Question about Canon PIXMA MP150 All-In-One InkJet Printer
Error E3 I know this means paper jam, however i have unjammed all paper, reloaded new paper and turned the printer on and off and the error still exists.. help?
E5 flashing in the button
Posted on Jan 13, 2009
Error 3 indicated - what is it and how do I fix it
E3 means that there is a paper jam. If you are getting the E3 error and there is not an actual paper jam you may need to do is simulate a paper jam. Try inserting paper crooked to cause a jam so that when it starts trying to feed the paper through it gets jammed. Then lift the cover up and take the paper out. You'll then get a bunch of the lights flashing. Turn the printer off and then back on and you should be good to go.
Mar 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
When i print any photo it can't print error show E3
hi, look at this post maybe can solved your problem not all Error E3 means your printer part damage but maybe somethings inside it that makes the printer look likes paper jam,
Canon MP198 Printer Error E3 is because something inside of the printer that makes paper sensor not function properly. To fix this error E3 you must open inside of the printer to remove the things.
Look at the paper sensor there is must be somethings in it. I found this when my printer Canon MP198 got error E3. I found small part of paper in the sensor that makes sensor not function properly. I just remove the paper and the printer working again.
see also
http://slayo.com/how-to-fix-error-e3-canon-mp198-printer.html
Nov 18, 2010 | Canon Office Equipment & Supplies
What Does E3 mean
E 3 means "Paper Jam". If there is no actual paper jam, but the error cod E3 is still there, it might be that something has fallen into the printer, or a piece of paper has been jammed in there. First, remove the cartridges, and turn the printer upside down and gently shake it to see if anything comes out. If nothing goes, or you can't hear anything, what you need to do is simulate a paper jam (it thinks there is one, so give it one!). Just shove a paper (120g or heavier) inside the printer (after lifting the hood up) so that a real paper jam would occur. When it starts trying to feed the paper through and its getting jammed lift the cover up and take the paper gently out. You'll then get a bunch of the lights flashing. Turn the printer off and then back on and you should be good to go.
Apr 06, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
I get the E 3 error message which I understand means paper jam. There is no paper jammed in the printer. I unplugged it and replugged it and it sill shows the E 3 message.
E3 error mean if printer has jammed in the machine.Clear paper jam,or paper feed sensor was displaced.clear or check paper sensor then solve your problem.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
The printer is not feeding paper but still gives the E3 error message
If paper has jammed in the machine,clear the jam reload the paper in the machine correctly and then press black or color key.If you are not success so it is problem mechanical.Service it and solve your problem.
Nov 24, 2009 | Canon PIXMA MP160 All-In-One InkJet...
AM GETTING ERROR CODE E3. CAN YOU PLEASE TELL ME WHAT THAT MEANS? THANK YOU.
if paper jammed in the machine,clear the jam reload the paper in the machine correctly and then press black or color printkey
Nov 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Getting code E3. What does this mean?
error E3 means Paper jam ..try to clean any paper inside...
May 06, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer Error E3
E3 error -
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press [Black] or [Color].
The above is direct from the user manual.
If there is no paper jam - look for any small pieces of paper that could be located near the roller sensor.
Oct 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
100 people viewed this question
old marine
old marine
