Question about Toshiba Magnia 5100 Server
Management interface failed - Toshiba Magnia 5100 Server
  • Toshiba Master
  • 1,511 Answers
Keep trying, eventually it will work.
Posted on Jan 29, 2014
What Web-based Management Features Do Switches Excluding the S1700 Support?
Table 1 lists the web-based management features supported by S series switches.
Table 1 Web-based management features supported by switches Category
Function System management Upgrade, patch loading, PoE, DNS, stacking, viewing log files, and setting the system time, SNMP parameters, and EasyDeploy parameters
NOTE: Switches in V200R002 and later versions support SNMP and EasyDeploy parameter configuration. Interface management Viewing/configuring basic interface attributes and viewing statistics on an interface Service management VLAN, MAC address, STP, voice VLAN, DHCP, ARP, VRRP, and IGMP snooping ACL management Creating/modifying/deleting ACL rules and effective periods QoS Priority mapping, traffic policy, rate limit on an interface, traffic shaping, and congestion management Route management Viewing IPv4 routes, configuring static routes, and setting the preference of static routes Security management Port isolation, static user binding, AAA, 802.1x authentication, and MAC address authentication Tools Ping, Tracert, and VCT S2300 Switch Thunder link com
Feb 09, 2017 | The Computers & Internet
What Are the Differences in AP-side Switch Interface Configuration and Intermediate Switch Configuration in Direct and Tunnel Forwarding Modes?
Differences in configuration on switch interfaces connected to APs are as follows:
In tunnel forwarding mode, interfaces connected to APs transparently transmit only packets of the management VLAN. These interfaces must be added to the management VLAN in untagged mode. In direct forwarding mode, interfaces connected to APs must be trunk or hybrid interfaces. These interfaces must be added to the management VLAN in untagged mode and added to service VLANs in tagged mode. If a trunk interface is connected to an AP, the PVID of the interface must be set to the management VLAN ID.
Differences in configuration on intermediate switches are as follows:
In tunnel forwarding mode, intermediate switches transparently transmit only packets of the management VLAN. In direct forwarding mode, intermediate switches transparently transmit packets of both the management VLAN and service VLANs.
S5700 Switch Thunder link com
Oct 17, 2016 | The Office Equipment & Supplies
Ethernet controller drivers for hp mini1000
click start control panel admistrive tools computer management device manager scroll down network adapters + expand Ethernet driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? ! question or exclamation mark or red x means you need to install/update driver right click to install driver
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard dischttp://download.cnet.com/realtek-rtl8139-810x-family/3000-2112_4-96337.htmlRealtek RTL8139/810x Family Fast Ethernet NIC:It is a highly integrated and cost-effective single-chip Fast Ethernet controller. It is enhanced with an ACPI (Advanced Configuration Power Interface) management function for PCI/Mini-PCI/Cardbus in order to provide efficient power management for advanced operating systems with OSPM (Operating System Directed Power Management). The RTL8139C(L) also provides a remote wake-up function by Magic Packet & Wake-up Frame to increase cost-efficiency in network maintenance and management. Furthermore, it supports the Cardbus interface for PC Card applications and is an ideal solution for notebook / motherboard-embedded network design.
hope this helps
Apr 29, 2011 | Computers & Internet
How do I change my MTU settings?
Hi
Please loginto the router management console
Then go into the interface mode
You can set the MTU as per your requirement inside the interface settings
By default the MTU is being set as 1500bytes on Ethernet type interfaces
Nov 01, 2010 | 2wire (1000-400108-001) Router
I have a 3Com baseline 2816 switch that I can access through management web interface. I do not have the current configuration of the switch neither the MAC address info. Is there a method to hard reset it...
To hard reset the switch back to the defaults
use a pen or sharp object and hold the reset button on back of the switch in - then unplug/plug back in the power while the reset button is still depressed until the power led goes to solid amber - The switch is now in fail safe mode - Connect your pc/laptop to one of the front panel ports and see if you can discover the switch - if you still can't then configure your pc/laptop to the 169.254.0.0 - class B network and run the discovery again
once you have discovered the switch and can login -hit the upgrade firmware button and reload the code - you can check the progress at the bottom of the screen which has a toolbar showing the status of the upgrade
Dec 10, 2009 | Computers & Internet
Acer elock
You don't need to pay acer the 100usd to get the password removed,
one thing you can try first, is to disable the elock service from
start -> run -> type in services.msc
look for elock service right click properties startup type disabled and stop the service, on some elocks this is enought to stop it from working. but it debends I can fix this and I have done it many times now..
Nov 29, 2008 | Computers & Internet
Modem
Technical Specifications AAL and ATM Support
VCI 0-65535 address range
VPI 0-255 address range
AAL5 support
Bridging
IEEE 802.1.d Transparent Learning Bridge (dynamic learning of up to 255 addresses)
Spanning Tree support
Certifications
FCC Part 15, Class B
CE certification
Connectors
DSL interface: RJ-11 or RJ-45 (Europe)
Ethernet interface: RJ-45
USB Type B interface (5200, 5500 series)
Diagnostic LEDs
Power, DSL, Activity, Ethernet status; USB status (5200, 5500 series)
Management
Intuitive, Web-based GUI management access
SNMP support
Comprehensive hardware diagnostics
Media Interface
RJ-11 or RJ-45 (European) DSL WAN connection
10/100Base-T RJ-45 Ethernet LAN connection
USB Type B LAN connection (5200, 5500 series)
Power
12V power supply included, 700ma max. 5400/5500 - 12 VDC, 1000ma max.
Routing
DHCP server/DHCP client
Network Address Port Translation (NAPT)
Network Address Translation (NAT)
Packet filtering
RFC 2364 Point-to-Point Protocol over ATM PVCs (PPPoA)
RFC 2516 Point-to-Point Protocol over Ethernet (PPPoE)
RFC 2684 (formerly 1483) Bridged Ethernet and routed encapsulation Routing
Standards Compliance
IEEE 802.3
USB 1.1 T1.413 issue 2 G.992.1 (G.DMT) G.992.2 (G.Lite)
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
How can I manage the Prestige 310 ?
# Menu driven user interface for easy network management Local and remote console management # Windows configurator Telnet remote management # TFTP (Trivial File Transfer Protocol) firmware upgrade and configuration backup and restore
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
Open Questions:
Cloud Storage - Online Data Storage ' Dataalign Cloud Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Server Cloud Backup Solution their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Cloud Backup For Small Business companies with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in mind. To provide Online Backup Pricing optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
May 24, 2018 | VIA Computers & Internet
See all Toshiba Magnia 5100 Server Questions
Toshiba Magnia 5100 Server Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
