Grundig ST-80-896 eht replaced but still arcing
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
It is arcing where---at the anode connection on the bell of the picture tube? If there and the transformer has been replaced it burned a carbon path that you should be able to see.
Posted on Dec 07, 2012
  • Michael Ellul Dec 08, 2012
    The arcing was from transformer ferrite to adjacent componenets and even from transformer plastic moulding.Problem traced to bad high tension lead inserted in transformer.Removed ,cut a fresh piece and reinserted.
  • SD Tech
    SD Tech Dec 08, 2012
    If that worked you are lucky---many of the transformers (We call them Flybacks) the wire is permanently attached.
Videocon challenger
Sounds like EHT cap arcing occurs. Contact any service technician. This is a repairable fault, by replacing the rubber boot of the EHT cord.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 24, 2014 | Televison & Video
Hello, I need the code for a telivision GRUNDIG ST
These are the codes to check with Grundig.
1141 1427 1154
1144 1125 1035
1450 1491 1148
If you wish to get more, http://electrohelponline.blogspot.com/
Aug 25, 2013 | Televison & Video
JVC flatscreen tv model Number AV-21mt35 with vertical interference? how to solve this problem?
It will be best to replace its Line Output Transformer [LOT]. It is not good to join the broken EHT wire. EHT arcing cannot be stopped by using glue.
Apr 04, 2013 | JVC AV-27720 27" TV
Tickling noice of tv
EHT arcing occurs inside your TV. It must be from its Line Output transformer, otherwise called as LOT in short. It might have to be replaced.
Jul 21, 2012 | Sanyo Televison & Video
Eht lead of my tv is spiking (arcing) to the tube
Hi, which end of the lead, is it the eht transformer or the anode end that plugs into the tube. I may have a hole in the lead somewhere and the voltage is arcing to the tube.
Check this and if it is the case then you will need to buy a new lead.. or try a load of installation tape.
BUT PLEASE BE CAREFULL, THERE IS EXTREMLY HIGH VOLTAGES IN THERE IN THE KV RANGE.
SO UNLESS YOU KNOW WHAT YOU ARE DOING , TAKE IT TO A SHOP.
I WILL NOT BE HELD RESPONSIBLE, IF YOU KILL YOURSELF.
If I have help then please rate me.
GOOD LUCK.
Regards - Anthony
Feb 09, 2010 | Televison & Video
My SONY tv KV-XF21M80 produces a continuous sparking sound
The tech is very likely correct. The EHT or flyback transformer can develop hairline cracks that allow leakage of high voltage that exists in this circuit. There are other related components that can also cause this, but the transformer is the most likely. This area in the set also builds up allot of dust also due to the high voltages and this aggravates the issue. I do not recommend operating the set very long this way as it may begin arcing inside and cause more components to fail. Replacing the part would depend on how much you want to invest in the unit. Get an estimate and go from there. Good luck.
Nov 25, 2009 | Sony Televison & Video
SET THE VOLUME CONTROL
i tried doing research on your tv model but can't locate it. try this site www.grundig.co.uk
Jun 16, 2009 | Televison & Video
Eeproms sda2546/3526 changed,tv grundig cuc5312 not swiched on
i think the problem is with the memory chip (sda2546). you replace it with a same one? If yes i believe is "empty". you must programming the chip. you can order a sda2546 with the programm in it. Plus you can replace the sda2546 with the 24c08 memory chip.
the "egejcka makedonija" repair man
Mar 19, 2009 | Televison & Video
Repairing Grundig Radio receiver Satellit 3400
GRUNDIG SATELLIT ST 1400 SL
Diodo Zener ST601 Volt ?? (SU ALIMENTAZIONE)
HELP Simon
Feb 27, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
