Question about Onkyo LS-V955 System
Remote I have a P-3160 preamp and a M-5140 power amp and I missplaced the remote to the preamp can you tell me what model remotes for onkyo equipment will work or can I get another original remote
    Problem Solver:
  • 11 Answers
Fine audio equipment from Japanese manufacturer's like Onkyo is typically "stand-alone", meaning there often is no universal remote control available that will work a given unit; those that will work are rarely capable of accessing all the features & functions such units employ...best bet is an original equipment remote control; recommend you try going to this site:
http://www.onkyousa.com/
and search for links to the P-3160 preamp & how to contact the Sales Department about cost & availability...
Posted on Oct 27, 2009
How do I program an AT&T u-verse remote to an ONKYO RC-866M remote
The RC-866M is the remote. What you need to do is add the codes for your Onkyo receiver into the ATT remote. There are 4 or 5 different Uverse remotes, but most can be reprogrammed by pressing the 'Menu' and 'OK' button together. First add your Onkyo codes to the ATT remote as an 'aux' device. After that is working, you can control the power and volume by adding the 'aux' device (Onkyo) to the power and volume buttons on the uverse remote.
These are all the different Onkyo Receiver codes:
Onkyo: 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140
This is how to reprogram the S10 style of Uverse remote:
http://www.att.com/support_media/images/pdf/uverse/standard_black_remote_control_uverse.pdf
Dec 22, 2014 | Onkyo Audio Players & Recorders
Cant get channel a & b to stay on together
You need to connect all the remote cables together then turn on the multiple room button on the onkyo p-301 preamp if u have it the it should turn on.
Dec 17, 2012 | Onkyo M-501 Amplifier
Need universal remote code for ATT uverse remote for an avr Onkyo TX-SR875
hi! i do have a couple of codes here for your Onkyo 2006, 2219, 2220, 2318, 2410,5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140 hope this helps! goodluck!
Mar 07, 2010 | Onkyo TX-SR875 Receiver
What is the remote control code to control the TX-SR506 from an ATT Uverse remote
hi i have here a couple of codes for Onkyo you could try them 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140, 2006, 2219, 2220, 2318, 2410
hope this help! goodluck!
Nov 24, 2009 | Onkyo TX-SR506 Receiver
I have an ONKYO TX-SV717Pro amp. recently I lost
It could be that you lost the power supply to the surround amp IC or the Ic is defective. It should be mounted on a circuit board attached to the heatsink. Look for poor solder connections first. I don't recall the specifics of this model, but the surround amp IC should be easily located.
Update this with your progress and I'll try to locate the service manual in the meantime.
Dan
Oct 22, 2009 | Onkyo M-282 2-Channel Amplifier
Onkyo P-3160 pre-amp doesn't output on the right channel. Think it can be fixee?
Most likely it can be fixed. One of the things that could stymie this is if there is a part that is not available. It also would be nice if a service manual or diagram is available though that might not be essential (a genuine maybe here) if the repairer is familiar with preamps in general. Of course who would repair it and what it would cost are prime considerations. I likely would be able to repair it were I still in business but I am retired and that is not the case. Nor do I believe that even were I not, that this would be possible due to Fix-Ya rules (can't solicit business).
Jul 02, 2009 | Audio Players & Recorders
Onkyo CR-505Dab - no sound!
The problem could be with the remote itself. The volume buttons on remotes usually get the most use and therefore wear out. Try using a universal remote programmed for your Onkyo and see if that works.
Dec 26, 2008 | Audio Players & Recorders
P-301 onkyo pre-amp
Hi juicer, If you use the switched outlet, then everything will be turned on/off when you operate the preamp power switch. Use the unswitched, then you have to turn off each unit separately. You choose which one you want. It wont matter.
What connection do you intend to use to connect the LBT zx6 to the Onkyo preamp??
Mar 20, 2008 | Audio Players & Recorders
No power
disconnect thesub amp and see if it power up if so
Dec 13, 2007 | Definitive SubAmp 600 Amplifier
Onkyo LS-V955 System Logo
241 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
