Question about Philips 47PFL7432D/37 TV
Phillips hd tv dimming - Philips 47PFL7432D/37 TV
Phillips flat screen tv left half of screen is black right side is dim and flickering
Is your tv less than a year old? You need to call Phillips and see if it is covered under warranty. If that is not the case you need to get a few estimates. You want to know if it will be cheaper to repair or replace your tv set.
1 888-744-5477 Phillips customer service number
Aug 14, 2016 | Televison & Video
Toshiba theaterwide hd
replace the lamp on your TV, but only replace it with PHILLIPS brand. Anything other than that, will not last. We just replaced ours with Phillips and the picture is much brighter. It really shows the HD quality of the tv.
Mar 24, 2014 | Televison & Video
Remote code for 26" LCD Dynex tv
Remote code for who? Dish network? Comcast?
CableVision UR2-CBL-CV04 code: 096
Charter DIGITAL code: 0463
Comcast M1057 code: 0463, 10463
Cox COX code: 0463
Direct TV RC23 code: 10463
Dish Network VIP508 code: 720
Dish Network VIP622 code: 720
Motorola DRC800 code: 0463
One for All URC-6690 code: 0464
Phillips PDVR8 code: 115
Phillips PH5DSS code: 115
Phillips PHDVD5 code: 115
Phillips PMDVR8 code: 115
RCA RCU807 code: 135
Rogers DCT3250 code: 0463
Shaw DCT3416 code: 0463
Sony RM-VL600 code: 8043
TiVo HD code: 0091
TiVo SERIES 3 code: 0091
Jun 06, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
What is the remote code for Dynex 15" HD TV
Dynex TVs can have different remote codes, depending on the model of the TV you own and the type of remote you are using. You didn't specify your specific Dynex model number, however the company only makes one 15" HD TV model. It's therefore quite likely that you own model DX-15L150A11. Even if that isn't the exact model you own, the information below should apply to all 15", 19", and 22" Dynex TV models.
Below is a list of the most common remotes, along with the corresponding IR remote code for your TV.
Cox COX code: 0463
TiVo HD code: 0091
For more information, you can visit your TV's remote code information page by clicking here, then clicking on the "Support/Downloads" tab.
Let me know if you need more information or have any other questions!
Sincerely, Ben
May 09, 2011 | Dynex Televison & Video
Can not hook my hdtv phillips tv to my dvd and
That is because your player does not support an HD signal and cannot complete the signal from one system the other.
Nov 28, 2009 | Pioneer DV-563A DVD Player
I have a 32inch Phillips HD ready TV but there does not seem to be and HD input for my DVD player
"HD input" is HDMI. If the DVD doesn't have HDMI output then use the 5 wire hookup - the component hookup.
The TV input for HD would be HDMI or component input - 5 wires.
Nov 25, 2009 | Philips DVR-1
Aspect ratio and tv type
The phillips 9P5544c isnt a HD tv so you will only have 4.3 formatt available
Jun 20, 2009 | Philips 9P5544C 55" Rear Projection...
Blurry Philips TV model # 51PW936317F
The coolant will become congealed in Phillipd rear projections and the color will get very dim and hard to focus. You can get the coolant replace kit at the following link which contains the coolant for all 3 tubes and step by step instructions om CD. Heres a link to the kit.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Apr 25, 2009 | Televison & Video
No sound on the hd setting on my lcd phillips hd tv
look in the owners manual about installing devices or components--- sounds like you have something hooked up wrong that is not allowing the video and sound to work--- if that doesnt work--- try using a combination device and hooking the two items to it--then run that device's wires to the television
Dec 03, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
How do I get HD broadcasts on a Phillips 60PP9352 TV that's 'HD ready'?
Hi.
Im guessing your in the UK.
Asking about HD as you havent stated what country you are in.
Ok You will need the following to be able to watch HD pictures on your tv set.
Either Sky HD which involves having a dish fitted. Or Virgin cable system which is not available all over the country.
If you go to either of these systems you will need to pay a subscription to view the HD channels.
http://dysonmanuals.llc.nu/
Chris..
Jan 01, 2008 | Televison & Video
Philips 47PFL7432D/37 TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
