DELL precario mini tower cpu... I losed my cpu and started Dusting it! Den i mistakenly tampered wit 1 pin in the pinless processor Circiut while brushing it....so the pin is Cutt Off and it refused to display on my monitor screen again am confused what will i do...
    Guru:
  • 571 Answers
I suggest that you contact a technician for that. It's a complicated issue.
Posted on Dec 07, 2012
  • 749 Answers
SOURCE: CPU problem
Here are possible solutions to your problem. Since you didn't give us some beeps from your PC.
1. Measure the voltage of CMOS-Battery it should be 3V if not change it, P4 is sensitive to it. OR
2. Try other memory first to test if it works fine. OR
3. You needed to refresh the installation of your windows XP to bring back or to repair the files in its system. Boot your WinXP CD and there find the one that refreshes the installation... Don't worry it will not erase your files... It should not try to create a new file-directory.
Posted on Nov 16, 2007
frcs68
  • 1605 Answers
SOURCE: dell optiplex 620- my monitor screen says no
why do yo want to do that?
15 pins to 15 pins. 9pin connector use to be serial connector back in the old days.
Posted on Jun 11, 2009
  • 52 Answers
SOURCE: i have acer 915m08 mbd & i want to use 3.06 ghz pinless processor in same mbd. processor will work or not.
you're mbd uses a LGA775 cpu with a fsb of max 800
if you're cpu uses fsb of 800 or below it will work if not i don't advise you to try it.
Posted on Jun 14, 2009
SOURCE: Dell OptiPlex GX620 starts up then shuts down repeatedly
Try this: remove the DMOS battery and unplug the on/off switch plug. It's the one in the corner near the power supply. To be sure follow the cable from the front on/off switch board on back to this plug. Then plug the A/C cord in, if the system boots up fine, then replace the front panel power on/off swith board. Naturally you will not be able to power off the computer using the power switch (since we unplugged it), so you will have to just pull the plug. Hope this helps. Joe
Posted on Jul 22, 2010
ib_yang
  • 1098 Answers
SOURCE: tamper monitor pop-up. How do I stop it?
An incomplete Norton installation activity (like a software for online security for kids) could have taken place. I suggest to uninstall this completely, clean it up and reboot. That should take care of it.
Posted on Jul 26, 2010
P 4 which is best pinless or pinned
As long as you secure it, it really doesn't matter. I prefer the pinless because with the pinned processors, it can be very easy to accidentally bend 1 pin and if it is slightly off alignment it might not fit into the socket.
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Feb 28, 2014 | Computers & Internet
Dark spot on pinless processor
the computer tends to shut down when the procssor ovrheats and if u removed the processor or the heatsync for that matter you have to remove old termo pate and replace it with new termo paste otherwise your brossesor will burn out
May 08, 2013 | Intel Computers & Internet
My gx620 thermal fan overheats
A) FOLLOWING Anti-Static Procedures;
1) Clean the inside of the computer out
2) Replace the Thermal Paste on the Processor (CPU)
THOROUGHLY clean top of CPU (Processor), and bottom of Heatsink.
PROPERLY apply fresh, new Thermal Paste.
http://www.hardwaresecrets.com/article/274
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503
http://www.dell.com/support/Manuals/us/en/19/Product/optiplex-gx620
Click on the blue ->
Dell Optiplex GX620 System User's Guide (5990KB)
Using Mini Tower Computer as an example;
In the list click on;
1) Removing the Computer Cover
2) Processor
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 13, 2013 | Dell OptiPlex GX620 PC Desktop
Optiplex replace power supply
Hello Jacey,
Below are the system specs for the power supplies that are installed in each chassis of the GX280 system. You can call the Dell Spare Parts
Department at 1-877-717-3355 or click the link below.
Spare Parts Department
Wattage small form-factor computer: 160 W
small desktop computer: 210 W
small mini-tower computer with processor speeds of 3.2 GHz or lower: 250 W
small mini-tower computer with processor speeds of 3.4 GHz or higher: 305 W Heat dissipation small form-factor computer: 546 BTU/hr
small desktop computer: 717 BTU/hr
small mini-tower computer with processor speeds of 3.2 GHz or lower: 853 BTU/hr
small mini-tower computer with processor speeds of 3.4 GHz or higher: 1041 BTU/hr Voltage fixed-voltage power supply-110 V at 50/60 Hz manual selection and auto-sensing power supplies-90 to 135 V at 50/60 Hz; 180 to 265 V at 50/60 Hz; 100 V at 50/60 Hz for Japanese computers
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 23, 2013 | Dell OptiPlex GX280 PC Desktop
What is the difference between a pin less and pin processor?
A pin processor have the pins at its bottom which merges in to the motherboard!
A pinless processor has no pins.pinless processor has a flat bottom with around an extra 297 connections to the motherboard. You cant fit one to a pinned socket. vote me if it is helpful
Sep 20, 2011 | Intel Core Duo T2600, 2.16 GHz Core Duo...
How to recognise a pin and pi nnless processor
A pin Processor has metal pins on the bottom of it.
For an example let's use an Intel Pentium 4 processor, that fit in a Socket 478 processor socket.
http://www.cpu-world.com/CPUs/Pentium_4/TYPE-Desktop%20Pentium%204%20Willamette.html
Viewing the link above, observe the green square under the grayish metallic looking square.
The green square is a circuit board.
(Width and length, about the length of your first digit on your thumb)
The grayish metallic square, is a metal shell cover over a Chipset.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The Integrated Circuit here is the Processor.
The Processor is connected to the green circuit board. (PCB. Printed Circuit Board)
On the bottom of the green circuit board are contact pins. In this case 478 of them. (478 pins)
http://www.cpu-world.com/CPUs/Pentium_4/Intel-Pentium%204%201.7%20GHz%20-%20RK80531PC029G0K%20%28BX80531NK170G%29.html
The tiny metal contact pins fit down into matching socket holes, in the processor socket.
