Hotpoint aquarius wmf560 not spinning
Hi i have an hotpoint aquarius that was given to me was in storage for nearly two years as it wasnt what my friend wanted. It worked fine for 3 days then started flashing f-10 so my partner checked the hoses on the back the belt and filter and cleaned the pressure switch its now not spinning and flashing f-10 at the end of the cycle please help as ive chucked my old machine out wish i hadnt never had a hotpoint and feel that maybe i should have stuck to my guns many thanks
  • sherry elliott Dec 07, 2012
    thank you all so much we actually found a bit of plastic in the washer filter and removed it and would you believe it works i do not understand how a bit of plastic in the filter could do that
    stopped working again flashing f-10 at end of cycle and not spinning
murdozzz2
  • 75 Answers
SOURCE: Hotpoint Aquarius Extra washine machine. Won't start..
hi there the pcb behind the control panel is blown this is due to the carbons running low
Posted on Dec 10, 2007
clusterfx
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
rockfixya
  • 679 Answers
SOURCE: Hotpoint aquarius WF541 will not switch on
If the washer doesn’t operate or make any noise when set on any cycle, or if it stops suddenly when it should continue onto the next cycle, it may not be receiving electrical power, or, if the motor stopped mid-cycle, the machine’s overload protector may have tripped. In this case, take out some of the articles to reduce the load and let the protector reset itself. Then restart the machine. Otherwise:
1) Be sure the machine is plugged in and turned on. If necessary, check the receptacle it’s plugged into for power, using a working lamp, appliance, or voltage tester. Be sure the washer lid is closed completely.
2) If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit.
3) Unplug the washer, and check the power cord. If necessary, replace the cord.
4) Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch. If it doesn’t click when you do this, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call a repairperson.
5) If the washer still doesn’t work, the controls may be faulty. Call a service person.
Thanks for your question
Posted on Jan 03, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius wf325 filter problem, Blocked maybe?
You are correct as to the location of the filter.
Remove rear panel, locate large black hose at right lower side.
Remove securing clip and hose, inside you will see the plastic filter, remove and clean filter, note location of plastic ball.
Refit filter and hose, and securely fasten hose back on.
When you remove hose, watch out for water, as there will be some in the hose.
water test before fitting panel back on.
Plz rate my solution
Thanks.
Posted on Jan 08, 2009
barkencoa
  • 3463 Answers
SOURCE: Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Posted on Feb 09, 2010
Hotpoint Aquarius WMA58 (about 16 years old) is leaking, seemingly from under machine (back looks dry), and leaving clothes wet after spin cycle. Door seal seems sound.
no not worth repair at 16 years old
its got issues with aging worn motor
not spinning fast enough
door seal if you can buy one
may not be the water leak fix
time to replace the washing machine
Mar 06, 2017 | Hotpoint Washing Machines
My hotpoint aquarius wmf560 won't turn on no power since I moved it from my old house yesterday any ideas ???
sounds like a blown fuse or broken wire
cut back the wire by 6 inch and rewire plug replace with 13 amp good fuse
Dec 17, 2015 | Hotpoint Washing Machines
Hotpoint wmf560 aquarius washing machine
BIG JOB !!! The whole machine has to be stripped down. Ie/ The complete bowl assy has to be removed from the machine, the outer bowl separated from the inner bowl, the main seal removed, and the bearings pressed or knocked out of the housing in the rear of the outer tub. If the bearings have failed , it would be almost certain that the drum shaft has worn and or been damaged. You will need a set of bearings, drum spider shaft assy, and main seal. If its an older machine, it may not be worth it.
Apr 13, 2015 | Washing Machines
Hotpoint aquarius wmf560 flashing f10
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
Dec 07, 2012 | Hotpoint Washing Machines
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius banging about when spinning
hi take the top of the machine and check the brick at top or bottom of the machine they sometimes come lose .
Sep 30, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Very noisy when spinning
hi
it may be the belt making noise,,,check it,,,
thank u,,,//////please rate it
Jul 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
May 27, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WD440
Bad door latch or Control board is bad
Apr 28, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
