Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Removal of protection screen mitsubishi ws55819 rear projection
How do you remove the protection screen. where to find a new protection screen. the old screen was scratched very deeply
  • 1 more comment
  • cbmb95 Jan 12, 2009
    would you know where to get a replacement protective screen. mitsubishi states they dont make it or have any more in stock. this piece of lexan has a purple uv tint to it and the glass company can not find the lexan.
    yes i see how both methods work as far taking out the screen. thank you. is the piece of lexan you have from this model tv ws55819 and how much for the part
    THANK YOU ILL GIVE IT A SHOT
  • 29 Answers
I'M A 30 YR SERVICE TECH.
ON THE LEFT AND RIGHT SIDE OF THE SCREEN THERE IS A BLACK STRIP OF PLASTIC. SLIDE A CREDIT CARD OR SCREW DRIVER IN BETWEEN THE SCREEN AND THE STRIP (CAREFUL NOT TO SCRATCH THE SCREEN) AND REMOVE THE STRIP. USE SCREW DRIVE AT THE MID POINT OF THE SIDE OF THE SCREEN TO BOW SCREEN OUT AND REMOVE SCREEN.
APGONZO
Posted on Jan 12, 2009
    Sergeant:
  • 233 Answers
You will need to pull the bottom of the unit off, this is just a snap on speaker grille across the bottom... then you will remove the screws across the bottom of the grey frame holding the screen... un plug the 2 plugs going to the control panel buttons, lift UP then OUT and it will come off.. once off, lay face down on a blanket and you can remove the frame screws INSIDE to pull out the protective screen. I took mine off to stop all of the glare problems. Also, while you have the screen off, clean your mirror and lenses since they will be easily accessible.. windex will do the job well, just make sure not to leave a bunch of lint from paper towels!
  • Josh Crager
    Josh Crager Jan 12, 2009
    I have one here, but you dont HAVE to have the tinted lexan, clear would work perfectly fine.. Also, the method that was mantioned below mine works as well, and is actually the way mitsubishi says to do it, but you risk marring up the plastic surrounding of the screen doing it that way..
  • Josh Crager
    Im sorry, mine is the 65 inch, not the 55 inch... any class shop should be able to cut you a piece of lexan or acrylic <-(harder to scratch) if you bring them the old piece, or measurements.
How do i remove a large scratch on my rear projection tv
I'm sorry, but you don't. It is probibally the protective cover that is scratched and not the screen itself. You should be able to take off the protective cover and replace it. Or you can just leave it off, but you risk damaging the screen itself when you do this.
Oct 25, 2009 | Mitsubishi VS-55609 55" Rear Projection...
Replacement protective screen for mitsubishi rear projection tv
I would measure the old one and have a piece cut at a local glass store.All it is is a piece of plexiglass.You will save yourself over $200 doing this rather than ordering the Mitsubishi part number.
Jan 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi ws55819 has no picture
the pico fuses are 6.3 amp. any type pico fuse rated at 6.3 amp will do and the convergence ic's are labeled on the body of the ic. (STK 391-010 or similar). the board that the ic's are on can be removed without removing the entire tray. the connectors are marked and even different sizes to prevent miss-connection when installing board abain. be carefull removing the board as the screws holding it in also hold the heat-sink for the ic's as well as the shield for the generator module.
And do please unplug the set first!!
Dec 28, 2008 | Mitsubishi WS-55819 55" Rear Projection...
WS55819
open the tv there will be three lamps inside around black stands and simply unscrew them
Sep 29, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Protective screen
remove the bottom it should snap off and then see if this model has screws to hold the frame up otherwise it just pop off
Feb 08, 2008 | Mitsubishi WS-65815 65" Rear Projection...
No parts
is it the clear cover protecting the lentil screen behind that you are talking about. if so you dont need this. more often by removing it you get a better picture.
the lentil screen can be brought in the states quite easily.
doing a web search there is a company that will cut you a new one of the roll.
Nov 28, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
322 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
