Question about Cameras
How do I use my digital radio with battery power?
My digital radio works fine when plugged into the mains, and it has a Lithium CR2032 battery compartment so I assume it should be battery-powered as well. I've just put a fresh battery in, but it doesn't work.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
What make and model radio? Without knowing that, I'm inclined to believe that the CR2032 is there only to preserve the clock settings in case of a power outage (assuming the radio also has a clock). A CR2032 doesn't have enough power to run a radio for very long.
Posted on Dec 07, 2012
SOURCE: No power despite fresh batteries
I am having the same issue with mine. I think it has something to do with the contacts in the camera. Mine is 1 1/2 years old. Mine is probably out of warranty. If I could get down in the battery compartment I could fit it but it is pretty deep.
Posted on Jun 22, 2008
  • 479 Answers
SOURCE: Olympus FE170 digital camera shows
on rechargeable batteries, check the mAh on the side, you would need to be about 2300 or more. also the shelf life on some rechargeables may be less than desireable... try lithium digital
Posted on Dec 18, 2008
SOURCE: Kodak EasyShare C613 turns off when connected to PC
The camera is supposed to go blank when connected to computer.
I hit the "share" button and can then download photos, even though screen is still blank.
Posted on May 27, 2009
jamo297
  • 19 Answers
SOURCE: Canon Powershot SD870 IS Digital Elph will not
This solution was originally posted by rulds2008.
"The battery regulator inside needs to be replaced around $15 from radioshack or you can take it to a camera shop for around $35 bucks. If its still under warrenty Take it in and have it repaired free."
Posted on Jul 18, 2009
Ranglo
  • 1194 Answers
SOURCE: C913 camera will not turn on - after new batteries
Try to clean the battery terminals of the camera, if there is any kind of rust, remove it.
Keep the camera off for a day with battery and memory card taken out.
Now insert the battery and memory card in and switch it on.
If still theproblem persists then there is problem with the internal circuit as the charge from the battery is not flowing in it. Then you will have to take your camera to a Kodak Repair center to get it checked.
Good luck and have a nice day.
Posted on Jan 11, 2011
What is wrong with my Roberts CR9955 clock/radio?
Do you happen to see the "Low Bat" indicator on?
It may be worth trying to leave the unit powered off for a long time (= several minutes) and then retry.
You may try this over after removing and re-installing the battery (behind the cover with a screw on the bottom of the unit).
The battery is a frequently used CR2032 lithium cell, which you can find in many stores.
May 07, 2014 | Audio Players & Recorders
Replacement battery for 5786 taylor scale
Fixya does not sell replacement batteries.
Dec 23, 2012 | Taylor Health & Beauty
I have a HP 7600 minitower and it says that I need a new onboard battery?
hi
this is real time clock battery -- keeps CMOS and time working on the system.
the onboard battery is a quarter size shaped , on the mainboard.. not sure if youc an remove it or its soldered on -- you are looking for silver coin shape, part # CR2032
you can buy this at any RADIO SHACK or Shoppers Drug mart locations in Canada
Battery size: CR2032 (coin cell)
Battery type: Lithium
hope this helps
Jul 09, 2011 | HP Compaq dc7600 Convertible Minitower PC...
7506 Glass digital lithium scale battery replacement. I need the battery no. please...
The lithium battery is a 3-Volt CR2032. The manual for the scale is available here: http://www.taylorusa.com/media/IBs/7506_ib.pdf . Additional information and a link to the manual is available here: http://www.taylorusa.com/weight-management/glass-electronic-scales/glass-lithium-electronic-scale.html .
I hope this helps.
Apr 19, 2011 | Taylor 7506 Glass Lithium Digital Bathroom...
I have a think pad r40- 2681 whenever I turn it on I have to reenter the time and date thru sys config. I found the c-mos battery but it is encased in shrink tubing. What type of battery is it?
The battery is a CR2032/S5LE 3v 220mAh Lithium battery. These are readily available with leads attached. You can make up your own by buying a CR2032 cell with tags from your local electronic store or online from e.g. Radio Spares. See http://www.rs-components.com/index.html and search for CR2032
Feb 15, 2011 | IBM ThinkPad R40 2681
Seth thomas autoset wall clock not functioning. replaced both sets of batteries (AA and CR2032), still not working.
I wish I had a solution... I'm in the exact same situation. I put in new batteries, and all I get is a faint reading of gibberish from the LCD screen, and that's it. I've tried following the instructions, but I can't set the time in the LCD clock, since it's unreadable, and almost completely gone. Seththomas.com has a web page indicating that "they will be back with info", but no support or FAQ pages. Disappointing... I have three of these clocks, and they are all behaving the same way.
Apr 10, 2010 | Seth Thomas Radio-Controlled Howard Wall...
I need a CR2032 lithium battery for my Dell Dimension 4600 PC - will any brand do?
Yes, any brand should work fine. Just be sure it's LITHIUM, they last longer.
Mar 26, 2010 | Dell Dimension 4600 PC Desktop
Hello sir Where can get the Battery for the model Royal DM4070
You can contact Royal or try Radio Shack!! Should not be a big deal to find!!
Jan 07, 2010 | Royal DM4070
What type of CMOS battery do I need for Optiplex SX270
CR2032 battery, located on the motherboard here,
http://support.dell.com/support/edocs/systems/opsx270/en/ug/battery.htm#1095363
Jan 05, 2010 | Dell OptiPlex SX270 PC Desktop
I need a new power pack (Battery) for my PC. Part
Do you mean the CMOS battery? (The little round one on the motherboard?)
In this case, you can replace the battery with a standard CR2032 lithium battery (3 volt, 220mAH rating). You get that at Walgreens, Radio Shack etc.
For how to replace the battery, take look at page 9 of the manual.
If you don't have one, you can download it here.
If you are looking for another battery, just come back here and leave a comment. I will check back and be happy to help.
Mar 03, 2009 | HP Compaq Presario SR1220NX (PJ517AAR) PC...
Cameras Logo
16 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
