Question about Samsung SCX4623F Laser All-in-One Printer
Samsung ml-1866 red color led blink
Samsung ml-1866 toner reset firmware
    New Friend:
    Problem Solver:
  • 9 Answers
Call 9448311575 bangalore
Posted on Apr 27, 2013
flopez
  • 161 Answers
SOURCE: Blinking Red ! lite
Good news solution: your toner cartridge is empty beyond any more shaking.
Bad news solution: if the toner is new AND original, the blinking light means bad fuser. It needs replacement at any Authorized Service Center.
Posted on Nov 02, 2007
xptareq2000
  • 1447 Answers
SOURCE: Samsung ML-1710p - error
It is problem your fussier unite may be thermostat or or lamp is fuse.If you are not a technician you go to a service center.Or you are a technician open it and clean thermostat and heater lamp check by ammo miter.
Posted on Nov 27, 2009
xptareq2000
  • 1447 Answers
SOURCE: Samsung ML-1710p - when attempt to print, leds
May be rejected this toner unite or paper could not feed properly.Service thoroughly your printer and Fuser unite.
Posted on Jan 07, 2010
rulds2008
  • 3866 Answers
SOURCE: New Samsung toner cart reads LOW
This is due to a sensor that reads the actual cartridge is defective not the actual cartridge or the cartridge is one that was refilled and thus not put back togeather the way it should have been. So its ether or a refilled cartridge or a bad sensor. Both req. repair in some sort.
Thanks for your free question, your free answer was delivered please do rate or leave some feedback.
Posted on Apr 22, 2010
Evildice
  • 222 Answers
SOURCE: i have replace my samsung
1. Check inside of printer for pieces of paper (papaer jams)!
2. Replace toner cartridge, maybe your printer doesn't recognized electronic chip on your new cartridge!
Posted on Mar 14, 2011
How to solve toner exhaust problem of samsung ml 1866 priner
any problem inbangalore kindly contact vectracomm@gmail.com helpline 9448311575
Sep 18, 2012 | Samsung Office Equipment & Supplies
Tip
Solution to red light after refill Samsung ML 1540
Samsung printers such as ML 1640,ML 2245 and SCX 4300 have a toner page count embedded in their firmware. This is the reason that once you refill your toner after it has run out,the printer still doesnt print and says toner is exhausted. After you've refilled the cartridge,you'll have to reset the toner count also to zero...to do this,download the firmware here. ML 1640 Ml 2245 and SCX 4300 are not available on Samsung support site. You will need to google it and you may find it in torrents.
run it and it will reset your toner count to 0...you have to do this everytime you refill your toner.
Another solution is to open the backside of ML 1640 and ML 2245,locate the chip 93c66 and short pin numbers 1 and 4 and turn on the printer for a second.It only works in some cases though.
on Sep 01, 2009 | Samsung ML-1640 Monochrome Laser Printer
Red light on all the time will not print Samsung ml-1640
Depends which LED light is red. The upper one with two symbols is the error LED, while the lower one is the toner LED.
If it's the top LED, then it could be a number of issues, such as an open cover or some software problem. Could be an LSU error. Try updating the driver and firmware.
If it's the bottom LED, then your toner is probably finished (or has hit the 2100 mark). Try redistributing the toner by giving it a little jiggle, or just change the whole thing.
Apr 05, 2010 | Samsung ML-1640 Monochrome Laser Printer
Samsung ML-1710p - when attempt to print, leds start slowly blinking simultaneously, "on line / error" - red, "toner save" - green
Nov 27, 2009 | Samsung ML 1710 Laser Printer
Toner exhausted
open the back cover and locate the chip numbered 93c66,its above the USB port on the mainboard.short the top-left and bottom left pins and turn the printer on for 5-10 secs...that resets the page count to 0... also either remove the chip on the toner or cover it with a cellotape
Sep 01, 2009 | Samsung SCX-4300 Monochrome Laser...
Red light comes after refill
Download from this site http://sahat-tambunan.com/files/2009/Samsung-ML-1640-reset-raw.zip Raw Package for ML-1640 You will find 5 files in this package:
  • ML-1640_V1.01.00.83.exe is the official firmware upgrader
  • downl1640.bat is the firmware downloader (to printer)
  • fix1640.bat is the firmware patcher
  • fixml40.exe is the tools run by the patcher
  • usbprns2.exe is the tools run by the downloader
Unzip and start usbprns2.exe than downl1640.bat, at the end press any button and for 16 seconds you have printer reset.
And that is it, you are free to do what ever you want, but be careful if you reset with empty toner it will also show that toner is full.
Save the money for toner refill. See ya
P.S- Was this helpful? Say YES
May 22, 2009 | Samsung ML-1640 Monochrome Laser Printer
I have a samsung ml 2851 nd that won't print, and says the toner cartridge is low - I replaced with cartridge 209 (which office max said would work) and it still flashes the red light and says there is...
The counter needs to be reset most likely. I can\t locate a reset code & steps for you. Try calling samsung and ask about the toner reset you replaced the cartridge and its still showing the count from the old cartridge.
Apr 23, 2009 | Samsung ML-2851ND Laser Printer
Hiw do I reset the
The following conditions can cause the On Line LED to glow:
* Printer paper is jammed inside your printer.
* A cover is not be closed properly.
* The toner cartridge is not inserted properly and needs to be reinstalled.
* The toner cartridge is running low.
* There is no paper in the paper tray.
* The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks
If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. For replacement cartridges, please click here to visit our official online parts distributor.
On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service
Apr 14, 2009 | Samsung ML-1640 Monochrome Laser Printer
ML1640 not working after toner refilling
Download the firmware from here http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=in&CttFileID=2238869&CDCttType=FM&ModelType=N&ModelName=ML-1640&VPath=FM/200904/20090416100856890/ML-1640_V1.01.00.83.exe
run the software and this will reset the page count to 0. Samsung printers generally do not support a refilled cartridge and thus the red light.But resetting the page count to 0 makes the printer detect the cartridge as an intoductory one.
Mar 23, 2009 | Samsung ML-1640 Monochrome Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
Samsung SCX4623F Laser All-in-One Printer Logo
641 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
