Work is updating desk top computers, i was fortunate to get one,its a phillips unfortunately it came without the hard drive, where can i get one from
  • 32,281 Answers
You can purchase one from a computer shop or on the Internet.
Hard drives can be IDE/PATA or SATA, make sure you purchase the correct type for your Phillips desktop computer.
Posted on Dec 07, 2012
5 Suggested Answers
  • 349 Answers
SOURCE: IHAVE A DESK TOP SYSTEMAX
if you require the drivers for your system go to the manufacturing website and download them.
if you need the recovery discs ,again contact the manufacturer,they will charge you for it.
if you only need the operating system disc ,sorry you have to pay for it ,at any pc outlet.
hope this helps you
Terry
Posted on Apr 04, 2008
  • 24 Answers
SOURCE: HP DESK TOP M733ON WILL NOT BOOT, WOULD NOT BOOT
That's because "not booting" only relates to the hard drive after you have eliminated the power cord, power supply, motherboard, memory and CPU of the computer. Eliminate those 5 things and in the process you will have found your answer.
Posted on Jan 04, 2010
rhojojoe
  • 93 Answers
SOURCE: i have a dell desk top computer what type of hard
Since you've not specified whether your Dell supports SATA or IDE. Please open it and check it whether it has IDE Slots and cable or
SATA cable and slots.
bad4060.jpg429ffb6.jpgIf it supports Sata, buy SATA Hard drive otherwise buy IDE.
For a monitor just buy any, either flat screen or Cathod Ray
Posted on Jun 16, 2010
  • 53 Answers
SOURCE: How do I remove the
did you remove the cage? You have to take out the entire cage to be able to remove the harddrive from the cage itself.
Posted on May 16, 2011
Will a laptop hard drive work on a desk top computer?
A laptop HD will not work on a desk top computer. the cables connections are different.
Dec 01, 2013 | Computers & Internet
How to retrieve any information from the hard drive when the computer system stops working
you will need to get an external hard drive enclosure. you can pick this up from newegg.com or amazon.com
make sure you get an internal IDE instead of SATA which I believe you have since the hard drive is only 4.3 GB. look for a IDE to USB hard drive enclosure. They do have multiple inputs like IDE/SATA to USB if you want.
Mar 09, 2012 | Seagate Medalist 4342 (ST34342A) 4.3 GB...
What is the Model of the original hard drive in the Model 5012 Desk top computerr?
This actually could vary quite a bit. Most computer manufacturer's will not place a specific model of hard drive into a computer now days, so long as it meets the same standards as the one they originally stock it with.
Your best bet, would be to open the side panel, by removing the small thumbscrews in the back (if they're not thumbscrews, then they're phillips head more than likely) then power down the computer, and disconnect the media cable , and power cable from the hard drive, then look on top of the har drive itself. IF the hard drive is missing, then only someone that of which has owned one could tell you one of the varying parts that are contained within it. Even xbox 360's for example, do not use the same brand, or model dvd drive, only the same speed, and connection type. Good luck, Dracconus
Jan 08, 2011 | Gateway GT5012 PC Desktop
Removed cruzer HD without ejecting, now it does not show up on the desk top, only U3 system shows up. i have an ibook G4, does not show in disk utility either. is there anything i can do to resolve...
try control panel administrive tools computer management device manager if you see a red x or yellow ? quetion mark you need to instal drivers for this device
to do this right click the select update driver
if you can see your usb but its not working
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Dec 11, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Double Image of my hard drive appears on desk top.
Greetings.
This sometimes happens with flash drive. Just to be sure, do back up and reformat the flash drive. Pls update if that solve the problem. if not we will try another solution.
Jan 24, 2009 | GTech G-Tech G-Drive Combo 500GB...
I have an asus eeepc and the windows startup window keeps going over and over without going to the desk top
boot loops usually indicate 1 of 2 thinks
- a corrupt or damage operation system
or
-a bad hard drive
unfortunately, i know these netbooks don't have a disc drive, but if you have access to an external one, see if you can get your hands on a hardware testing program like drive fitness test. if that passes, you know your operating system needs to be reinstalled.
Jan 16, 2009 | ASUS Eee PC 900 16G Notebook
My desk top hv no sound
ur motherboard has a disk containing the drivers needed for components like the vga card.. sound card (if integrated onto the motherboard), local area network (LAN) etc..to work.. this disk probably came along with ur computer.. unfortunately.. when you formatted th hard drive and reinstalled windows u got rid of all these drivers and they must be re-installed in order for these components to work..
if there is no disk present you can download drivers straight from the manufacturers website by typing in th make and model name of the sound card..or of the motherboard if p.c has a soundcard integrated onto the motherboard) into the address bar (the bar at the top normally..this begins with http://) you can find these details by going to start > all progs > system tools > system information > components > sound.. this will display the name and model etc of th card.. once on the manufacturers website there is usually a link for downloads to follow..
alternatively go to start > control panel > system > hardware > open "device manager" > once open look in the list for any yellow explanation marks anywhere..right click on any item showing this and delete..then restart the pc.. once it has restarted th pc will automatically detect new hardware and look for drivers.. often the best move now would be to rollback the drivers when given the option but this wont work after a disk format because th format clears th hard drive of everything..including updates and drivers so.. if you DO have a disk supplied with your pc carrying the required drivers (most new pc's will have this supplied with several other disks required to install software or applications...... this is far the easiest method of installing drivers
Nov 23, 2008 | Trust Ever 32bit 4-Channel PCI Sound Card...
I received Hp upgrades and now it has made my computer exceptionally noisy and has also rearranged my desk top icons
HP or your antivirus software's regard for its updates caused the updates to clear out your fan/power settings and that's fan noise. If the hard drive keeps going, you'd better find out what that junk is using Process Explorer (downloadable from Microsoft) and probably get rid of that thing. It's probably just running some virus scan once, and all that CPU and drive activityr is necessarily turning fans on, really.
Still, it's like they throw stuff in with some abandon because of people whose machines had no antivirus, and thus are spamming without the owners' knowledge. Hard to blame them, eh?
Jul 19, 2008 | HP Computers & Internet
Open Questions:
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
