Question about LG Washing Machines
HI Sir we have LG frnt load washing machine Model : DW 14331 ADK if i start any program than water coming in the drum but not stoping and still coming full of the drum please guide me what i do thanks
    Top Expert:
  • LG Master
  • 9,472 Answers
You will need to replace the water level pressure switch.
Posted on Dec 07, 2012
dazmaraz
  • 67 Answers
SOURCE: washing machine
this indicates a fault unfortunenately it doesnt say which one the most likely problem will be brushes in your motor
Posted on Jun 25, 2007
SOURCE: LG WF-764STP
Your problem might be the motor capacitor
Posted on Aug 31, 2007
Yozzer6821
  • 116 Answers
SOURCE: front loading washing machine is having leakage problem
You need to work out where the water is coming from, either the front, back left or right hand side to give you an idea what/where to look.
Front - Open the door and check the door seal (usually grey rubber round the door) look for splits, chaffing, damage.
Rear - check the connection to the pump, there will be a (Black) rubber hose from the drum housing about 12-18"long, check for splits, connection etc.
Check and remove the pump itself, Isolate the electricity, to remove - disconnect the outlet hose from below the sink or upstand, lower the outlet hose to the floor and syphon off the water into a bowl from the machine, there will be some even if the machine appears empty. disconnect the plug on the pump (2 wires), disconnect the hoses from the pump (2 off) and check inside the hoses, bra wires, socks etc. look inside the pump for foreign objects, the pump can be wasily split open via 3 screws normally, refit in reverse order.
Top - remove the top cover usually 2 screws at back or side and will slide slightly to remove, check hoses to drawer and the hose below drawer to top of the drum housing, check the inlet solenoids at the back (where the water hoses connect).
hope this helps
Posted on Apr 08, 2008
jason0110
  • 66 Answers
SOURCE: stoped machine
if you still have power then it sounds as if your pump may be blocked
Posted on Jun 15, 2008
  • 3 Answers
SOURCE: Sir, Drum of front loading washing machine making banging noise
Mine did that and had to have the washer re-balanced.
Posted on Aug 16, 2010
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
Nextt 100 frnt load washer wont go past rinse cycle..stops with drum full of water..i cleaned the pump area filter and drain hoses and upper cannister thoroly..whats nexxt??
It can be the program controller unit. You need to check the output to the program controller unit to confirm if the power comes out to the next cycle. Start by following from the inlet opening vavle, the cut off and the motor drive to confirm.
Please see these tips: Repairing Washer
Jun 28, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Hi my LG WD-14311RD washing machine refuses to unlock. Cannot open the door,just remains locked.
My model no is LG WD-14331 AD the door just remains locked cant open i think the handle inside plastic hv broken how to solve can u send some one come to repair or .
BR Chow
Jul 29, 2011 | LG WD14311RD Front Load Washer / Dryer
LG WF T6517TC Washing Machine does not fill water
sir
my washing machine WF-T6517TC
when it start to wash get Alarm "dE" beep and stop machine.
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
User manual needed
Hi there at great risk of sounding a cad..(.was this cash or a cheque)...id doubt very much if its anywhere under the drum....if it WAS in the pocket it would still be there crushed and a little discoloured..had got into the drum it would have blocked the filter .IF he was paid in coins then youd have stopped tthe machine..
regards Sir Galahad
Aug 20, 2009 | LG WFT1071TP Top Load Washer
Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
May 19, 2009 | Samsung SW62ASP Top Load Washer
LG WF-T1022TP Fuzzy Logic
hi my name is joyce
the pump is stuck. you need to get a pump replaced, a piece of dirt is all it takes to mess up the pump, exspecally if you are on well system, check the filter in the line and make sure its clean. if the machine is not spinning out, and its running the entire cycle the transmission is not engaging correctly, have this checked out.
let me know if you need further help
Thanks,
joyce
Feb 06, 2009 | LG WFT1071TP Top Load Washer
Beko washing machine fills with water when not in use!!
hi there.....you got a faulty water inlet valve on the machine ..change this and all will be fine again...
regards Sir Galahad
Dec 05, 2008 | Beko 24 in. D3421F Free-standing...
Washing Machines Logo
232 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
