turn it on it will recieve the signals for about 10 minutes and then it will not recieve anything. I have to turn it off and leave it for a few hours before it will recieve again but it only recieves for a few minutes. My antenna is not the problem and all the intrenal connections seem to be ok. Please Help! Chaz
    Scholar:
  • 66 Answers
I had the same problem and no it is not because of heat. In most cases when you turn a scanner off it has data stored in its RAM and ROM memory banks, this data is cleared out of the scanner if you do not have a memory backup battery. The problem with your scanner is the RAM data might be corrupted, reprogram your radio using only the priority banks and never turn your scanner off unless you have a backup battery, if you do, you'll have to keep reprogramming it. Instead of turning it off, just turn it down.
Posted on Jul 01, 2008
    Problem Solver:
  • 13 Answers
Sounds like the reciever is getting hot? try bringing it to a local radio shack dealer and see if they will have there techs. look at it.
Posted on Jul 08, 2007
SOURCE:
Hi I have a Aldi bauhn LCD tv and its not recieving the remote signal. I have checked through a camera for the remote control light signal and it works with every button. So that leaves the reciever
Will cost more to fix then a new unit , replace it and try to buy a extended warranty with the new one, most times you can get 3 years after the original warranty runs out.
Apr 04, 2017 | Televison & Video
Power and record buttons are flashing on reciever and tv is not recieving a signal from reciever
Hello, my name is Nick Franta from DISH Network Customer Support.
Just wanting to make sure this issue has been resolved. If you need assistance let us know!
Dec 03, 2010 | DISH Network ViP 211 DTV Receiver
What would cause reciever 2 to have a much lower singal than reciever 1 on a 625 reciever foe dishnetwork
Hello there! Becki Barned with Dish Network customer service here! There are a few reasons for this. There could be a problem with the receiver itself, cabling, or a component on the dish itself. Normally, it is due to a corrupted cable, or the receiver not being able to pull in signal. Unplugging the receiver for 10 seconds in most cases, will help. Blog back if any other troubles!
Sep 26, 2010 | DISH Network DVR-625 DTV Receiver /...
Hello, This Sony KDL 40S4100 is only recieve NTSC signal, is there is any firmware or anyway that I can make it recieve PAL signal??? Thanks for your help.
This is another Sony KDL 40S4100
Anybody out there?
Sep 07, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
Receiver taking a long time to transmit reciever
I assume that the HDMI works fine if you go directly from the dish receiver to the TV with either HDMI cable. And try it with a different source (DVD or x-box) in the same input port.
Take it to a Radio Shack there service centers can repair Onkyo in warranty. Most Onkyo receivers carry a two year warranty.
Nov 18, 2009 | Audio Players & Recorders
Central locking stopped working on my corolla verso '06. any idea why?batteries are fine in key and reciever isn't covered by anything!please help!
TWO THINGS TO TRY... FIRST DISCONNECT BATTERY. LEAVE DISCONNECTED FOR TWENTY MINUTES, WHILE DISCONNECTED TURN THE IGNITION KEY TO THE RUN POSITION AND LET SIT...AFTER 20 MINUTES TURN KEY OFF RECONNECT BATTERY.. THEN TRY IF STILL NOTHING, THEN TRY TURNING KEY TO THE RUN POSITION AND LEAVE FOR 10 MINUTES.. THEN TRY IF STILL NO THEN GET BACK WITH ME FOR FURTHER INFO
Sep 01, 2009 | 2006 Toyota Corolla
Reciever powers up and recieves signal (station and song titles are displayed) but doesn't transmit to car radio either through the assigned fm station or the aux cord.
IF you have a cord plugged into the audio jack, if will TURN OFF your FM transmitter. You have to leave it unplugged for the FM transmitter to work. Go to MENU and make sure your FM station is set and that the FM OUTput signal is turned up. Write back if you need more help.
Thanks,
John
Aug 19, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
How come my Nokia 7610 cant send anymore txts and cant recieve any either?? it also cant accept any calls.. and also my phone battery gets drained so easily
Hi!... If the phone has signal an then you can't send and recieve text try to goto> Message> Message settings> Message Center Number or Center number , then compare it with another user with the same network if its the same or else copy his/her Msg Center Number if he' she is able text... And for your battery problem, how long are you using the battery?... If you always leave it overnight charging so it might be damaged or leak,... Try to buy a new battery...
Jun 19, 2009 | Nokia 7610
Yahmaha rxz9 no output signal to sub
the part where you plug in the sub has blown or warn out over night dude get it repaired i think u need to change the fuse inside the reciever
Dec 31, 2008 | Yamaha RX-Z9 Receiver
I can't get the 200 channels to recieve
GO TO YOUR FIRE STATION AND THEY SOMETIMES WILL GIVE YOU THE FREQUENCIES YOU NEED TO PUT INTO YOUR SCANNER. IF NOT, UNIDEN SELLS A MANUAL THAT LISTS ALL CHANNELS FOR WHAT YOU NEED.
DDJ.
Dec 22, 2008 | Radio Shack Pro-2018 Scanner
Radio Shack Pro-2018 Scanner Logo
144 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
xxxxxx xxx
Steve Allison
Steve Allison
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
