Question about Bose Lifestyle V35 Theater System
Bose lifestyle v35, sound but no image on ps3
Pluged ps3 into bose system and get audio coming though but no visual why?
techman
  • 3130 Answers
SOURCE: lifestyle 12 by Bose
No sound ? Make sure the audio input cable is connected to the music center FIXED outputs, the black connector is fully seated in the music center SYSTEM CONTROL 1 jack, and the multi-pin connector is firmly seated in the Acoustimass module jack. ? Turn the music center off for ten seconds, then on again, to reestablish communication between the music center and the speakers. ? Check the connections for any external components. Make sure to select the correct source for the desired input. ? Check the speaker connections. ? Be sure the CD is placed correctly, label-side up, in the music center, and the cover is closed. ? Increase the volume. ? Check to see if MUTE is lit in the display. Press the MUTE button on the remote to unmute the sound. ? Disconnect any headphones. ? Connect the FM and AM antennas , and last but not least. Make sure there is power going to the remote speakers or the unit will not communicate with them. Good Luck
Posted on Jun 14, 2006
SOURCE: Sony Audio Optical Out to Bose Optical In not working
Set the source for Optical-In on the Bose system to TV
Posted on Feb 17, 2008
SOURCE: audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Posted on Dec 28, 2009
SOURCE: hooking up a Bose Lifestyle 30 II to an optical audio output
Actually, you can do this. Just get an optical to RCA converter.
This looks like a good one: http://www.amazon.com/Cables-Go-40019-Optical-Converter/dp/B0002GV876/ref=pd_cp_e_2
Posted on May 31, 2010
  • 3 Answers
SOURCE: No display lights on bose lifestyle 8 home
If your capable of replacing components yourself - Change capacitor C19 (33uF 63v) its on the board next to the display.
This cap goes leaky/dry after time, as there is a lot of ripple on it. This is what causes the display to go dim or blank. changing this cap brings the display back on most cases. Also maybe change the other capacitors near it while you are there..
Really works!
Posted on Sep 02, 2010
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier
https://worldwide.bose.com/.../en/owg_en_sa2_sa3.PDF Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
worldwide.bose.com/axa/assets/pdf/owner.../og_sa1.pdf
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
[PDF]BOSE® Link AL8
Dec 29, 2015 | Bose Lifestyle SA-2 2-Channel Amplifier
I had Bose lifestyle V35, V20 try to link together. Bose link AL8 transmitter will not connect to receiver. both led is light solid green. Please help.
The commands for the Bose link system are actually going through the remote control system. In order to use the system you need not only a set of AL8 sender and receiver, but also a special remote control model RC48S2-40 these model numbers are slightly different for the US and for Europe. In addition you will need to activate the BoseLink connection through the system settings menu and you will need to tell the remote to which system it needs to talk. When you have done all that, there should not be any problem to "connect" the two systems. If this does not work, you may need some specialized help from a Bose specialist who understands this multi room set-up.
Nov 09, 2014 | Bose link AL8 wireless home-wide audio...
Bose link AL8 will not connect with the Lifestyle homewide powered system
Your v35 system needs to be programmed to work with the second zone wireless unit. Read the instruction manual how to do it, or let a Bose dealer set it up for you.
Dec 27, 2013 | Bose link AL8 wireless home-wide audio...
Bad distortion of Bose Lifestyle V35
It may be due to one of the component attached. Detach all the components and test by connecting one by one. Try connecting radio at last.
Mar 24, 2013 | Bose Lifestyle V35 Theater System
Bose Lifestyle V35, sound but no image.
Thank you so much the unplug the power from the system worked after hours of trying other stuff
Huge thank you
Aug 14, 2012 | Bose Lifestyle V35 Theater System
PS3 to Bose Lifestyle 28
hey, this is how i have mine set up.
Bose to PS3 via Digital Audio Optical
PS3 to TV via HDMI
This way you can get Full 5.1 surround sound, and good picture quality, also, go to the bose menu and set the optical source to your PS3.
Jan 29, 2010 | Bose Lifestyle 28 System
Connecting optical cabel to ps3 and no sound
go to the setting on the ps3 and go to audi select the audio to play through optical
if this does not fix it then
make sure that the bose is in the correct mode to play through optical
Jan 14, 2010 | Bose Lifestyle 48 Series III System
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
Audio problems connecting ps3 to bose lifestyle 48 system
Jun 14, 2009 | Bose Lifestyle 48 Series III System
Bose Lifestyle V35 Theater System Logo
47 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
