Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hoover Upright Steam Vac, 12 amp
My carpet cleaner will put water out, but will not **** the water off the carpet into the empty tank. Please help.
  • herlongspage May 11, 2010
    i checked the suction at the round hole and it is blowing hot air
  • 294 Answers
  • Check to make sure that the lower dirty water lid is installed and secure and not cracked.
  • Check to make sure the front duct panel is installed on the dirty water tank (this will transition the water from the front nozzle into the tank)
  • Check the filter in the dirty tank lid, clean if necessary
  • Remove the lower tank and look at the motor cover, locate a round hole, you should see a black ring (gasket).
  • with the lower tank removed, turn the machine on to check suction at the round hole, if OK then your problem will be with one of the above reasons
Posted on Jan 14, 2009
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
SteamVac Carpet/Upholstery Deep Cleaner Vacuum: how do i add the solution to the steam vac? how mu...
You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
May 16, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
We purchased a Hoover Steam/Vac (F5915-900) cleaner. We assumed it be a combination STEAM and Vacuum machine. Where is the Steam? I will await your reply. Thank You.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761645
Generic problem for all Vacuums
Posted by hjopmi on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I have a similar Hoover “SteamVac” and the vacuum does not create steam as you stated, but you do have to use the hottest water with cleaning solution and the Hoover will clean your carpet by spraying down the solution, the scrubbing brushes will loosen the dirt and the vacuum will pickup the excess water until the holding tank is full and then you have to empty it, and then start again. The word “Steam Vac” is something that the Hoover factory labeled but so far I have not seen anything that actual produces “Steam” while cleaning. Feel free to contact the Hoover factory with your complaint @ the information listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
HOOVER STEAM CLEANER PROBLEM
The soap dispenser is supposed to be attched to the water tank. That grey piece, if it is round with 2 small ears on it is the metering plate, it controls the flow of water. It sits on the table that the tank sits on, insert it into the hole and turn to lock it in place.
Jan 14, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
168 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
