Question about Fisher and Paykel Washing Machines
What does the error code 4.02 mean for the fisher & Paykel cpap machine
Fisher & Paykel NOVO
  • Steve Sickman
    Steve Sickman Jan 08, 2014
    I have the same problem with my F&P icon cpap unit. I called their U.S. office and was told that it is the code for a fault in the heater plate. This makes sense since the unit was not blowing humidified air.
4 Suggested Answers
SOURCE: service manuals and diagnostic codes with results/reset code
http://www.aars.com.au/F&P%20Service%20manual%20517735.pdf
Posted on Feb 06, 2009
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
  • 343 Answers
SOURCE: what is error code 136 on a fisher & paykel IW...
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
Posted on May 24, 2010
Showing Error Code E1
If you wish to get some details; check the site linked here. Pull up older posts.
http://homenol.blogspot.com/
Aug 31, 2016 | Fisher Paykel Fisher & Paykel SleepStyle...
My Fisher and Paykel icon Series auto CPAP does not start
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Mar 05, 2016 | Fisher and Paykel Washing Machines
FISHER PAYKEL WASHING MACHINE FAULT CODE 56 DOES ANYONE KNOW WHAT IT MEANS
Error code 56 is mostly the motor controller, SD11 & SD12 brown boards, 3 x 332k resistors near the small transformer go low & need replacing with a 1 meg Ohm resistor will fix the problem.
May 22, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
On a fisher & paykel washing machine what does it means by fault code 12. The washer is approx 8 years old.
Hi just read posting.Error code 12 means FLOOD PROTECTION ERROR.Has you machine overflowed or does not pump the water out quickly?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
May 16, 2011 | Fisher and Paykel Washing Machines
Our Fisher & Paykel Intuitive Q came up with an Error Code 51, Stopped and an Alarm came on.
Hi, this is an update on what I found out about the E51 error code from Fisher & Paykel. This code is an error with the internal memory as one of the previous poster's said. Fisher & Paykel Rep said though it wont hurt the function of the machine it should still be replaced because it may effect the compliance information.
Nov 15, 2010 | Fisher and Paykel (IWL12)
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
What is error code 136 on a fisher & paykel IW709AU top load washer
May 20, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Have Fisher & Paykel top loader. Error code
fault code 56 is a real code : bowl invalid check clutch in centre of bowl and pressure tube is not kinked,can also mean pressure tranducer on motor control board could be faulty, note check for obstruction between inner and outer bowl( missing a sock perhaps.?)
May 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
651 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
