SOURCE: How can I replace a damaged timer control knob?
i was reading up on this item and i came across section where they mentioned you have to purchase 4 complete different replacement knob boxes or panels
heres the link boy this product is having one heck of time
http://www.reviewcentre.com/reviews105062.html
SOURCE: Neff B1432 2002 Element blown
did you check the old element with a multimeter to make sure it is in fact faulty?
check continuity across the thermostat as well
SOURCE: How can I remove the fascia panel from my Neff
did you manage to fix your strip, i have the same problem, all4 strips have broken in the last 6 months on my U1552. how much was the replacement?
SOURCE: How do I replace a knob on a neff stainless steel
It should pull off with a little pressure, if it does not, then try levering it off with a screwdriver, or grip the knob with a pair of pliers if you can grip it, but protect the knob with a piece of cloth.
SOURCE: on the NEFF u1461 how
Pair of pliers on the old knob (make sure it is in the off position) and a hefty tug. The new one will push on by hand, push it all the way in so it is flush to the fascia and then click it to check the pop out mechanism works ok. The knob is a D shaped fitting with the flat part of the D at the top.Hope this helps. You may find when you tug at the old knob, the cover comes off and you are left with the black portion still in position, if this happens, reposition the pliers on the protruding black lug and give it another pull, this will get out the remaining part of the knob.
