Code 4522 comes up, I think this is for the color reg sensor... just need to know how to clean it.
The solution for your problem new belt assy and cleaner box and clean everything on the color reg assy with compressed air.
The manual for the printer is available from the link below
You need to see Chapter 4 for getting instruction to clean the sensor
click this link to download the manual
Sir,
Click this link for more infor.
thanks
good luck
hi
check the fuser first, it should be clean and shiny otherwise it's coming from drum area
Check the wiring between the PRCB and the Total Counter. There might be
a short to ground close to the Total Counter. After the short is found
and repaired, replace the PRCB (p/n A03UR75900).
If the wiring is not damaged, reposition it so that it is secured in
the plastic hooks behind the counters. This will keep the wiring from
being pinched when the cover is removed and reinstalled.
It is recommended that all machines be inspected at setup or the next service call to prevent future incidents.
Possibly three problems.
1. Your tech is cleaning the sensors but may not the cleaning pads so
each time the machine is doing a color reg it is putting toner on the
sensors.
2. The transfer belt has not been assembled properly and it has more
tension on one side than the other causeing the belt to buckle.
3. The film seal in the cleaning unit is worn and it is spraying toner on to the reg sensor.
Ultimate solution new belt assy and cleaner box and clean everything on the color reg assy with compressed air.
HI,
Junior Member
CAUSE:
ICP17 is OPEN on the Printer Control Board. The wiring between the
printer control board and the hardware counters may be pinched. If the
wire is shorted to ground, ICP17 on the printer control board will
open, resulting in the error code. If the wire is broken internally
without shorting, the machine will function but the counter will not
increment.
SOLUTION: Check the wiring between the PRCB and the Total Counter.
There might be a short to ground close to the Total Counter. After the
short is found and repaired, replace the PRCB (p/n A03UR75900).
The above solution is from the below forum:
Please click on the below link for more troubleshooting steps.
http://www.copytechnet.com/forums/konica...
Below are the 3 problems for your issue:
1. The pad is not cleaned.So
sensors.
tension on one side than the other causing the belt to buckle.
http://www.copytechnet.com/forums/konica-minolta/14613-km-6500-error-code-c-4522-a.html
1. The pad is not cleaned.So each time the machine is doing a color reg it is putting toner on the sensors.
2. The transfer belt has not been assembled properly and it has more tension on one side than the other causing the belt to buckle.
I have an error code of 4522 on my Konica Minolta bizhub c6500. I just need to know where the color sensor is so that I can clean it.. does anyone have a scamatic or can walk me through it. thanks
