Question about Smeg Dishwashers
Smeg st663 not finishing cycle
Two right hand lights flashing
3 Suggested Answers
SOURCE: Smeg ST663 gets stuck onwash cycle
I have the same problem. If anyone has an answer I would be most greatfull.
Posted on May 05, 2010
ginko
  • 19396 Answers
SOURCE: I have a smeg st663 that has the delicate and
Hi.
Try first to reset the error follow the procedures below.
1:
  • Hold down program selection button for up to ten seconds
  • Close the door.
  • After approximately 1 minute the dishwasher will advance to the end
    of cycle.
  • Turn off power from main circuit breaker.
  • Dry water inside the dishwasher.
  • Clean the filter unit (see Manual here, page 26 )
  • Apply power back.
3) If that does not work, please try the following procedure, it should enter diagnostic mode and reset the error.
  • Switch off the appliance
  • Turn the dishwasher back on.
  • Before any of the lights coming on press immediately the program button. Program button must be pressed 4 times within 4 seconds.
  • The two last program lights (normal and intensive) should start flashing.
  • Press again the program button once.
  • The Normal light will turn off.
  • The last light will keep flashing.
  • Switch off the appliance.
  • Wait 10 seconds.
  • Switch the appliance back-on.
If error is still there, then the problem is water pump malfunction. This will turn on second and third light from the left (light wash and regular wash)
The appliance cannot pump out the water. Check that the drain hose is not kinked or crushed and that the siphon and filter are not fouled. Check height of the drain hose at the back. Clean the drain well and filter located on the bottom panel of the machine. If the problem persists, contact the after- sales service. The pump must be accessed, freeing the hose connected to the pump from blockage, and testing the pump motor.
Note if lights are instead first (soak) and third (regular), then the problem is water inlet. In that case check pressure from the house, inlet hose. If that does not fix the problem, then the inlet valve and water level switch must be tested.
If lights are Delicate and Normal (the one with glasses and the one with dishes), then the problem is drain.
Regards.
Ginko
Posted on May 28, 2011
Help my SMEG dishwasher was stuck in a loop and when resetting it was going through the motions like it was trying to drain itself and then finishing the cycle so all 4 lights on the right were flashing...
completely unplug it for several minutes. if you do not have a plug, turn off the breaker to this unit for about 15 minutes. Then turn it back on and see if this resets it. Check for a reset button somewhere under the unit or on the door panel where the control buttons are if this is easier.
Mar 04, 2015 | Smeg Dishwashers
Re: SMEG Integrated Dishwasher ST663. I'm having
usually a screw on the striker (the bit sticking out that goes into the door) it will be a slotted adjustment so just loosen (not remove) the screw and pull it out a mm or 2.
retighten and test.
Also, clean the seal. While your at it, the sump filters and spray arms.
Oct 18, 2013 | Dishwashers
Feb 11, 2010 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
What does the very right hand light flashing mean? it still works, even though it is flashing
HI
It's probably your descale light. The machine needs to be descaled every so often to prevent mineral build up. Follow the directions in your manual. Let the machine finish each cycle. It will give you different light when its completed.
Jun 28, 2009 | Gaggia Super Automatic Espresso Machine...
Dishwasher not completing cycle
hi..you need to take out 6 screws to remove the top cover,you
will see that circuit board will have a burnt solder joint,re-soldering
it will solve the problem.
try this out..
thank u..
kindly rate my response..
May 09, 2009 | Smeg Dishwashers
SMEG dishwasher - cycle buttons
What is the model of the dishwasher? Open the door and look down the right hand side for a sticker and repost please. As a rule number 3 is a normal wash :D
Mar 23, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
SMEG DI 612CA. Dishwasher
Pisss!!! Comin from my asss!!
Mar 04, 2008 | Smeg Dishwashers
Smeg DF612S
Check to make sure there r no kinks’ in the drain line or that it is not clogged it sounds like the sensor is tripping because there is too much strain on the pump just like a breaker.
Nov 07, 2007 | Smeg 24 in. DWI612 Built-in Dishwasher
It's stuck on Bio...
Here is the link to the user manual, hopefully this solves your problem else please ask again; http://www.smegtech.com/site/smeg/pdf_libretti/19590097802-GB.pdf Hope this helps :)
Jun 25, 2007 | Smeg 18 in. DWF410SS Slim-Line...
Smeg electric oven
your neighbour is probably right. fan should work but if the element has disintegrated, bits of the element could be jamming the fan. take the rear panel off inside the oven and check
Jun 01, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Dishwashers Logo
Top Smeg Dishwashers Experts
Cleverer2
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
