Question about Canon imageCLASS Office Equipment & Supplies
How can I reset System error E000 canon copier
Photocopier machine black and white
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
This is your fixing problem.you kindly open your fixing unit and cheque all cable.Then set it properly. Then go to setting option and then find where errok option and then ok, then press off button then on. Your problem will be solve.
Posted on Dec 08, 2012
  • 5 Answers
SOURCE: System Error E000
okay lets shed some light on the E000 error code on the D680, D880, IR1300 family ( including the 1310,1330,1370,1630,1670)
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used untill the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser overtemp means the fixing assy has exceeded the manufacures maximun temp limits
E002 fuser temp dropout means the fixing assy has cooled below a set point during a copy session
E003 fuser no responce means the fixing assy didnt even attempt to warm up at power on
How to fix, most common problem is bad power setting 4 E002's either brown outs of brief power failures.
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arow buttons to scroll to #4 printer reset press set.press the approprite arrow key under the YES to clear the error. unplg the copier and reboot. At this time normal function should return if not and it resets a E00 the nyou can assume either the fixing asy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to reserch the problem to avoid spending money on excess parts
Posted on Jun 07, 2008
SOURCE: How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Posted on Jul 12, 2008
  • 4 Answers
SOURCE: System error E000
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
Posted on Apr 24, 2009
SOURCE: system error E000 in conon ir2000
Sir,
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Press #
Press Set
Press Set
Press <
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Thanks
Good Luck
Posted on Apr 28, 2009
ermiaby
  • 54 Answers
SOURCE: Error E000 on Canon NP 6317.
IX. SELF DIAGNOSIS The DC controller PCB has a microprocessor that diagnoses the functions of the copier (particularly the sensors) at appropriate intervals. If this microprocessor detects an abnormality, it will display the type of the abnormality on the indicator on the control panel. The table below shows the various fault codes, their meaning, and the corresponding detection timing. Example of E000 code indication: Eó000 light alternately. Fault criteria • If the temperature difference between the thermistors 1 and 2 is 60°C or higher. • If the fixing asssembly temperature is lower than 50°C after 15 sec from the power-on. If the tempereture remains 220°C or higher for 0.1 sec or longer. If warm-up is not over after 60 sec from when the temperature reached 50°C. If fixing unit temperature drops below 50°C when the copier is in stand by or copying. If the C HEAT CHECK signal is on while the HEAT ON signal is off. If the main motor speed feedback signal does not appear after 2 sec from the main motor. If the break signals is generated continuously for 0.1 sec or more when the counter is not being driven. Code displayed Main cause Fixing roller heater (LA1) low temperature error Thermistor1 (TH1), Power supply assembly, Fixing roller heater (LA1), or DC controller PCB Fixing roller heater (LA1) low temperature error: Thermistor, fixing roller heater, AC driver, power supply assembly, DC controller PCB, thermoswitch (F1), auxiliary thermistor (TH2) Fixing roller heater (LA1) low temperature error: Thermistor (TH1), fixing roller heater, power supply assembly, DC controller PCB, thermoswitch (F1), auxiliary thermistor (TH2) Fixing heater ON timing error: Triac (U104) on power supply assembly Main motor error: Main motor (M1), DC controller PCB Counter (CNT1), DC controller PCB E000 E001 E002 E003 E004 E010 E030
Posted on Jan 11, 2010
How can repair an error of canon 2202 E000-0000 error code?
The E000, E001, E002, E003 and E007 are temperature error codes. Fixing these errors are necessory part of every
photocopier and printer. It is usefull to apply high temp and pressure to melt toner into the fibers. follow these steps
to reset E000, E001, E003 and E007.
Enter into service mode by clicking on key "2" and "8" the SSSW will display
Change bit switch 1 to bit 0
Press OK
http://canonprintersupport.us/
Sep 05, 2016 | Canon Office Equipment & Supplies
How do I solve a system error E000 on canon iR1600 photocopier?
First you need to clear that error from service mode. If problem persist replace the fixing unit
Jun 15, 2015 | Canon Office Equipment & Supplies
How do i clear error e000007-0000 on a canon ir 2200 photocopier
Fixing film assembly may need to be replaced if error cannot be cleared. Fixing error codes should be reset by a professional only. Fuser assembly must be examined before resetting the E000, E001, E003 and E007 codes. Enter the service mode this way: Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again. Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here your tech can reset the error codes. Then turn machine off & on again.
Sep 04, 2014 | Canon Cannon Ir 2022 Photocopier
Error code E000 on canon photocopier means
the thermal switch is open. you need to check this part first and if it's open you have to replace it and then erase the E code in service mode-function-error-ok.
Apr 15, 2012 | Canon NP 6050 Copier
I have canon ir2000 photocopier machine and i t is showing e354
Canon IR 2000 copier is showing System Error E000
From my searches online the first course of action seems to be resetting the printer in service mode.
I attempted to clear it in service mode:
1. Press ADDITIONAL FUNCTIONS, #
2. Go to #7 Printer and press OK
3. Go to #4 Printer Reset and press OK
4. Yes = ( > )
However, when I press the yes (>) nothing happens.
Does anyone know why this is not working?
Apr 15, 2011 | Canon ImageRunner 1600 Copier
The screen just shows error E000
E000 code Fuser Error
What model of Canon copier is it?
May 15, 2009 | Canon Office Equipment & Supplies
''System error E000''
the problem related Image Processor PCB
you will need to restart the machine.
May 13, 2009 | Canon Office Equipment & Supplies
CANON NP 6220 ERROR "E000"
replace the fuser lamp or the thermofuse.
E000 fuser problem.
Dec 12, 2008 | Canon NP 6050 Copier
115 people viewed this question
old marine
old marine
