Question about Home Security
How to reset password cct716
I want to connect to internet for remote viewing. i have forgotten the password of the dvr. it will not let me in to the setting unless i put the password in. how do i do this. i also don't have the software disk. thanks
3 Suggested Answers
SOURCE: not able to use remote viewing via no-ip
I had the same exact issue. I was using dyndns to connect, but i found out that when you login in the host, dont put your local ip address of the dvr, but instead put the internet ip address of your network. so instead of 192.168.0.5 for your local put the 89.137.24.124 for the internet address. That fixed my issue. Hope that works for you. Just make sure your username and password is right and the port is set up correct in your router to forward to the local ip of the dvr.
Posted on Mar 27, 2010
SOURCE: Security First SDVS-1904 Setup
I'm not sure if you are still looking for the answer, but I think the problem may be that you need to enter the PUBLIC IP address of the modem at the remote end instead of the PRIVATE (ie. 192.168.1.x) IP that was actually assigned to the DVR. It works best if you assign a static IP to the DVR on the remote end and enter that IP into the router's DMZ. You might also want to get a free account at dyndns.net and setup a FQDN for your business router/modem. That way you can connect to it using something like "mybusiness.homeip.net" instead of an IP address, and if the IP changes it will still find it. You will also have to configure your modem at the business to automatically update the dyndns server when the IP changes.
Posted on Sep 08, 2010
How to reset Admin password on Samsung SDR-C5300N Digitalvideo recorder
If you have forgotten your admin password on a Samsung Security DVR, most experts would suggest that you have to contact Samsung and/or send it back to Samsung to have the administrator password reset. While this is true in some cases, it is not always necessary.
Many Samsung Security DVRs have a built-in reset that will allow you to wipe the settings of the device and reset the configuration, including the administrator password. Note that if you perform one of these resets, all settings will be erased and you will have to setup the DVR again. So you should only do this as a last resort - but to reset an admin password, the last resort is the only option.
Reset Procedures for Samsung Security DVRs
There is more than one reset procedure for Samsung Security DVRs, depending on the series and model. But in total, this only amounts to a handful. Since one reset can apply to several different models, I'll provide the resets here so you can try them on yours - I won't associate any one reset with a single model because a complete list of which reset works with what model Security DVR simply doesn't exist. Some of these won't make sense based on the buttons available on your unit or your remote. In those cases, just skip that reset procedure.
If you can perform a reset (in other words, if the instructions match what you have available on your Samsung Security DVR and/or Samsung Security DVR Remote), try it, and let us know in the comments if it works and on what model. If you tell us which model Samsung Security DVR you have, along with your results of each reset procedure, we can compile a complete list of reset procedures by model so that it will be easier for those seeking this information in the future to reset their Samsung Security DVR. Also, if you have a reset that you have used and you know works, let us know and we will add it here. I will update the list of Samsung Security DVR resets/recoveries as I encounter them.
So if one of these doesn't work for you, you may want to check back occasionally. In fact, if you leave your model number in the comments and any specifics about your problem, I'll try to get that specific reset for you. For any of these comments, just use the comment section at the bottom of this page - it is checked regularly.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
Then enter the 4321.
Samsung Security DVR Reset Procedure #2
Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3
This reset will work on Android based DVRs only. All steps are performed on the device itself.
Turn the device Off
Wait 2 minutes
Press and hold the following buttons
POWER,
HOME
VOLUME UP
The unit should power on. Once it does, you can release power.
Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
Activate the reset using the HOME button.
When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4
This reset will work on SDR models. It may also work on other models.
With just the cameras showing, press the following in quick succession using the remote:
Freeze
Alarm
Freeze
Alarm
Freeze
Menu
Enter
Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5
This reset will work on SDR models where procedure #4 failed. It may also work on other models.
Press the DVR Button to place the system in DVR Mode
Press:
Freeze
View
Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6
Courtesy Sergio Ayala
To factory reset the SDR-B74301
Reboot the DVR
Once the DVR has rebooted, enter the following sequence on the remote:
UP, RIGHT, 5, 3, 3
You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
These reset procedures cover many Samsung Security DVRs, but not all.
CCTV Networking Technical Support
Oct 07, 2017 | Samsung Home Security
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
Sep 18, 2017 | Samsung Home Security
My Samsung dvr model SDR75300n can't not reset my passwood.
you need to do on the dvr .remolt settings you cant do needs to be done by the dvr
Jun 15, 2017 | Samsung Cameras
Password reset dvr
Hi anybody out there know how to reset the 'Admin' password on a 4 channel 'Kare H.264 DVR' I have forgotten it and cannot access the menu.
Please help!!!
Jan 07, 2014 | Home Security
Cannot remember password need to rest it on ECOR264-4D2
On some DVR's you can reset the password by downloading .bin files from the manufactures website onto a thumb drive. I've done it for other models just not Everfocus. It's pretty simple if you can get access to those files. After you have them on the thumb drive you power down the device, plug in the thumb drive, the device scans the thumb drive and resets your password back to default, hope that helps!
Dec 21, 2013 | EverFocus ECOR264-D2 ECOR264-8D2 8 Channel...
I have a sentient cctv dvr from Maplin I can view it on my phone at home which is fine I wanted to know if I can view camera footage when I'm not at home etc. at work
Yes you can definitely view your CCTV footage on your mobile phone at your work via internet. Sentient CCTV DVR basically is a night vision camera. You must know the IP of the camera and IP Video server. Connecting your phone to CCTV camera via the protocol you can view the CCTV footage's in your phone. Night vision cameras are used for surveillance purpose. I would prefer cctv camera with ir illuminator for good image quality in the night time that will clear footage quality in my phone.
Recently many new applications have also being launched by security cameras with a view to solve problem you mentioned.
Jul 05, 2013 | Home Security
I cannot access my internet viewer
More details are required.
The Samsung 'SmartViewer' program starts up on a computer. You can access it whether you have a recorder or not.
The Samsung 4 channel DVR has a menu to set IP address & ports to use and a netjack to connect to internet. You can access the DVR from any computer connected to the same router as the DVR by inserting the same correct info into 'SmartViewer' as in the the DVR.
Once you open the required ports in your router, port forward the router to the DVR, any incoming requests from the internet to view should connect and with the correct password you can view your security cams.
With minor adjustments..that's it.
What didn't you do?
Dec 25, 2012 | Samsung 4 Channel Dvr
I need reset the password on a 16 ch. dvr dvs do you know how i can do this?
I have a H.264 Network DVR with ver. V2.00.R05 and I've forgotten the password can anyone help with resetting it...
Mikw
Nov 05, 2010 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Home Security Logo
125 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
