Question about Radio Communications
LAVA Headset Issue
Hope you are aware, once we insert Headset in LAVA mobile the profile will automatically change to "Headset". When we remove the headset the profile will automatically change to "Normal" mode. . But my problem is even after removing the Headset the prof ile is not changing to normal mode, its still in "Headset" mode. Now If i want to speak with someone, i should plugin headset. without headset I cannot speak.. :(
  • 2 more comments
  • Mohanbabu Dec 10, 2012
    This is phone issue not the headset issue. Profile is not getting changed.
    I have tried all basic options.... like
    I have tried all basic options... like
    1) Switching Off the mobile with headset / without headset. 2) Removing battery. 3) Removing sim cards and SD memory card. 4) Restoring fac setting etc... but nothing worked.. :(
5 Suggested Answers
SOURCE: my mobile profile is changed general to headset
connect headset then switch off then on . aftr dat disconnect the head phone
Posted on Jul 12, 2011
SOURCE: hbh-pv705
I had this problem. I fixed it doing follow: hold volume keys together, so the indicator is flashed red and green (reset to default settings mode). Then press power button to turn the headset off. Then turn it on again and try to find the headset again from my phone. Then select "pair" from phone menu and typed "0000". The led stopped flashing and headset was connected. Before this my phone couldn't see the headset at all. Hope it will help you! (sorry for my English, I'm from Russia =))
Posted on Aug 06, 2008
praky16
  • 744 Answers
SOURCE: logitech headset not working
did u connect both the output wires from ur headset to ur system audio port.?
Posted on Feb 08, 2009
SOURCE: my motoriola H710 headset is paired, but no one can hear me
The microphone no longer works. Don’t know if you can change the Microphone of your headset through some authorized service personnel or not.
Posted on Jun 09, 2010
Tip
How do I automatically start Bluetooth?
<p>Bluetooth is a wireless connection method used for two different devices together, like a computer, cell phone, headset or sync. You are required to enter code synchronization when connecting two devices, but most likely you do not want to enter this information each time you want to sync the hardware. Instead, you can automatically start the Bluetooth devices in sync with each other. <br /> <p><br /> <p>1. Turn on the Bluetooth device (such as a headset) and the hardware you want to synchronize with the equipment (such as your computer or mobile phone). <br /> <p><br /> <p>2. Click the "Start" button when using a computer, select "Control Panel" and finally "Hardware and Sound". Select "Bluetooth Devices" and click "Add" and wait for the computer to search for Bluetooth devices. Press "Setup" when using a mobile phone, select "Bluetooth" and activate the configuration. This allows the phone to search for the Bluetooth device. <br /> <p><br /> <p>3. Select the Bluetooth device, once it is detected (both computers and mobile phones) and enter your pair of four-digit code (listed in the user manual of Bluetooth device). <br /> <p><br /> <p>4. Press "OK" on your computer or mobile phone connects to Bluetooth. Now each time the devices are enabled on the phone and the computer automatically detect and connect to Bluetooth devices. <br />
on Jun 26, 2011 | Computers & Internet
Tip
THE DETECTIVE TRICK (Mobile Spying)
<span>Now you can spy on anyone using your cellphone. Just do the following. <ol> <li>Activate the "Automatic Answer" in the headset profile of your cellphone and set the ringing volume to "Mute"</li> <li>Short-circuit the left middle and right pins on the bottom of the mobile phone with all connections touching each other this will activate profile "Headset".<br />If you cant do this just keep your earphone connected to mobile.</li> <li>Now place it under a table in a room and call it. Now you can use your phone for checking out what people are talking about in a room. Just call on your phone.</li> <li>The phone receives the call without ringing and you can listen to what people are saying.</li></ol></span>
on Jan 01, 2011 | Cell Phones
Lg gm200 mobile profile is changed general to headset without connect headset
why profiles fom geneal to headset without headphone
Jan 30, 2012 | Cell Phones
My lava a10 disturb java setting please send me orignal setting & how i set gprs setting
DearFriend (shabsohel999),
I saw 2 queries from youon Lava A10:
1) Your original Javasettings on Lava A10 is messed up and you need the settings again. Pls. find below the Java settings on A10:
Javaaudio: (Default is 4). You can select thelevel you want
Javavibration: (Default is ON). You can selectthe vibration "On" or "Off"
SelectSIM: (Default is SIM1). You can selectSIM1 or SIM2, depending on the SIM you want to use to launch the Javaapplication.
JavaSIM1 profile: Select your operator from thedrop down list.
JavaSIM2 profile: Select your operator from thedrop down list.
2) You want to know theway to do GPRS Settings.
- Ideally, as soon asyou insert any SIM card in the Lava A10 handset you should get the GPRSsettings from your operator in the form of an SMS. You can click on"Install" and the settings will be done automatically.
- But in case you do notget the settings automatically, you can call your operator and they will provideyou the necessary settings. The GPRS settings are operator specific. Lava A10is already registered with all the major operators in India, so will get the GPRSsettings without any problem.
- In case your problemis not solved by the above mentioned ways, than pls. let me know your Operatorname and your city. I will directly send you the GPRS settings directly.
You can reach me directlyon mayank.purohit@lavainternational.infor any futher help.
Mar 15, 2011 | Cell Phones
Lava arc 02 keypad problem
lava arc03 insert sim salutions sevd me to salmankhan99722@gmail.com..........
Dec 20, 2010 | Cell Phones
What is the format code for micromax q75 mobile actually in profile setting showing only customize not showing activate menu and activated only headst profile i tried to change profile but when i tried to...
to change the profile first dial the code *#84666*# then u vl reciv d menu of Factory mode. nw insert yr handsfree in fon first then go to the no.14 item "Headset" & press 'On'. thus u can check yr headset that its working. after that just easily pull out yr handsfree and u vl got the General profile simply.
I tested on my fon vn i stuck by this prblm
for further help u can ask me
Sep 26, 2010 | Cell Phones
110i/1112 Nokia cant activate headset option
generally wen you insert the headset pin it goes automatically to headset profile, if this is not working then go bak to the vendor & get the phones software changed
Oct 13, 2008 | Nokia 1100
Radio Communications Logo
352 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
