Motor trying to spin but drum seems jamed
Motor nd belt turning but drum will not
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 07, 2012
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
  • 51 Answers
SOURCE: Indesit WA105 - drum is loose and fails to spin
Hi Jezzer69 It is repairable but will take about 3 -4 hours (if you know what your doing) and the parts will cost about 65% of what a new machine will cost. You need to weigh up how old the machine is and or if its "beyond economical repair" Regards
Posted on Jul 24, 2007
  • 38 Answers
SOURCE: Zanussi IZ12 Washer won't spin.
check the motor carbons they r mounted on either side of the armiture you will find they r held on the motor with 2 screws or 2 5.5mm nuts make sure you unplug the machine before u start working on it good luck
  • 20 Answers
SOURCE: Maytag washer won't Spin freely
You have a worn brake
Posted on Feb 10, 2009
Maytag317
  • 1136 Answers
SOURCE: The drum on my maytag epic z washer will not spin.
Hi, The belt must have came off. Remove the access panel in the front and see if the belt broke. If the belt is off, see if there is an access panel in the rear that will help you get to the belt easier.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 04, 2009
Why dryer won't tumble?
The belt could be worn and stretched.
Jul 20, 2014 | Maytag MDG2706A Gas Dryer
Washing mahine stops after one minute
put it on the spin cycle and open the filter if it's the belt you will surely hear the motor spinning if not then it's not the belt
Feb 10, 2014 | AEG Lavamat 72640 Front Load Washer
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
The drum does not spin, the blower works, the gas will fire up, belts look to be in tact but may be loose?
Most gas dryers have a tensioner on the drive belt under the drum a metal bar with a teflon pully that is spring loaded to tension the belt. Try spining the drum by hand if it spins freely the belt may have come off the tensioner or it may be streched. If it doesn't turn the drum rollers or bushing may be bad. Without a make and moddel # it's hard to say
Hope this helps
Please leave feedback
Dec 04, 2009 | Dishwashers
Front loader washer machine not rotating.
Fisrt, see if you can rotate it by hand, BOTH directions. It should have some resistance. If you can spin it and when you stop pushing it will turn a full turn, your drum belt is too loose. If the belt is good and tight, it will spin less than one half rotation, there is probably something blocking one of the wheels that the drum rides on.
Nov 16, 2009 | Frigidaire GLTF2940ES Front Load Washer
My kenmore dryer's drum does not spins. I checked for the belt and it's fine. Where do you suggest I check?
the drive motor if its not turning then the drum wont turn, also if its sliped the belt off thats another reson why and one more thing to look at is how tight is the belt on the drum,,, is it just sliping round it? is the drum very tight to turn by hand? are the drum bearings jamed up, is any thing stuck behind the drum? ??? like one of the kid's?
i hope this is helpfull to you
Oct 23, 2009 | Kenmore 63942 Dryer
My LG dryer does not spin...everything gets hot and works except either it spins VERy slowly or not at all
Open the back to get to the motor and check to see if the belt is loose on the motor pulley. Try to turn the empty drum by hand--does it seem bound up? Turn the motor pulley, does it seem hard to turn? Maybe the motor pulley is loose on the motor shaft. Run the dryer for a short time to watch the action of the drive belt.
Sep 27, 2009 | LG DLE0332 Gas Dryer
Replaced broken washer belt, but drum still won't spin.
you may have a bad bearing in a pulley,could be motor coupling. Take belt off and spin motor shaft and pulley both ways if it's free, then its more than likely not the motor. Now spin the drum with belt off and see if it does the same as with the belt on if it does it has to be a bad bearing or coupling to the drum. hope this helps
Aug 24, 2009 | Amana ALW480DA Top Load Washer
Drum not turning
If you are certain that the motor was turning, then the only things that come to mind are that:
  1. The belt is stretched or worn-Replace as there is no adjustment.
  2. The drum is stalled, either because it has seized, or there is something stuck in the drum.
  3. The motor brushes are worn, and will not cope with load of drum, check brushes.
Try running it on fast spin without the belt on , if it spins o/k, then that would indicate the motor is o/k.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
