Question about Motorola Walkie Talkie 2-Way Radio
We just bought motorola MR350R radios. hubby unwrapped the battery and stuck it into the charger. the light went for a minute or so, then went out. Has he blown the battery or the charger, or both. to compound the problem, we had to use an adapter as the points were american and we use a different system in NZ. is there any way to check?. what the problem is.?. we can use rechargeable batteries on the radios, but would prefer to use the correct charger if possible.
  • heathercr133
    heathercr133 Dec 09, 2012
    i have been able to charge the batteries using a usb port on my computer. it seems to be the charger
  • 4 Answers
What is the input voltage listed on the charger? It is probably on the large transformer that plugs into the wall. If it says 120-240v then you should have been able to use it. If it is only meant for 120v, then you have blown out the transformer and you need to purchase a 240 volt adapter. Tell me what it says and I can help you further.
Posted on Dec 14, 2012
  • heathercr133
    heathercr133 Dec 15, 2012
    yes it says 120V. i have an adapter plug, but it is not an adapter.. i would be pleased to receive any advice, as its going to be a pain without the chargers.
  • heathercr133
    thanks for the other 2 solutions. too. i couldnt see where to put the reply. will use rechargebles, but am trying not to buy in the US again as the postage is prohibitive.
3 Suggested Answers
Goofguyster
  • 379 Answers
SOURCE: motorola talkabout t5700
Or buy some AA batteries and the charger for them then charge them and put them in that should work to
Posted on Sep 14, 2009
SOURCE: How to charge battery in Motorola Talkabout Distance DPS
also got to battery barn.com and they have matching rechargable batteries with stand alone battert chargers that can be used AC or off the car 12vdc port. I have the same radios.
Posted on Aug 08, 2010
What are the more commom problems mr350r
Contact Motorola Solutions Support. They can tell you
portal motorolasolutions com
Mark
Motorola Mobility Support
Jun 19, 2014 | Motorola MR350R Two-Way Radios
My battery on the MR350R only last about two hours can i get a longer lasting battery for it
There is only one battery available for this style radio. Is it possible your battery is more than one year old, or had a poor initial charge? Either of these could result in poor talk time. Try using a known good battery in the radio, and see if the length of time differs. It could be as simple as replacing the battery.
The other thing that can effect talk time is the amount of time you spend talking (transmitting). If you are a heavy talker your radio will run down more quickly. The other thing would be special features such as having the Weather service turned on all the time, or voice activation turned on all the time. You might try shutting down any features you aren't actually using and see if that helps too.
Best regards.
Mar 18, 2014 | Motorola MR350R Two Way Radio
Not working
This radio may need to be replaced, but before doing so try the following:
Trade batteries with a known good unit and see if the problem moves to the other radio.
Check your buttons to see if one is partially depressed or stuck.
Check to see you do not have the radio set to VOX mode.
Shut off all special features and go back to a basic setting with the frequency and code matching your other units. If it does not communicate then, you have a radio which needs replaced.
Jan 22, 2014 | Motorola MR350R Two Way Radio
TALKABOUT BEEPING
Turn the radio off when it is on the charger. Also, check your batteries, you may have a bad battery pack. Try a battery from a known good radio to see if the radio functions correctly with a different battery.
Dec 25, 2013 | Motorola Talkabout Mr350r 2 Way Radio
Broken display screen for mr350r
Parts for this model were never made available from Motorola. You could try looking for a replacement, or parts radio on ebay.
Best regards.
Feb 07, 2013 | Motorola Talkabout Mr350r 2 Way Radio
My volume is lower then normal
VOLUME NEEDS CLEANED WITH ELECTRICAL SOLUTION
Jul 02, 2012 | Motorola MR350R Two Way Radio
Will the motorola mr350r work with the motorola cs1110
  • The mr350 is a standard GMRS/FRS talk around radio and the cls1110 is a business band radio but bot operate in UHF. So if the cls1110 is programed to one of the frequencies I will list then the two will communicate. Otherwise they will not.
Here are the frequencies listed in order of channels on your radio. 1-22.
Apr 30, 2011 | Motorola MR350R Two Way Radio
I lost the batterie cover (back side) of one talkabout MR350R. I woul like to know if I can buy it as part and where can I find it. Thanks, Antonio
Here is a link to the user guide http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf On page two, in the lower right corner there is a phone number and email address for assistance. They may be able to assist you in getting a new battery door.
Best regards.
Mar 02, 2011 | Motorola MR350R Two Way Radio
GP 360 Radio Charger
On a Motorola charger, when the battery is charging the light should be a constant red (or amber depending on the charger). When the charge cycle is complete the light will change to solid green. Sometimes the solid green time is brief, as the battery will begin to lose charge, and the charger will go back into trickle mode and change once again to red (or amber). In most cases, a flashing light indicates a problem, such as a bad or shorted battery, an incorrectly seated battery, dirty battery contacts, or a bad connection with the battery. (Note: Batteries last 18-24 months typically. Check your date code for the age of the battery.)
There were several chargers made for the GP360, including but not limited to a 60-minute charger, a 90-minute charger, a 10-hour trickle charger and a 6-unit gang charger which would be a rapid rate, either 60- or 90- minute. If you would supply your charger's model number we could tell you which one you have.
Nov 02, 2008 | Motorola HNN9628A Two-way Radio Battery
Radio Communications Logo
140 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
