Question about Music
Need authorization code for addobe photoshop CS3 version 10.0
I live in Myanmar. I try to install CS3. I have serial number : 1045-1090- 6246-8353-3166-2968 , authorization number : 4732-2156-5437-1935-4277-8022-4063, authorization type : normal 194:13 . I need authorization code : ????????? Thank you so much .
Is the serial number J96107 a real serial number? I was told that they only went up to J96096.
As with any hardware, you need to supply a "brand name" or manufacturer and what the "model number" is. Of course, a model number is not a serial number. Even within a brand, each model may have its own set of serial numbers. I suggest you do a google search for "brand serial numbers" replacing the word brand with your specific brand. But here is a short cut that may serve you well:
http://musictrader.com/?page_id=61
If you want to try another type of direct google search for your:
If you do not know the brand, then try the type of instrument and serial numbers. That may offer you a list of different instrument brands with links to serial numbers associated with them. Here is a result for a search for clarinet serial numbers.
For example: http://www.woodwind.org/clarinet/Equipment/HowOld/
Aug 26, 2015 | Music
Fender Artist Signature Yngwie Malmsteen Stratocaster US13088442
A new serial numbering scheme was adopted toward the end of 2009 using the number "10" as a prefix, followed by a space, followed by seven digits. The "10" prefix was designed to identify the first year of the second decade of the new millennium, and while it appears on the instrument decals, it was not captured in Fender's operating system. Only the seven-digit suffixes were actually entered into the database. These serial numbers did not identify the country of origin in the body of the number. Instead, the instrument's country of origin appears on the decal on the back of the headstock, near the serial number.
This new numbering scheme was short-lived and was replaced only a few months later by an improved scheme that identifies an instrument's country of origin and year of manufacture in the body of the serial number.
This new scheme uses the letters "US" as a prefix to designate an instrument made in the United States, followed by an eight-digit number. The first two digits of the number identify the year of manufacture, (10 for 2010, 11 for 2011, etc.). The following six digits are the unit identifier, although it should be noted that these final six numbers are not sequential and do not provide any other identification information about the instrument. This new scheme is now used on the majority of U.S.-made Fender instruments, with exceptions including the American Vintage series and certain special-run instruments. Instruments Product Dating Fender Support
Feb 18, 2015 | Fender Music
Information on Besson 10-10 Trumpet Serial number 259315
A Google search for Besson 10-10 trumpet will get you results
Feb 07, 2015 | Music
What yr is my Epiphone valve junior serial number 11050738
For the best answer contact Epiphone directly at http://www.epiphone.com/Home/Talk-2-Us.aspx
Feb 01, 2015 | Epiphone Music
I have a Fender Squier Stratocaster Standard HSS. Serial number: ic071104059. i am trying to determine the year and specifications
It was made in 2007. If you call Fender directly they can sometimes id the exact model version from the serial number. The records they keep on Squier guitars is a bit sketchy, but sometimes they can help.
Oct 11, 2014 | Music
I need an activation code for pro tools 8?
When ProTools is installed on a computer it needs to be authorized to work. This has to be done via a dongle, a socalled iLok . The authorization is done by www.ilok.com. You need a dongle with the authorized registration of ProTools on your computer to make ProTools work.
regards
Mar 09, 2014 | Digidesign MBox2 Mini with Pro Tools 8 LE
Where is the serial number on a crate amplifier
Real basic owners manual is here:
http://www.crateamps.com/pdf/manuals/CA6110DG_OM.pdf
Look at the chassis, or pull a part number off the original speaker to match speaker and back cross reference to the amp versions that used it. The OM is at least good enough with the block diagram to allow it to be serviced easily enough.
Feb 21, 2012 | Crate CA6110DG Gunnison Acoustic Guitar...
Yamaha BB450's year (bass)
supported here and those formats offer no clue as to where these guitars where made.
google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); Supported Brands
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
The serial numbers repeat evry 10 years... you have to know what decade is likely thenfrom the Yamaha wizard: Your guitar was made on
January 15th, 1985, 1995
or 2005
Production Number: 3
Feb 08, 2010 | Yamaha Music
Music Logo
97 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
