Question about Neff Ovens
A Neff warming drawer red light flashes
The drawer is closed properly and the red light glows for about 15 seconds and then starts to flash and the drawer does not warm up
    New Friend:
There is a 'plug and socket' connector at the back of the warming drawer which does wear and eventually start to make erratic or no electrical contact. The drawer electronics read this as an open drawer and switch off the power to the heating element (flashing red light). If your competent the drawer can be stripped down and the contacts serviced or replaced otherwise consult a service technician.
Posted on Jun 24, 2016
SOURCE: Electric warming drawer will not heat
Found that there is an electrical connection at the point the main electric enters the back of the stove. There is a connector for the element that was not connected. Now it works!
Posted on Feb 19, 2009
bschilz
  • 2049 Answers
SOURCE: The oven warms up and then starts beeping and
The "F10" oven error code means "Runaway temperature".
If you have technical skills, you can try to diagnose and repair yourself, otherwise, call a qualified appliance repairman.
Locate the temperature probe wire plug at the Electronic Oven Control (EOC) and measure its resistance. It’s supposed to be about 1100 Ohms at the room temperature.
If the reading is wrong, replace the oven temperature probe.
If the reading is correct, replace the EOC.
Posted on Jan 28, 2010
  • 57 Answers
SOURCE: neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
Posted on Aug 26, 2009
jayhawke
  • 338 Answers
SOURCE: My bad... I use my
open drawer- use hot dog tongs and fish for rack- or a large kitchen magnet on a string
Posted on May 28, 2011
Testimonial: "Very helpful! This was something I was sure I didn't need a repairman to fix, I just wasn't sure how to go about it. Thanks a million! "
KevinWhite
  • 1902 Answers
SOURCE: Whirlpool electric oven won't heat just barely
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then test the door switch. Please get back to me if you have any other questions.
Kevin
Posted on Jun 09, 2011
How do I switch neff oven from auto to manual
reset the clock to the proper time
Oct 25, 2015 | Neff Ovens
Where can I get installation and operating instructions for a NEFF 29c warming drawer?
Hi Pat,
I suggest contacting Neff directly. You can email them or telehone them from choices on the page linked below:
http://www.neff.co.uk/customer-service.html
Apr 14, 2015 | Neff Ovens
I have neff double oven ,only had it two weeks and the top oven which i use the most looks filthy- i have had it on self clean at least three times but the floor of oven is burnt on and looks awful. W
Self-cleaning ovens are not "squeaky clean" after the cleaning cycle has run. Any spilled food or debris in the oven before it cleans will be left behind as ashes, soot, etc. and you will need to wipe it out with a damp cloth afterwards. If the residue is black and sticky then the cleaning cycle isn't running at a high enough temperature. Please refer to the manufacturer's instructions to make sure the cleaning feature is working and being operated properly.
Nov 20, 2014 | Neff Ovens
Oven light switching on and off
which model is it?
switch it off at the mains ie fuse boad...label cooker switch....for 10 seconds, then back on.
Sep 04, 2014 | Neff Ovens
My Neff U1421 bottom oven has failed.
Probably the ring element. If the clock is flashing zeros or 8's the bottom oven will not operate but the top will. Make sure the clock is set (doesn't have to be the correct time, just not flashing) If the fan and light then work but no heat, defo the element part no 499003
Mar 21, 2013 | Neff U1421 Double circotherm Electric Oven
Neff b1421n not heating up, grill and fan ok
breakers off ,,,back wall bottom center is a mounting plate 2 screws to take out the pull out wires and remove wires(careful not to let them slide back in)install new element...wires first the push back in place(no need to open back) don't forget breakers on now...you did it.... good for you.
Aug 25, 2009 | Neff B1421 Electric Single Oven
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Ovens Logo
2,396 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
