Question about Sony KDS-R60XBR1 60" Projection HDTV
Tv not bright enough on a sony kds-r60xbr1
Played with controlls settings on high tv is dark
  • Bear Carrillo
    Bear Carrillo Jan 22, 2013
    replace lite bulb it will fix the problem it happen to me
    Top Expert:
  • Sony Master
  • 14,553 Answers
When was the lamp this model uses for brightness last replaced? These as a rule have a 2,000 hour or 2 year average lifespan and many just before they fail will go darker, picture will come up slower and be a bit dim.
Posted on Dec 07, 2012
waynejamescm
  • 67 Answers
SOURCE: Yellow Tint in Lower Right Corner of Sony KDS-R60XBR1 TV Screen
What you probably have is a very well known problem with the optical block. As it covers the screen, it will turn everything else greenish/yellow.
The optical block is very commonly replaced and an expensive repair, but the extended warranty (in place for all these TV's regardless of purchase date) on these sets is expired or about to expire. I would urge you to call Sony (1.800.222.SONY) immediately to try to get assistance, and to see if the warranty is up on it.
Hope this helps you...
Posted on Jan 05, 2009
welcomejee
  • 10594 Answers
SOURCE: Yellow Tint on Lower Right Side of Sony KDS-R60XBR1 TV Screen
Hi, Sony will repair your TV free of cost for yellow tint problem. Click Sony Support for details.
davebies
  • 43 Answers
SOURCE: Resetting lamp hours
You will need to enter the service menu to do this. However if you were to push the wrong button on the remote you could really mess up the tv. So I suggest you call Sony and see if you can get an ASC to do it for you for a minor charge. There are literally hundreds of electrical adjustments in this service menu. I would adcise an asc do this for you.
Posted on Jan 23, 2008
SOURCE: KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Posted on Mar 31, 2009
  • 1039 Answers
SOURCE: KDS-R60XBR1 Sony Projection SXRD
When the tv is working turn it offO on the remote press display,channel 5 number,vol-,pwr quickly in that order. you will see the self check screen. items with a 1 to the right is failure. the remove the slf check screen turn set off.
Posted on May 02, 2009
TV is older and has had a great picture through the years. It has now developed blue vertical lines all the way across the screen every 3/4".
Those are retrace lines from too bright a picture. If you can't get them to go away with the brightness control then a repair is necessary
Jun 22, 2015 | Sony KDS-R60XBR1 60" Projection HDTV
The tv is on then screen turns off and greenlight will blink understanby and then screen comes on again
If it has a lamp that has not been replaced in a long time it may be that---if it turns on slow and is somewhat dim that points to a lamp that is about to fail---set detects if lamp not full up or bright enough etc.
Oct 24, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
Sony sxrd kds-r60xbr1 flashing red light all the time
Are you sure the lamp is pushed in far enough and did you make sure you screwed cover back on tightly?
Mar 13, 2011 | Sony XL-5100 Projector Lamp for Grand WEGA...
Picture getting dark
Its time to replace lamp in tv.
DLP lamp has limited life span like 3000 working hours and after that it need to be replaced to get bright picture in tv.
Lamp replacement is easy and procedure would be written in user manual.
Jul 04, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
My KDS-R60XBR1 has a total green screen, what options do I have?
Replace Light Engine or Buy New TV .Call Encompass Parts 1-800-638-3328
Nov 30, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
The picture has too much green
Change the contrast settings or the brightness settings. Theres alot of fine tuning that you can do
Jun 11, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
Picture is getting dark
thats a great tv,unfortunately the do wear out. all you can do is turn up the brightness
May 20, 2009 | Televison & Video
Mar 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Jan 05, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS-R60XBR1 60" Projection HDTV Logo
113 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
