I have a sony all in one desktop pc pcv-f11m but the dvd-cd is missing. what one do i need for this?
The Sony that I have is missing the drawer where you put the cd/dvd
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps.
Posted on Dec 08, 2012
SOURCE: Sony VAIO PCV-W700G Desktop PC
My vaio deshtop cant boot from cd, no boot screen i do not know how to go to bios, i try to press "del", "F9, 10, 11, 12." still cant help. Another problem it cant give sound, window sound was disable.
Please help me at tanynguyen@yahoo.com
Posted on Apr 06, 2008
  • 16 Answers
SOURCE: CD/DVD ENCLOSURE in Sony Vaio PCV RX860
http://esupport.sony.com/US/perl/tutorial-display.pl?tut_id=269&mdl=PCVRX860
this link is a tutorial of how to get the side panel off,
to get the cd drive out, you need to do a couple more steps.
first, you will need to take off the top and other side panels. this can be done by looking at the top back of the case. there are two clips that hold the top panel on. push up on the two clips and the top part will slide back and you can pull up on the panel and it should come off.
Next, you should be able to push some more clips on the top to get the side panel off. it should fold down just like the first side.
then, you need to take off the front two panels. the bottom part should be just a couple clips on the inside front of the case, and the top clips will be revealed when you take off the bottom part.
after that is done, you should be able to unscrew the cd/dvd drive from the case and unplug the cables connected to it from the top where you removed the top panel.
then you should be done
Posted on Jun 05, 2008
Dr Geek MD
  • 201 Answers
SOURCE: how to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
13-taking-apart-notebook.jpg STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
14-taking-apart-notebook.jpg STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
15-taking-apart-notebook.jpg STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
Posted on Jun 02, 2009
  • 20 Answers
SOURCE: Sony VAIO PCV-RX500 Cant get recovery cds to work
since she formatted the hard drive there is no drivers for your cd rom to work
1(888)476-6972
san diago rrc
16550 via esterillo
building 5
door two
san diego california 92127
Posted on Aug 21, 2009
gotgeek2
  • 565 Answers
SOURCE: how do you remove rh cover from Sony vaio
Download the System Reference Manual here:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCVRX755&LOC=3
See page 24.
1 Locate the tab on the upper right side of the rear panel, and pull it
back until the side panel releases.
2 Lift the side panel away from the unit and set aside.
Posted on Dec 31, 2009
My sony vaio pcv-f11m tv will not tune in to the aerial
Is the TV adapter digital ready. Try a cable connection. Digital antenna.
Nov 29, 2012 | Computers & Internet
Cd\dvd drives not working on PCV-RZ49
hmmm..perhaps you need dvd or other reading software? go to www.sony.com enter model number then search on dvd software for that model
Jun 13, 2012 | Sony VAIO PCV-RZ49 (T99861234) PC Desktop
Reset sony vio pcv f11m to factory settings
Sony desktop computers can be placed into factory restore mode by shutting them completely down, and then pressing the VAIO Assist button to turn it back on. Follow the on-screen menu to get to the restore mode that resets to factory state.
Mar 01, 2012 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
Missing dvd/cd rom drive on my computer eitheron
If you are using xp, Try google (Dail-a-FIX) the program will reset all your windows system to normal, good program for XP.
Feb 25, 2010 | Sony VAIO PCV-W600G PC Desktop
I have a Sony Vaio desktop with XP. My DVD-CD
Have you tried burning a CD in the new drive? Because the drive is a DVD it will always be recognised as a DVD, but should work perfectly well with CDs both playing and recording.
Nov 07, 2009 | Sony VAIO Digital Studio PCV-RS220 PC...
Sony dvd drive automatically running without any cd or dvd
you will need to go to the Sony website to the support web page and download the latest firmware for the drive.
Good luck
Oct 20, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Where can I get a new DVD Cd for my sony pcv-v200g.
Hello
please check first the bios settings check the boot priority select the 1st boot priority to cd or dvd rom then exit and save while inserted the bootable cd..
Angel
Thanks..
Aug 02, 2009 | Sony VAIO PCV-V200G PC Desktop
Sony vaio pcv-rs510 fails to fully boot. Goes past initial windows screen then blanks out.... safe mode fails to boot as well... command lines just pile the screen.. need help plzz
reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
May 31, 2009 | Sony VAIO PCV-RS510 PC Desktop
Open Questions:
Data Recovery After Battery Fire These days, not only businesses but individuals increasingly need access to their data on the go without thinking about storage and hardware maintenance costs. Online Cloud backup provides an efficient solution and is swiftly attaining popularity. Before cloud-computing, end users stored their personal data on computer's hard drives and memory cards. Unfortunately, computers and mobile phones require physical proximity to the device to allow access to the stored data and are far more vulnerable to damage and accidental deletion. Individual devices need diligent support and maintenance, and ensuring the security of the data remains a challenge. With, Server Cloud Backup Solution end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software Cloud Backup publishing companies choose to offer Cloud Backup For Small Business web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. An online backup service isn't much capable if the process of restoring your data and getting back to being productive is not simple and quick. DataAlign offers a search tool to find a backed-up file. Also, the ability to replicate an entire folder-tree structure, helps with preventing bigger data losses. Versioning is another capability offered by DataAlign. This allows you to see earlier versions of a file in case you made Online Backup Pricing some undesired edits. This can also be termed as archiving function. You can set the number of versions and days you wish to keep any file and utilize the maximum available storage space. Using the version history, you can view the history of each file stored and undo mistakes, if required. Any accidental deletion of file from the computer and can be restored instantly as deleted files are backed up on the cloud. The moment the data is no longer required, you can setup a data destruction policy.
May 21, 2018 | Individual Computers & Internet
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
