My laptop is over heating
Over heating during net conection
  • 32,281 Answers
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on Dec 07, 2012
Error 106 (net::ERR_INTERNET_DISCONNECTED): The Internet connection has been lost.
i'm not sure what the actual problem is, of course it's going to say the connection to the internet is lost if you disable the wireless adapter. what exactly is the problem?
Feb 26, 2012 | Computers & Internet
Why Thinkpad T23 2647 4MP can't conect net after installed windows XP?
I do not use an automatic driver detection program, because they have a tendency to install the wrong drivers.
I look in Device Manager, and use the driver that matches THAT device, the O/S used, and is the newest version, (Date), with all the bugs worked out from an older version.
For your laptop that would be;
Ethernet Driver for Intel PRO/100 VE LAN that is the 49675 version, and has the date of November 8, 2002,
http://support.lenovo.com/en_US/downloads/detail.page?DocID=DS002672
Regards,
joecoolvette
Jan 28, 2012 | IBM ThinkPad T23 2647 Notebook
Laptop wont connect to internet
Your laptop has a manual IP on it you will have to dis able the IP and make it automatic for it to browse the net would have been more detailed if I knew the operating system u are using
Dec 05, 2011 | Sony Computers & Internet
Hello there my name is Isaac and i bought the net book yestarday, i followed the steps to conect it to my home's wireless internet and i could get it conected, however, although the netbook says that is...
I have a similar problem when connecting to a new network with my laptop sometimes.
I would try two things:
-Restart your netbook and see if it will connect, sometimes that's all it needs
-"Reset" your wireless router. This does NOT mean hit the reset button to get rid of all settings, instead, just unplug it for ten seconds and plug it back in.
Mar 17, 2011 | Sylvania G-Netbook
Wireless net
Can you connect to the router?
please do the following
Start/run/cmd<enter>
type "Ipconfig <enter>"
copy the results in to a message window so I may see it
Nov 04, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
My nokia2626 is not conect inter net conection
it's because the fault in installer cd which u install modem
Sep 15, 2008 | Nokia 2600
Wireless router
During setup you must have a RJ45 ethernet cable plugged, one end on your router and the other on the laptop.
Make sure on your laptop, that the Local Area Network Connection is "Enabled".
If it is "Disabled" Just double click on the icon to "Enable" it then try your Setup process again.
This should work.
Regards,
Abdul Qayyum
Jun 16, 2008 | Computers & Internet
Getting on to net
Having a limited connection could mean that your laptop is far away from the router, but I think you had already tried getting closer with your laptop. At the router's web utility page see if your router is in G-only or mixed, if is not then change it to mixed (or G-only if your laptop is the only one connectiong to your router). Try again to connect to the router, if you still have the same problem then I suggest you to input an IP address and DNS manually.
Hope this works out!
Feb 16, 2008 | Computers & Internet
Network
hii you conect net server pc . all pc conect in switch ..then your name all pc diffence .. and net conect server pc then go net conection dailbox properties ..networking ....enabil network conection then so server pc auto ip address....apply ok  done
Jan 08, 2008 | Computers & Internet
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
