Question about Nintendo Wii Fit for Wii
Too many accounts on Wii Fit
I want to get on Wii Fit and all 8 accounts are filled with grand kids and locked. How do I remove one?
  • 15,935 Answers
Call your grandkids and get the password from them. If they dont remember it, you can call Nintendo customer service, and I believe they have a universal code which will unlock your Mii accounts on Wii Fit. The number is 1-800-255-3700. You will need the Serial # off the machine.
Alternately...
if you miss the password 3 times and it asks you if you are that Mii. You click yes and you have to confirm your height. Got into it and was able to delete.
Posted on Jan 12, 2009
How do i fit a new headlight bulb on 1995 jeep cherokee
Check this details, from the Repair Manual...
HEADLAMP BULB REMOVAL
(1) Lift hood to access lamps.
(2) Reach into engine compartment and locate lock ring supporting the headlamp bulb assembly.
(3) Rotate the lock ring 1/8 turn counterclockwise (Fig. 5).
(4) Pull the bulb (9004) straight out from the housing. This is a halogen bulb, take care not to touch it with your fingers.
(5) Replace by seating the assembly in the lamp housing and turning the lock ring 1/8 turn clockwise to secure.
Hope this helps.
Feb 27, 2013 | 1995 Jeep Grand Cherokee
My wii fit board willnot turn on
maby it's the batteries!
your guy for help,
ElijahCruz
Even kids can help :)
Jul 25, 2012 | Nintendo Wii Fit Plus with Balance Board...
How to connect wii fit board to the wii
Important Note!
Do Not use "One-Time Mode" sync.
Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off.
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.
7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Nov 16, 2011 | Nintendo Wii Fit for Wii
Cannot remove wii fit charater that is locked with a password, person not using it and has forgotten it completely what do i do
try this website.
http://wii.marcansoft.com/parental.psp
or please call 1-800-255-3700 for assistance.
Apr 26, 2010 | Nintendo Wii Fit for Wii
Wii fit plus, need to delete a locked profile. Bought a wii second hand and it has locked profiles in wii fit I would like to get rid of.
try reseting the nintendo wii to manufacture settings it should erase everything completely like new!
Apr 07, 2010 | Nintendo Wii Console
Where is the fill plug on the diffirential on a 1999 jeep grand cherokee laredo"
How to Fill a Rear Differential
You may need to add fluid to your differential due to leaks or changing seals, or it may be time to change out the gear oil completely. Either way, it's just a few steps to fill the rear differential and get your vehicle back out on the road!This article will explain how to fill a rear differential. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderate
Instructions and Things You'll Need:
  • 3/8 inch drive ratchet with extension
  • 2 quarts gear oil (gear lube, differential fluid)
  • Side cutters
  • Oil drain pan
  • Shop rags
  • Flashlight or shop light (optional)
  • Lock tight (optional)
Filling a Rear Differential
  1. Be sure the car is raised on four jack stands and is level. It will be more difficult to fill the differential if you've only got it raised in the rear.
  2. Place an oil drain pan underneath the plug to catch any leaks or drips. Keep shop rags handy for any spills.
  3. Check your service manual for the amount of fluid your differential needs, if you're completely refilling the system. Two quarts should be enough in most cases.
  4. Remove the spouts on the gear oil containers. Peel off seals, then replace spouts. Use side cutters (or any cutting tool you've got handy) to clip off the top of each spout.
  5. Remove the differential fill plug using a 3/8 inch drive ratchet with extension. (Some models may require a hex key or screwdriver, but the 3/8 inch is the most common plug design.)
  6. Take the gear oil container and fit the spout into the fill hole. Pour the fluid inside. You can gently squeeze the bottle to speed the process. Repeat with a second bottle if necessary.
  7. Fill the differential until the fluid starts draining back out of the hole.
  8. Clean and replace fill plug. Use lock tight (thread locker) to help seal if desired. You can see my eHow article "How to Replace Rear Differential Fill Plug" (video) for more information.
  9. Take the car for a drive around the block to get the gear oil moving. When you return, check underneath for any leaks from the fill plug or differential cover.
Hope help with this.
Mar 12, 2010 | Jeep Grand Cherokee Cars & Trucks
We are a college and have purchased a wii fit board for our students. Is there any way we can have more than 8 users by using a memory card etc. as obviously it is time consuming to keep setting it up for...
No. I believe that the software can only handle up to 8 despite the number of Mii's that you have on a system. Unfortunately, I think the best solution is three Wii consoles. You don't need a new balance board and software (unless you plan on more than one using it at the same time), but you will need to have three separate Wii systems.
Sorry about that. Good news is that the Wii console is getting easier to find than the fit. ;)
Feb 27, 2009 | Nintendo Wii Fit for Wii
Need to replace Miis in the Wii Fit
I want to delete my Mii;s in Wii Plaza and start from the scratch. How to do this?
Oct 27, 2008 | Nintendo Wii Console
Nintendo Wii Fit for Wii Logo
453 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
