Question about Garden
Quantum 35 xe
Does anyone know the armature gap for a Briggs ans Stratton quantum 35 xe lawn mower motor
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
tmandink
  • 30 Answers
SOURCE: What spark plug should be used for a Murray Quantum XNP 6.5hp mow
Home Depot has the plug you need for briggs 6.5hp engines. Don't worry about it being a Murray. Buy a Briggs 6.5hp plug.
nobby63
  • 10 Answers
SOURCE: lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
Posted on Jul 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
mikehowy
  • 177 Answers
SOURCE: I would like a user manual for a Champion R484TR lawn mower.
google
Posted on Jun 07, 2010
How to adjustment static governor on a quantum xe 40 briggs and Stratton lawnmower please thanks Robin
1. Move throttle control to wide open throttle position,
Fig. 45.
2. Loosen lever adjusting screw. Item 8
3. Turn governor crank counterclockwise and hold.
4. Torque lever adjusting screw to 15 in. lbs. (2 Nm.).
Mar 31, 2015 | Garden
Manual for briggs and stratton 12000 series mowers quantum
B/S makes the motors for several brands of mowers. Go to the web site and search your model for a download.
Oct 07, 2014 | Briggs & Stratton Quantum Lawn Mower...
Repairing a Briggs and Stratton Quantum 35 mower engine. How do you replace the metal starter pawls in an older Briggs & Stratton mower engine
take cap off drive the pin out the bottom from the top replace starter pawls and springs put back to gether drive the pin back in checking making sure not to thight if it is drive pin back some until it spins freely
Aug 22, 2014 | Garden
What is the correct gap setting for a Champion RJ2YLE spark plug used in a Toro Lawn mower?
Briggs & Stratton Part Number 799876 replaces Champion plug RJ2YLE. For use in Quantum Series 625, 675, and 725 engines built after Date Code 110701xx. The gap for this spark plug should be set to .020". This spark plug should not be used with Quantum Series 625, 675, and 725 engines built before Date Code 110701xx, or any other L-head engine family.
Apr 20, 2013 | Toro Garden
I am replacing the spark plug on a 5 hp Quantum engine that is on a Troy Bilt walk behind mower. I would like to know the spark plug gap setting on that motor.
I'm guessing you have a standard Champion J19LM plug, which has a gap of .030. They come pre-gapped from the mfg. and usually no need to adjust them. Most of the plugs on these engines have a .030 gap. There are very few exceptions that use a .020 gap (such as the RC12YC). Anyway, here's a link to a chart I like to use for reference: (there's a drop down menu at the top to change engines, but the standard Briggs engine is the one here).
http://www.manddsmallengine.com/briggs/info/plug7.html
Hope this helps. James
Aug 06, 2011 | Briggs & Stratton Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
