Question about NEC PABX SL1000
How to assign trunk lines on NEC SL1000 Keyphone System?
There are already incomming lines assigned to the Function Keys 1-9. However I need to re-arrange them differently. So how do I go about reassigning the Trunk Lines on these function keys? Thank you very much for your help.
  • Chandru Dec 10, 2012
    Basically, there are a total of 9 incoming/outgoing fixed LAN Lines assigned to the first 9 Function Keys. However, we have terminated 2 lines with our service providers. So now the first 9 Function Keys have gaps in them wtih lines not working. So I require to re-shuffle them. How do I re-assign the trunk lines/lan lines to the function keys again by re-ordering them? I hope this clarifies the issue. Anything else please ask me. I need to know how to do this soon. I am also away Admin level programming requires password. I have them at hand.
  • Chandru Dec 15, 2012
    Solution Not Helpful. Asking me to sign up to another website to post problem there.
    Sergeant:
  • 109 Answers
Download manual from: https://www.manualslib.com/manual/832824/Nec-Sl1000.html?page=531
and follow the instructions in your appropriate section.
Posted on May 23, 2017
    Scholar:
  • 277 Answers
Try posting here:
http://www.tek-tips.com/threadminder.cfm?pid=937&page=1
Posted on Dec 13, 2012
Line not assigned
make sure that your service provider has installed 3 individual lines into the building
check that the 3 incoming lines are not all together in the plug at the wall
you may need a telephone technician to check it out
Feb 17, 2016 | Panasonic Kx-tda100 Kx-tda100 Digital...
HOW COULD I RESET THE NEC SL100 PBX SYSTEM?
System Reset on Page No. 2-509 of the manual:
Dial 1 + press HOLD (Press Hold key only to cancel)
Jul 04, 2013 | NEC PABX SL1000
Factory reset sl1000
Feb 16, 2013 | NEC PABX SL1000
NEC DTU 16D 1A not ringing
Your PABX line settings need to be programmed for "ringing" as incoming call notification for each specific assigned number (wired port assignment).
Jun 08, 2012 | NEC DTU-16D-1 Display Telephone
Trunk lines r getting hangup always and i'm reseting the system always
Check your firmware on the system.
which kind of phone do you have connected to the stytem, are these all digital phones?, like the ones on your profile picture. do you have programming software for the system. I will then be able to give you some steps to follow for the trunk access mapping and key assignment to the phones.
Jun 01, 2012 | NEC PABX SL1000
I want all incoming calls to come through my extension only.
What it sounds like you want to do is restrict the automatic system answering to certain extensions. This is done via feature code 204.
To identify the lines on which outside calls should be answered by the system:
  1. Press feature +(00)+(system program)+(system program)+#204
  2. Enter the two-digit system line number of the desired line.
  3. To assign or unassign the line, press (Next Data) until the appropriate value appears.
    1 = Assigned
    2 = Not Assigned (the factory setting)
  4. To identify another line, press (next item)or (prev. item) until the line number appears on the display. Then repeat Step 3.
  5. Repeat Steps 3 and 4 for all the lines that you want to identify.
  6. Select another procedure, or exit programming mode.
Aug 31, 2009 | Lucent PARTNER18 Corded Phone
Choosing which lines ring.
If you have a multi line setup, you have a phone router. Have your phone company come in and program it for you.
Feb 17, 2009 | Toshiba DKT-2020 Corded Phone
Automated Attendant not on everyone line
The below texts should help you.
**Found on page 9-8 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
Use Line Assignment (#301) to assign all the lines that you want the auto attendant to cover
to extension X.
**Found on page 4-47 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
To assign lines to a specific extension:
1. Press [Feature] [0] [0] [System Program] [System Program] [#] [3] [0] [1] at extension 10 or 11.
2. Enter the extension number to be programmed. For example, to program extension 15, press [1] [5]. The red light next to each button that has a line assigned is on steady; the red light next
to each button that has a pool assigned flashes.
3. To remove all existing line assignments, press [Remove] before selecting a line.
4. Enter the line number to be assigned. For example, to select line 1, press [0] [1].
5. Do one of the following:
■ If you want to assign the line to the first available button with lights, press [Next Data] until the
display reads:
Line Assignment 15 L01
1 Assigned
1 Assigned is the factory setting.
■ If you want to remove a line assignment, press [Next Data] until a display like the following
appears:
2 Not Assigned
■ If you want to assign the line to a specific button, press 3. A display like the following
appears:
3 Select a Button
Then press a button with lights to assign the line to that button. If you use option 3 after a
line already has been assigned, the line moves from the old button to the new button you
select.
6. Do one of the following:
■ To program another line for this extension, press [Next Item] or [Prev Item] until the line number
appears on the display. Then repeat Step 5.
■ To program another extension, press N P and begin at Step 2.
7. Select another procedure, or exit programming mode.
Feb 05, 2009 | Avaya Corded Phone avaparp18d
NEC PABX SL1000 Logo
477 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
