We have an internal kerosene boiler. How do I get rid of smells
Our boiler is in the utility room, and at times the smell is obnoxious
    New Friend:
    Problem Solver:
  • 6 Answers
If you are using a Cheap Heating Oil then you should regularly clean the boiler and its room. Don't let water spread on the floor or under the heater it will start smelling bad.
http://www.valueoils.com/
Posted on Dec 02, 2014
  • 8,404 Answers
Good luck with that. There are fuel additives that you can use ... some will reduce the smell a little. Make sure your heaters are properly adjusted and absolutely clean. I have been around kero for many years, my parents cooked with kero in the 40's. You may want to consider another kind of auxiliary heat. Natual gas is of course the best followed by electric and propane then fuel oil depending on what options are actually available to you.
Posted on Dec 07, 2012
tbugger
  • 232 Answers
SOURCE: 55000 reddyheater
What is the pressure setting on the air pump? The air pump delivers the fuel. the correct pump pressure deluvers the correct ampunt of fuel. Wrong amount of fuel/air ratio produces a stink!
Posted on Nov 08, 2008
  • 126 Answers
SOURCE: have monitor 422, have had it serviced and flame
JM,
When you have a smell from a Monitor you have a real problem. You need to get to the bottom of the problem as soon as possible due to the chance of CO gas. If the heater was just serviced I would look at the connection for the exhaust on the back of the stove. The little Z pipe needs to be all the way in on both sides. Monitors are close to the wall and sometimes it's very hard to get that pipe all the way in. Since it is a serious problem I would look at all the gaskets on the burner and heat exchanger to be sure none are missing or broken.
I can't stress this enough. If you are smelling fumes from a Monitor you must get to the bottom of it before you continue to use the heater.
Tom Hawkins
hawkins111@gci.net
Posted on Apr 25, 2009
SOURCE: ventless gas heater smells like kerosene
It is posible that your heater is burning fumes from paint, varnish or stain and some times carpet cleaners or other household cleaners. I work for a utility company. We get called to homes for a lighter fluid/kerosene smell quit often. Most of the time it is from the fumes burning off on a standing pilot gas oven. The odor collects in the oven and is released in the customers face when they open the oven door. This will happen with any open flame appliance when exposed to these fumes.
Posted on Nov 04, 2009
koolbreezes
  • 540 Answers
SOURCE: had heater for 6 yrs, now its leaving a very stong
Sounds like its ready for a tune up kit,(spark plug--vanes-- filters)nd a full cleanning. oh yes , they do have kits for these at a lawnmower shop!
Posted on Dec 18, 2009
  • 674 Answers
SOURCE: my monitor 41 smells like kerosene when it sits
Does it smell like raw kerosene or exhaust. If it smells like kerosene it sounds like you may have a fuel leak. If you can remove the grill, look inside and check for any kerosene in the bottom and in the tray under the heater. You should also check your fuel line for leaks. If it smells like exhaust look inside and on back of the heater for any black soot marks. There are a couple of o-rings, 1 in the exhaust connection in back of the heater and 1 in the flue pipe where the exhaust from the heater connects. There's also several gaskets in the combustion chamber that could be leaking. Hope this helps. If you need any more info, you can send me an email (nitensheaterservice@embarqmail.com).
Posted on Jan 24, 2010
How to get vinegar smell out of ac window unit
hi Jeff.
not saying this will work,but its all i could find on the internet.
Sprinkle baking soda on the surface being cleaned (as long as it is safe to do so). Scrub with a sponge or plastic brush to work in the baking soda. Rinse with clean water and the vinegar smell should disappear.24 Dec 2009
How to Get Rid of a Vinegar Smell ' Hunker
https://www.hunker.com/12001359/how-to-get-rid-of-a-vinegar-smell
What will neutralize the smell of vinegar?If the smell of vinegar lingers and you just hate the smell, open a box of baking soda and leave in the room that smells. The baking soda will neutralize the smell of thevinegar.What are some ways to get rid of the vinegar smell without removing ...https://www.quora.com/What-are-some-ways-to-get-rid-of-the-vinegar-smell-without-re...Search for: What will neutralize the smell of vinegar?