A Socket 478 processor socket,
http://en.wikipedia.org/wiki/Socket_478
(You can click on the photo to the upper right to enlarge it.
The next design to come out, has the Processor with contact pads, (Pinless), and the processor socket has the contact pins.
An LGA 775 processor socket,
http://en.wikipedia.org/wiki/LGA_775
Example of a Pentium Dual Core's bottom side. (LGA 775 processor socket is used),
http://www.cpu-world.com/CPUs/Pentium_Dual-Core/Intel-Pentium%20Dual-Core%20E2220%20HH80557PG0561M%20%28BX80557E2220%20-%20BXC80557E2220%29.html
There you have it.
A 'Pin' processor has metal contact pins on the bottom.
A 'Pinless' processor has metal contact pads.
Regards,
joecoolvette
Sep 03, 2011 | Intel Computers & Internet
Wanted to know what a pin less motherboard is
Actually there are Pin less processors .which fit in the motherboards .
Pin less processors don't have pins . we can fit in motherboard easily.
But, the processors which have pins . takes a bit concentration .because the pins can bend.
All Amd Processors are with pin . and all new Intel Processors are Pin less
May 09, 2011 | Computers & Internet
My p4 system getting hot
see do one thing check the cpu fan whether it is working properly and is not producing any noise if it is then probably you need to replace your cpu fan with a new one also makke sure that your power supply fan and chasis fan is working as excess heat gets generated in the system they remove it
to change the cpu fan 1.see it will depend on what kind of cpu socket you have pin or pinless for pin-open the plastic clamp on the fan for pinless -unscrew the heatsink
2.remove the heatsink and replace it it will be much better if you replace the full heat sink with a new one .also don't forget to put thermal grease compound for effivient heat transfer in between the cpu and the heat sink contact generally these days heat sinks come with pre-applied thermal componds but still it is recomended to apply it firmly over the cpu before installing the heat sink on it
3.if you wish to install the old heatsink by just replacing the top fan then replace the fan and rub the bottom of the heat sink with a sand paper to make it even and free from dust and oxide apply thermal compond and install it on the processor .plug bak the cpu fan header cable . start your system it will stop overheating..
Dec 05, 2010 | Intel Computers & Internet
What is pinless prosseser
Pinless processors are the new type put out by Intel. They do not have the pins on them that the older ones had. They basically work on a contact method with is actually much better than the pins in the past.
Oct 09, 2010 | Intel Core Duo T2600, 2.16 GHz Core Duo...
How to recognizea pinless or pinned processor
A pinless (Pentium 4) processor has no pins.
Just a flat bottom with around an extra 297 connections to the motherboard.
You cannot fit one to a pinned socket.
Hope this helps
Jan 25, 2009 | Intel Core Duo T2600, 2.16 GHz Core Duo...
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 23, 2018 | Toshiba Computers & Internet
Can I hold DHHS accountable for the burden they put upon me? If not, is there someone that can be held accountable? What can I logically and honestly do to remedy this prob. I explained my prob below! I was getting QMB part of Mainecare and my spouse at the time we were dating but living together was getting the QI part of Mainecare. We are both disabled and only get SSDI. However being honest and do our best to always do the right thing we go to DHHS office on Griffin RD in Bangor, ME within a month of us getting married where the worker we saw tells us we don't qualify for anything but the min of FS and both Q1 part of Mainecare and serious voice tells us to divorce. I have made a few trips within last months to same DHHS. One sends us to Eastern Area of Aging to see if there were secondaries we can get. This past Monday hubby and I went to our appt with Eastern Area of Aging & was told they strongly believe I could get spousal exclusion also warning it could mean my hubby loses help but because it was a volunteer a newer one at that she couldn't tell me definitely cause she didn't know the formula as she still learning; tells us to go back to DHHS to ask about spousal exclusion. So I go back to DHHS this past Thurs and got a worker with more smarts, heart with approx 10 yrs working for DHHS tells me I qualify for spousal exclusion and took the time to answer all my questions. I told her I had QMB till hubby and I married June 2016 & shared with her what the DHHS worker told us when hubby and I went in to show marriage certificate to update the change. She looked at me with shocked eyes and dropped jaw in bewilderment. Then says I would of never lost it as I would of qualified for spousal exclusion from the day we married. And had it been her that we got when we were being honest wouldn't have only told me about spousal exclusion but would of applied me as she could see I have major medical problems that is too much a financial burden for my hubby and I. She also told me I was to submit all unpaid bills even if monthly making payments were being made. I thought I was only to submit bills I paid in full or on a payment plan. So started Thurs night on a Medical Bills Tracker to go through all the medical bills and sort things out. I haven't even put a dent in the pile and see I'm responsible for just over 6K I'm predicting once done I could be closer, if not over, 10K. In collections is currently 1K but once done with pile amount in collections could be closer to 2K or more. So the mess has impacted my credit and if things were done by professionals I wouldn't be losing my hair stressing over my medical bills and how it declines my credit. I know I'm in a small group that actually pay their medical bills any and all bills to be honest! I am disabled and get SSDI. Worked 1992-2013 a lot of times working 2 jobs! Dr in 2013 practically dragged me out of work as was just diagnosed with Hep C, CKD Stage 3 & liver disease! I also have depression disorder, panic attacks, anxiety disorder! So even this incompetent DHHS worker putting extra financial burden on me unnecessarily affects those things. I am trying to do the right thing but get kicked down by the very people that are paid to help me. What are my rights and can I fix this at a faster pace then not even fixed it by the day I die?
Jun 23, 2018 | Major Computers & Internet
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
