Question about Toshiba DVR660 DVD Recorder/VCR
Have a Toshiba RDXV60KB. Will play some prerecorded vhs vids but not others. It's as is the tracking is out. Can I manually adjust the tracking or is it back to the repairers.
Bought this to both play older coveted Pre-recorded Videos and record to DVD old family videos.
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Many if the unit has a vol or channel buttons those will when in play become manual tracking adjustments, it depends if they are there or not.
Posted on Dec 07, 2012
SOURCE: Toshiba DVR recorder incorrect disk message
You could try the factory initializing process I found on another webesite (AVS Forums): "Had this message pop up a few weeks ago. Tried the solutions in the manual, no go. Tried unplugging it for 7 days, no go. Called Toshiba customer service @1-800-631-3811, the tech told me: 1) turn on TV and set to receive your DVD signal 2) Turn on DVD player and remove any discs 3) put Dvd / VCR selector on DVD 4) at the same time, push channel selector button UP (^) along with the PLAY button 5) hold the buttons down until TV screen shows "Initializing" message, release buttons, let DVD player go thru it's reset cycle and shut down 6) turn DVD player on and watch your DVD movies now Works like a charm. Put this in your manual for the next time." My unit has not worked since December of last year, I only had it for one year and it conveniently stopped working right after the one year warranty. My unit was not functioning whatsoever past turning it on, but when I did the factory initialization I was able to operate my unit again....UNFORTUNATELY, it still does not read disks, I still get the "Incorrect Disk" message. I guess I could consider it progress. But still try it, it may work for you. My unit just seems to be fried beyond repair. If anyone has any suggestions on how to correct the incorrect disk problem, I would be greatly appreciative. I'm not ready to throw mine away yet!
Posted on Sep 08, 2007
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
Posted on Oct 05, 2008
SOURCE: i have toshiba dvd recorder,the
Make sure you Finalize the disc when you are done recording, otherwise it won't be read on other players or computers. To do this you go to Setup> Disc and choose Finalize. It takes a few minutes per disc, don't turn off the player while it it finalizing. In the same Setup menu you can choose an option to autofinalize the disc when you are done recording, so you do not have to to it manually each time.
Posted on Dec 31, 2008
  • 6 Answers
SOURCE: recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Posted on Jan 27, 2009
SOURCE: recorded dvd's won't play on other dvd players Toshiba d-r410
You can play these recordings without finalizing them in the D-R410, but if you want them to play
in other DVD players, they need to be finalized. See pages 28 to 32 in manual. If you want to
finalize the disks you've already made, follow the directions on page 32.
Posted on Jun 07, 2009
What am I doing wrong? I have aligned all the gears on the deck mechanism but the left tension arm seems loose(WHEN LOADED MANUALLY WITHOUT A TAPE).It springs back a little but shouldn`t it be tight?
When dealing with VHS set up unless you have done the same model several times over, or have the service manual, you will never get it properly set up.
My advice is to get the manual, if you don't have one, and start again from scratch.
Jul 28, 2016 | Toshiba RDXV60KB DVD HDD VHS Recorder
VHS plays for 5 to 10 seconds then power switches off
I think you might have a problem with the VHS mechanism. Perhaps damage to the mechanical parts. If the mechanism can't perform the task it has been set after a very short period it will send a message to the electronics to shut down. This prevents further damage to the tape or system.
Jun 12, 2016 | Toshiba RDXV60KB DVD HDD VHS Recorder
My daughter pressed some buttons and now I can't get the guide on screen to use one time record
do a hard reset and if this does not work contact the manufacture or use the trouble shooting section of the manual
Dec 05, 2014 | Toshiba RDXV60KB DVD HDD VHS Recorder
How to fix my Toshiba DVR620's Poor VHS Quality?
The flying head is dirty. Open the unit and clean it with isopropylic alcohol or similar with a smooth cloth like the same used to glass clean.
Aug 29, 2014 | Toshiba DVR620 DVD Recorder/VCR
Toshiba V231 UK VHS manual is lost. Since last week I disconected and then replaced to my Toshiba TV. I can not Autotune it back to play VHS recvordings. I get sound but the tracking just flickers up the...
I believe you are using a RF wire Connecting a VHS, then searching TV station is an old way. I would recommend you use a RCA wire. By so doing, you won't need to tune any station on your TV. All you need to is select Source (AV) on the TV and the VHS would automatically display on your TV.
Below is what the RCA cord looks like:
The yellow stands for video (display), while the red and white stands for audio left and right (sound).
Purchase this cord from any electronics part store within your area, it's not expensive at all.
Look at the back of your TV, connect the yellow cord to "Video IN", connect the red and white to "Audio IN". Then connect the other end of the cord to Yellow: "Video OUT", and red or white to "Audio OUT", at the back of the VHS.
After the above connection, turn on the VHS, insert a tape, and press play. While the VHS is play, turn on the TV, select Source (AV) on your TV and your VHS will start displaying and you will hear sound.
I hope the above is clear. If you need further assistance, please let me know.
Regards.
Sep 20, 2011 | Toshiba Televison & Video
Can I enable my Toshiba RDXV60KB to play Region 1 dvds?
YES, IF YOU CAN REMOVE THE REGION LOCK IN THE DVD PLAYER. THIS CAN BE DONE ONLY BY A TOSHIBA AUTHORIZED TECH. AND THEY WILL NOT AUTHORIZED TO DO IT. THIS FUNCTION WILL BE PASSWORD PROTECTED.
REGARDS.
PLZ. DON'T FORGET TO RATE
Jul 05, 2011 | Toshiba Televison & Video
I HAVE A TOSHIBA VCR/DVD COMBINATION MACINE. THERE IS NO TRACKING BUTTON. iS THERE A WAY TO AUTOMATICALLY ADJUST THE TRACKING??
Usually VCRs do not offer specifically labelled tracking buttons as such, however they may incorporate tracking into their channel UP/DOWN buttons, both on the front of the main unit and/or remote. Some brands also offer V-LOCK (vertical lock or still image adjustment) (in pause mode during playback) to stabilise the image, reducing vertical jitter, which again can be adjusted as required using the same buttons as used for tracking. In most cases, pressing both CH UP and CH DOWN together while the tape is playing should centre track (revert back to auto tracking) the unit.
I am sure if your VCR has channel buttons on it, try pressing either one while a tape is playing. See if it affects the tracking at all. If it does, press both buttons together for 5 seconds or so, then release - auto/centre tracking takes over.
It costs nothing to try this, and it won't hurt your machine or your tapes.
Apr 20, 2011 | Toshiba W522 VHS VCR
My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Jan 02, 2010 | JVC DR-MV150B DVD Recorder/VCR
JVC DR-MV1S VHS Tracking
No manual tracking or if there is it wont help.either heads are worn or possibly dirty.if u open it .i assume u have.the silver drum has little notches around it.2 ,4,or 6 these are the heads.get some alchol or aftershave will do.take a peice of card playing card size is ok .must be plain not printed.apply some aftershave alchol to card not dripping ,hold card against the dum then with other hand turn the drum back and forwad not moving the card,u may damage heads.when u check card it should show some dirt reassemble and try.otherwise its museum time show the grandkids see if they know what a tape is
Jan 14, 2018 | JVC DR-MV1S DVD Recorder/VCR
Tapes not playing
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
Nov 14, 2007 | RCA VR634HF VHS VCR
Toshiba DVR660 DVD Recorder/VCR Logo
299 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