How do you get the smell of vinegar out of a car?Sprinkle baking soda over the carpet before vacuuming it to remove odors.Blot the area affected by the vinegar if it is still damp. ...Sprinkle baking soda over the affected area of carpet and let it sit for about an hour.Vacuum the carpet thoroughly.Reapply more baking soda and vacuum again if necessary.How to Remove a Vinegar Smell From Carpet ' Hunkerhttps://www.hunker.com/13421004/how-to-remove-a-vinegar-smell-from-carpetSearch for: How do you get the smell of vinegar out of a car?
or go to this link might help you out more.
How to get vinegar smell out Google Search
Nov 26, 2017 | Heating & Cooling
Tv emitting unpleasant smell. I seem to be only one who can smell! thought radiator causing so turned off but remains. is it dangerous? My four mth old is in the bedrooom until 6 mths. Get rid of tv?
I always recommend getting rid of the TV. It frees up so much time to do really cool things! But to your point, if the smell is of "warm" electronics it is relatively harmless. If it smells acrid, then keep an eye on it. Seriously though, I wouldn't have an infant in the same room with a television. They don't need all that stimulus. What they do need is floor time with interesting objects they can play with. This exploration period is so important for their development! You made a career choice by having kids and my best advice is to put the needs of the little one way ahead of the convenience of television. Been there.
Apr 22, 2015 | Cars & Trucks
Obnoxious smell from washer
I use "Affresh" every couple of weeks to keep the washer smelling good. Here is the product to order.
Nov 23, 2012 | Equator EZ 3600 CEE Front Load Washer /...
I have an MPI 41 Kerosene (K-1) monitor heating my home. Every time the monitor starts it gives off an intense smell of Kerosene. It lasts about 4-5 minutes after starting and then the smell seems to...
I would check all fuel lines, connections, and watch how long it takes to ignite. Kerosene heaters should atomize fuel meaning it should look like a fog not droplets, so that would point to fuel nozzle problems. That being said it should exhaust out side not in to the house, inspect the burning chamber real good for cracks or leakage? If this unit has a flue or damper make sure it has a good draft to exhaust the burnt fuel. This is purely speculation not a solution, these are things I would be looking for if it were in my home. Good luck
Jan 07, 2011 | Heating & Cooling
I just bought a remington 45,000 btu salamander. It heats great. although I'm going to have to exchange it because there is a short in the power plug. My question is : is there an additive available to...
i know you can buy kerosene additives to make it smell better.... they are liquid that you mix with the kerosene... but i'm just not sure exactly where to get it.... try like lowes, or home depot, or tractor supply co...... look around anywhere places sell kerosene heaters
Dec 26, 2010 | Desa International (R165DT) Utility Heater
Keresoene odour
The best way is to invest in an Ultra Vilolet light...many of them will eliminate odors as well as purify the air...
heatman101
Apr 11, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Need a disasemble/reassemble diagram/instructions for a cf-51
Hi!
Im not sure that you will get rid of the smell even if you vacuum clean it, but i know HOW to get rid of the smell permanetly. I work with thing like that.
I will try to explaong for you in my poor english. There are companys who works with cleaning up after a fire, the go in, start up a machine and do a "Ozone cleaning". That ozone machine kills all the oxygen in the room and that kills all the smells there is in that room. So what you need is to either borrow a ozone machine or contact a company that do ozone cleaning. Its not expensive anf it take 24h . Do that and you will never again smell that fire smoke.
You can read about Ozone Cleaning here:
http://www.thebigclean.co.uk/
Nic
Apr 07, 2009 | Panasonic Toughbook CF-51 Notebook
Kerosene smell from the dryer
I have read other places that if you have recently painted, stained, varnished or used something in your house that has some sort of oil base it can make you dryer make your clothes smell like Kerosene. My dryer started doing the same thing and it was at the same time that a contractor was staining some trim in our basement. Good luck.
Mar 22, 2009 | Kenmore 73952 Gas Dryer
Smell of oil throughout the house when the boiler is on
Other than the stench of fuel oil permeating every soft surface throughout the house, there are numerous health hazards associated with exposure to petrochemical vapors. Shut the unit off until you can get it repaired.
Mar 16, 2009 | ACCO Brands Water Heaters
Ventless gas heater smells like kerosene
Feb 05, 2009 | Procom 10K BTU, Vent Free, 2 Plaque...
Heating & Cooling Logo
119 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
