Question about Konica Minolta Office Equipment & Supplies
How to reset fuser life on bizhub 43 - Konica Minolta Office Equipment & Supplies
  • 12 Answers
SOURCE: how do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
Posted on Mar 20, 2009
SOURCE: Brother HL-5170 fuser reset
should be a service selection in the user tools/ menu. reset life/consumables/replacement etc.
Posted on Aug 05, 2009
  • 5 Answers
SOURCE: RESETTING FUSER LIFE ON BROTHER HL5140 PRINTER
How to reset the pf-kit message on a brother hl-5140.
Posted on Aug 12, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: I have bizhub c250 and
You can reset the fuser counter only by replacing the counter reset fuse. This fuse is located on the fusing unit which must be removed and a small cover opened to get access to the fuse. You ca get the fuses from precisionroller.com
Their part number is M9970. It will say imaging unit fuse but the fuse is the same for the C250 fuser reset.
If you do not feel that you can remove the fusing unit and replace the fuse then you might be able to find a local independant copier repair person to do it.
Be assured tho that you can reset this indicator as I have done this a dozen times or more for my customers.
Good Luck and Thank You for using Fixya.
Posted on Nov 04, 2010
Testimonial: "Thanks"
wheatlandsvc
  • 1110 Answers
SOURCE: can you reset fuser counter without replacing the
You can. You have to remove the fuser, and replace the counter reset fuse that is soldered into the wiring harness, then re-install the fuser. 10 minute job but not a one I would recommend unless you know the machine pretty well. Depending on your location and service options I would try to find a local independant repair person who can do this for you. I reset 20 to 30 of these fusers per year. Note you can also reset your transfer belt unit as well as your Imaging Units as well.
WheatlandServices
Posted on Jan 06, 2011
Testimonial: "thank you very much. I can tell, you're really an expert. your response was very helpful, i will contact a good technician right away to change fuse."
C 3201 bizhub c351
did you reset the machine after installing the different fuser a different fuser does not reset the machine requires a manual reset procedure your old one might be ok just got to hot and shut down reset the machine.
Apr 01, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Ihave konica minolta bizhub 43 i replaced anew fuser unit but its still showing consumable error replace fuser unit how can i solve this
Enter in the service mode: press Utility key-Metercount-(Details if exist)-Stop -0 0 -Stop -0 1 select a special parts life or in the counter mode consumable and reset the fusing unit counter.
Feb 04, 2013 | Konica Minolta Office Equipment & Supplies
I have a message on the screen : need to replace fuser unit
You have 2 options. Since your fusing unit life is over you can have it replaced by your local service company for a cost of about $350.00.
Or in most cases you can have the reset fuse in the fusing unit replaced which will reset the electronic counter in the machine and get another life cycle out of the fuser. This will cost you around $100.00. Someone who is mechanically inclined can get a fuse for $5.00 and do the work themselves and save even more. Instructions are easy to find.
If you need a fuser, or even just a fuse they can be found at precisionroller.com
If you need further info just ask.
Jun 18, 2010 | Konica Minolta bizhub C250 All-In-One...
Is it possible to find a used fuser for a Bizhub c250? I only have a few months left on the lease and don't want to put out the money for a new one. Also can I install this myself or will I need a...
you can replace the inline fuse located under the communication connector. This will reset the fuser life counter. You will have to remove the fuser, remove the fuser bottom cover (one screw), cut out the fuse and solider in a new fuse. You must turn off and unplug the copier before you remove the fuser or you will cause a fuser error code.
May 12, 2010 | Konica Minolta bizhub C250 All-In-One...
Is it possible to find a used fuser for a Bizhub c250? I only have a few months left on the lease and don't want to put out the money for a new one. Also, can I install this myself or will I need a...
These are not too bad to replace yourself if you or someone you know is at all mechanically inclined. As far as used, you would probably spend the same for one plus shipping as you would for new. Or at least close enough to make it not worth it in my opinion. precisionroller.com has them for $257 with free shipping. Part# H1895
Hopefully this helps and just holler if you have any further questions.
Mar 19, 2010 | Konica Minolta bizhub C250 All-In-One...
How to increase the drum life of Konica bizhub c250
Forever to change the OPC drum and drum cleaning blade change the reset fuser(0,80A fast fuser).and the copier machine it work 60000 copies.
Sep 27, 2009 | Konica Minolta Office Equipment & Supplies
How do you reset the life of the transfer unit on the Bizhub C250
Yes,
Bye.
Feb 14, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Reset fuser
Unforunately once a fuser goes, you are out of luck. I don't know of any printer that will continue to work once the fuser has gone bad. It's best to keep an extra fuser handy for business-critical printers.
May 28, 2008 | Konica Minolta bizhub C250 All-In-One...
107 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
