Question about Sony WEGA KLV-21SG2 21 in. HDTV-Ready LCD Television
I just bought an apple TV to go along with my Sony WEGA KLV-21SG2 21 and the only thing missing from the Apple TV box supposedly is the HDMI cable. However, it seems that i need some kind of an adapter for the cable in order for the system to work. Does anyone have an answer for this?
circuitcity
  • 137 Answers
SOURCE: HDMI and other outputs doent work
You may want to try a Manufacture reset. To do this you must first turn the TV off. Press in sequence.. Display-->5-->Vol +-->power on your remote(this sequence must be done fast). This should bring up a service menu. Press the number 8 and then Enter on you remote, The set should go off and on by itself. Now go through your setup and try the input again.
Best regards
Circuitcity
Posted on Dec 10, 2007
HDTV GURU
  • 261 Answers
SOURCE: Sony Bravia KDL52XBR5 picture blanks out using HDMI port
I think this has to do with the cable box not liking the encryption thing going on with the sony tv. The cable boxes probably don't understand it fully and therefore you have intermittant problems. I would just use component inputs. Which are analog and no encryption problems. I hope this was helpful. I bet it doesn't happen using a sony DVD Player or a blue ray DVD Player either. Sony, Sony, Sony.....Good stuff...but they have their moments. Let me know if u come up with a fix for this and then i will post it on my fix it list.. Thank you again..GURU JAY
Posted on Feb 08, 2008
oakwoodman
  • 36 Answers
SOURCE: Apple TV and Sony KE32TS2 Plasma TV
That's weird... I just looked at the back of my set Sony KE-32TS2U and it has a DVI port.
Posted on Sep 16, 2008
mjjdesigns
  • 98 Answers
SOURCE: sony bravia klv-32t400a hdmi input through x-box
The problem is that, according to the specs for that TV, it doesn't support 1080p.
That's a 720p television you've got. (Specs here)
While the specs say that it supports 1080p, the resolution says it supports 1366 x 768, which is only 720p, not 1080p or even 1080i.
You may want to contact Sony for clarification, because their specs for that tv are contradicting each other.
Posted on Mar 19, 2009
  • 1768 Answers
SOURCE: sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Posted on Feb 05, 2010
Can I pair my iPad to Samsung smart tv to watch movies from showbox
No, Apple don't believe in sharing with any other devices that arn't other apple products.
In order to do as you ask, apple require that you make an additional purchase from them. The apple TV box:
apple tv box Google Search
This is one of the many things that make Apple S**t.
The good news is you can do this from an android or a PC via a HDMI Cable
May 09, 2016 | Samsung Tablets & eReaders
I have a Sony bluray surround sound and lg smart tv, I can't play my Apple TV sound through my hts, all my connections are hdmi and both systems have arc, please help?
Is your Apple TV connected to the Sony or directly to your TV? If directly connected to the Sony HTS ARC shouldn't be needed and you should have audio. If that's the case check the Apple TV settings to be sure it isn't set for s/pdif output. If connected to the TV then the TV should be able to put a s/pdif signal on the HDMI ARC pin but perhaps there's no way to assign it to the HDMI input coming from the HTS? It may be going to the ARC pin on the Apple TV HDMI input which won't give you any sound. Normally ARC is intended to put the s/pdif signal from the TV's internal tuner on the HDMI cable from the HTS so the HTS can play TV sound without having to tun a separate Toslink cable from the TV s/pdif output to the HTS. One other thing: Early HDMI cables do not include the ARC wire so be sure you have ARC capable cables. Look in your TV documentation to see if there is a way to assign the ARC output to a different incoming HDMI input if the Apple TV is connected directly to the TV. If not you may need to resort to a Toslink optical cable from your TV to an optical input on your HTS. Or actually running that cable from Apple TV to the HTS would be better since it's possible it could carry surround sound. Most TV's optical outputs are limited to the 2 channel sound the TV can accept.
Oct 22, 2014 | Audio Players & Recorders
Bravura not recognizing an Apple TV signal
You need to connect using an hdmi cable from the appletv to the tv, and notice which hdmi socket on the tv you use (eg 1 or 2 or 3...) Then make sure the light is on green on your apple tv by using the supplied remote control to power it up. And then you need to make sure you have chosen the correct hdmi source on your tv remote control (eg hdmi1 or 2 or 3...).
Sep 16, 2014 | Televison & Video
Trying to connect older sony wega flat panel to Apple TV?
No HDMI? There are conversion boxes out there to take an HDMI image and convert to RGB Component Cables, You will need to run the audio out seperate using TOS Link (Fiber optic) to your receiver.
Apr 02, 2014 | Televison & Video
TV doesn't recognize HDMI with Roku
The Roku is the problem, not the TV. You need to go to the Roku site and request download information to synch the Roku to an HDMI input.
Jan 13, 2013 | Sony KLV-S32A10 32 in. HD-Ready LCD...
I would like to connect my my hp laptop to my Sony Grand WEGA KDP-57WS550 57 in. Rear Projection HDTV-Ready Television to watch netflix
You need to connect your PC to either your TV or your receiver. Also, if you have XBox, you can watch Netflix through it (thought I'd suggest, just in case).
Take your PC (or take a photo of your available outputs from your PC) and a photo of your available inputs (on your TV or receiver) to Best Buy or similar computer store. They can help you learn which connections you need.
Most likely you'll need a DVI to HDMI cable for video, and maybe a separate audio cable from your headphone connection on your PC to your TV (or receiver). You'll only need a separate cable for audio if your HDMI input on your TV does not support audio.
I am going through this same problem with my TV connecting Apple TV. I am checking now whether my old rear projection tv's HDMI input supports audio (same as yours). I've connected Apple TV to my rear projection TV. I have video, but no sound. Either my TV doesn't support HDMI audio, or I need to change a setting on the TV to enable that sound to work. If the TV does not support HDMI audio, I will need to connect Apple TV directly to my receiver via a digital optical cable for sound.
Hope this helps.
Jun 22, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
Could I hook up Apple TV with this tv?
Read the Apple Tv box owner manual can it be hook up wih RCA component R,Y,W cables,than yes.This tv is an analog tv only can be functions buy component cables not anything else will able to hook up with analog tv to get a video picture.
Dec 19, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
BRAVIA KLV-37U300A 37 in. LCD TV: I have a HDMI cable attached to my Sony Bravia and...
t con is not working is t con is repairbale or can i get ic becouse here in pakistan is not available.
May 17, 2010 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
Sony PCM 48 Issue
As long as you continue to have both HDMI and optical outputs connected at same time from the cable box, it will probably always choose the default as HDMI. If you do not want to change any connections then the best thing to do in this case is to always leave the cable box turned on. Otherwise, disconnect the HDMI and connect it to the TV by component video.
Jun 17, 2009 | Sony STR-DE698 Receiver
Nov 18, 2007 | Sony WEGA KE-32TS2 32 in. HD-Ready Plasma...
Sony WEGA KLV-21SG2 21 in. HDTV-Ready LCD Television Logo
50 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
