Want to change Linux Fedora 17 ip from 10.42.x.x to other range
I'm using fedora 17 and I have configured my WAN connection to DHCP and my LAN connection to 'shared to other computers'. It's work. However, I need my ip addresses on the clients to be 192.168.x.x range. I want to change the 10.42.0.x subnet. Is there anyway i can configure network manager to give out addresses on the 192.168.x.x subnet?
  • 2,878 Answers
Yes, the router dictates the IP and range. So if you have modem for your ISP connection. Just attach a router.
Example of my Belkin.
Want to change Linux Fedora 17 ip from 10.42.x.x t - 12_7_2012_4_11_46_pm.jpg
Posted on Dec 07, 2012
2 Suggested Answers
Sutibun
  • 186 Answers
SOURCE: Dual Router Configuration
Plug the second router into the lan not the wan and it will act as a switch instead of a router
Posted on Oct 02, 2008
Can the management IP address of an ONT be configured?
ONT management IP addresses are classified as LAN-side management IP addresses and WAN-side IP addresses.
· The LAN-side management IP address can be configured. To do so, choose LAN > LAN Host Configuration from the main menu on the web page.
· The WAN-side management IP address is based on WAN port configurations.
§ If the WAN port statically obtains an IP address, the WAN-side management IP address can be configured. Ensure that the configured management IP address can communicate with the upper-layer device.
§ If the WAN port obtains an IP address in DHCP or PPPoE mode, the WAN-side management IP address can only be obtained from the DHCP server.
May 16, 2016 | Computers & Internet
Looking for drivers to use this monitor with Fedora 20 Linux OS
You don't need drivers. You need to adjust the resolution and refresh rate. If you plug in an old CRT monitor then Linux will probably boot and you can edit the conf file to change the settings. Most LCD monitors require 50-60Hz refresh rate.
May 05, 2014 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
CAN'T CONNECT TO INTERNET
Check that you network card is installed or not if not then install .
after installing you need to configure it ip address which is provided by you ISP provider that's it. please let me know if you are facing any issues..
Apr 15, 2013 | fedora Linux Operating System
How to configure router & switch
You shouldn't have to configure anything except the PC's should have IP and gateway set to auto.
Here is how it works:
A router connects two separate networks and manage the traffic between them.
In most home network applications the router connects your local group of computers and devices known as the LAN with the Internet, commonly called the WAN or Wide Area Network.
The router usually assigns unique Local IP addresses to all of the devices connected to it via a service known as DHCP. The addresses assigned by your router are private addresses http://en.wikipedia.org/wiki/Private_net... and are not routable across the Internet.
Dynamic Host Configuration Protocol (DHCP) is an auto configuration protocol used on IP networks. Computers that are connected to IP networks must be configured before they can communicate with other computers on the network. DHCP allows a computer to be configured automatically, eliminating the need for intervention by a network administrator. It also provides a central database for keeping track of computers that have been connected to the network. This prevents two computers from accidentally being configured with the same IP address. http://en.wikipedia.org/wiki/Dynamic_Hos...
Your cable or DSL modem will get a Public WAN IP address from your ISP's DHCP service. These public IP addresses are leased in blocks by your ISP and are Internet routeble. The modem is connected to the WAN port on your router. The router will manage the traffic between the devices on the LAN and the Internet.
If your 5 port switch is connected to one of the router's LAN ports and router's DHCP is on then it will configure the clients attached to It automatically.
Feb 04, 2013 | Computers & Internet
How do I playback commercial DVD's on fedora 17
First find out that DVD format i think it may be in flash or shockwave thats why you cant able to detect that
Jul 17, 2012 | fedora Linux Operating System
I have a unstable linksys WAG200G what can I do
Converting A Router To A Switch The five steps are:
  1. [Optional] Put a piece of electric tape over the WAN port so it doesn't get used.
  2. Disable the DHCP server.
  3. Change the downstream router's LAN IP.
  4. [Optional] Turn off the wireless radio on the downstream router.
  5. Connect an Ethernet cable from a LAN port on the upstream router to a LAN port on the downstream router.
Step 1: Putting a piece of electric tape over the WAN port isn't necessary. But it is a good way to prevent future problems caused by someone plugging a device into that port.
Step 2: Log into the downstream router, look for the DHCP configuration section, and disable the DHCP server. For example, on a Dlink DI-614+, DHCP server configuration is a menu in the Home configuration section.
Step 3: Change the downstream router's LAN IP to an unused IP in the same subnet as the upstream router. Log into the upstream router and find the DHCP server controls. Figure 3 shows a typical set of DHCP server controls. You can see that 192.168.3.200 - 250 is the range of addresses that will be issued by this router's DHCP server.
You can use any IP address outside (above or below) this range, except for 0 and 255, which are reserved. You also can't use the IP address used by the upstream router. This is usually 1, which in this case is 192.168.3.1. But if you log into your upstream router's admin screens using an IP address with anything other than 1 as the last octet, i.e. XXX.XXX.XXX.1, then just don't use that address.
Thus, a safe LAN IP address for the downstream router that isn't used by the upstream router is an address from 192.168.3.2 to 192.168.3.199. So I assigned my downstream router a LAN IP of 192.168.3.3 (Figure 4).
Step 4: [Wireless routers only] Disable the downstream router's wireless function. It doesn't hurt to unscrew the antennas from the downstream router as well if they are detachable. This gets them out of the way since you aren't using them anymore. Figure 5 shows the wireless disabled for a D-Link DGL-4300.
Step 5: Connect the downstream router. Run an Ethernet cable from a LAN port on the upstream router to a LAN port on the downstream router. The LAN ports are the ports that often grouped together and not labeled as WAN or Internet.
If you need more help post back!
Thumbs and testimonial are welcome!
Feb 23, 2011 | Linksys WAG200G Router
ADSL ISP provides same address for IP and Gateway
Can you manually change the WAN IP on the router?  If so, give it an IP like 123.12.167.5 and set the gateway address to 123.12.167.1.  If it asks for a subnet mask, give it 255.255.255.0.
If she has a Linksys router, you may need to change the operating "MODE" on it.  A lot of Linksys routers have 2 modes of operation---Router mode and Gateway mode.  For her configuration, make sure the Linksys is in Gateway mode.  This will fix the NAT problem.
Cheers!
Mar 26, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Oct 02, 2008 | D-Link DGL-4100 Router (DGL4100)
DI-524 Wireless
Yes you can, it's easy.
1. Just connect one of the LAN ports of the DI-524 to a LAN port of your other router. Leave the DI-524 WAN port empty.
2. Disable the DHCP server on your DI-524, your other router will be the DHCP server.
3. Assign a static IP address to you DI-524, different from your other router's. Example, if your other router has 192.168.2.1, you may assign 192.168.2.4. Make sure that the IP address you assign is outside the DHCP range configured in your other router and that the subnet mask is identical on both.
Feb 20, 2008 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
