Question about Dell 1320c Laser Printer
What is BTR - Dell 1320c Laser Printer
Xerox 7345 009 343 error code
Check out the Xerox.com website for more upto date information.
.Good luck.
Oct 20, 2014 | Xerox WorkCenter Office Equipment &...
How do I Replace The BTR
Hi, the BTR don't need to be replaced (except in the fisical damage cases), just remove it, clean up it and reinstall the BTR.
Oct 22, 2010 | TallyGenicom 8026DN Laser Printer
Dell 3100cn
the BTR cover is also called " Bias Transfer Roller " cover it should be that roller that seen when open the front cover most likely the Bias transfer roller door sensor in NOT detecting the dorr closed. make sure the tab isn't broken this will produce this error if it is.
Jul 23, 2009 | Dell 3100cn Laser Printer
Error 9-358, Por favor si pueden enviar respuesta en español. Gracias
Problem seems to relate to the BTR Cam Sensor. The area around it might covered in toner and if so, you could try blowing out the sensor using air. Might also be due to a bad, dirty or full 2nd BTR assembly. Empty the waste from this. Do NOT hold the plate too far open otherwise it may lead to problems in the future. Clean it thoroughly before replacing it. It is also possible that the 2nd BTR cam might not be seated properly into its home position. Also, the clutch could be bad.
Jun 11, 2009 | Xerox DocuColor 12 Printer
Dell CLJ 5110
Pop the lens cover off of the transfer roller, clean all the toner debris out of there and replace the lens, put clear tabe on it, and you are good as new!
Oct 09, 2008 | Dell 5110cn Laser Printer
Telex BTR-500 Instruction Manual
I have a manual I can fax to you if you are interested. Email me your fax number, or e-mail address and I'll scan it. Send to: diann_sells_slah@yahoo.com.
Jul 26, 2008 | Telex Btr-500 set (71208000sp) Wireless...
Error code 009-349
The 1st BTR did not reach the retract position.
arrwup.gifInitial Action
  • Clean the 1st BTR Retract Sensor ( PL 5.4) and check for damage.
  • Check the 1st BTR Worm Gear and Retract Shaft ( PL 5.4) for breakage.
arrwup.gifProcedure
Apr 05, 2008 | Xerox DocuColor 3535 Copier
Error code 9-342 at start up / docucolor 12
That is a BTR contact failure. The Bias Transfer Roller is not making proper contact.
Most likely time for the BTR assembly to be replaced.
Apr 01, 2008 | Xerox DocuColor 12 Printer
Error Codes 9-343
That means , second BTR is not in contact with transfer belt. Open front door and pull out paper transport and check that is everything OK with black roll and her assembly.Check sensors for dirt,and gears for damage.If You have used one ,replace it.
Nov 10, 2007 | Xerox DocuColor 12 Printer
Dell 1320c Laser Printer Logo
41 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
