How to root LG SU950
Root access instructions for LG SU950
How to get iPhone emoji on my Android phone?
If you are used to sending emojis in your chat messages, you will very well know that these emojis do not look the same on all devices. But, you can get iPhone emojis on your Android phone.
How To Get iPhone Emojis On Android Phone?
The sure shot way to get iPhone emojis on your Android device is to root your phone. Follow the following steps carefully:
1. Connect your mobile to the computer and allow the rooting tool to do the job. The Kingoroot tool will be helpful for this.
2. Sometimes, it may not be able to root some Android devices, and you need to check for compatibility of your device before you begin the process.
3. Once you run the program, you need to follow the instructions given on the screen carefully, and you may even need to restart the system a few times.
Once the rooting process is done, you can go ahead and install this new app that will wipe out the default emoji designs of your Android device. In this way, you will also be able to access the iconography used by Twitter, LG and Samsung phones.
May 06, 2017 | Android Cell Phones
How do i root LG tablet with computer?
Root LG Device with OneClick Root
  1. Step 1: Connect LG phone to PC and enable USB Debugging on LG phone by following steps. Drag and drop down the notification window. ...
  2. Step 2: Install LG Drivers on your computer. ...
  3. Step 3: Download LG One Click Root. ...
  4. Step 4: When connection is successful, click the "Start" key.
Oct 03, 2016 | LG Cell Phones
How do I root an LG LS665
Hello
You can root your mobile phone using this link -i'm not responsible for any problems that might happen-
http://www.howto-rootphone.com/how-to-root-lg-tribute-2-ls665-tools-download.html
This link will be very helpful to you.
Feb 12, 2016 | LG Cell Phones
Why can't I access the playstore app to access my account? Why does anything I try time out before an action can happen?
If you are rooted go into the root folder and go into etc then find the host folder and delete every line except the first which should say Localhost and then and ip. you can search for the exact line that should be left
Aug 04, 2015 | LG Straight TaL34C Optimus Fuel Android...
How do you root the lg ms395?
Hi, Allen here is a guide about stump root for LG devices, maybe it can help you.
http://forum.xda-developers.com/lg-g3/orig-development/root-stump-root-lg-g3-sprint-verizon-t2850906
Mar 26, 2015 | LG Cell Phones
How do you root a cellphone from cell phone for LG optimus?
I assume you're talking about the Optimus G? If not, please provide specific model number. Anyway, it's been awhile since I've had that phone, but when I did, you had to have a computer to root it. I don't believe that has changed. Step-by-step instructions can be found at the following links:
GUIDE ROOT BL Unlock Install Custom Recovery LG Optimus E970 1 3
LG Optimus All Things Root Guide Android Forums
Rooting for LG Optimus sprint Updated 3 13 13 Android Forums
Aug 15, 2014 | Cell Phones
How do i unlock memo on galaxy s2
Hi Andre,
You must gain root access in order to reset the password as there is no other way. If you do not have access, search XDA Forums for instructions on how to root. Rooting procedure for S2 is pretty established and straight forward.
Once you have root, you will need to do the following steps:
  • Get a Root File Browser which can edit and save text files. I used: Root Browser. Make sure you download the plugins at first run. (2-3MB in size)
  • Browse to: /data/user/0/com.sec.android.app.memo/shared_prefs/
  • Open AppLockPreferences.xml with some text editor.
  • Change the value field in front of applock_enable from "1" to "0".
  • Change the value field in front of encrypt from "true" to "false"
  • Save the file. Open SMemo, it should ask you to set a new password. Your memos should open with the password you just set.
    Please contact me if you need further assistance,
    Thanks,
    Hunter Quinn
    IBM Technician
  • Jul 08, 2014 | Samsung Galaxy S GTI9000 Smartphone
    LG-SU950 how hard reset
    too many pattern attempts
    Dec 09, 2013 | LG Cyon
    Root my Android SII Galaxy
    Hello, mess82
    You can safely root your Samsung Galaxy S2 Android device. Simply follow the detailed step by step instructions available in this site and you're done!
    Regards!
    Sep 11, 2012 | SOTI Inc SOTI MobiControl
    77 people viewed this question
    k24674
