Question about HP Compaq nc6000 Notebook
Compaq nc6000 wifi connection very unstable - HP Compaq nc6000 Notebook
  • HP Master
  • 32,281 Answers
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Posted on Dec 07, 2012
  • grudcarsten
    grudcarsten Dec 07, 2012
    The unstability is caused by the notebook. Other pc's have no stability issues. No interference from other routers or electrical apps. I have tried a usb adapter tp-link as a substitue for the onboard wifi. With the same unstability problem
3 Suggested Answers
FoxSysPCTech
  • 107 Answers
SOURCE: i can't get wifi on my HP Compaq nc6000
Typically, this means your wifi card is toast, however there are a few things we can try first. Is the light turning on to show that you Wifi connection is on? If it isnt, then make sure whatever switch or knob is set correctly. If this doesnt work then you can reinstall the drivers, but since it isn't even showing up then I doubt this will work. Even if the drivers are not installed, usually windows will at least see there is something there.
Posted on Jul 17, 2009
  • 101 Answers
SOURCE: how to connect wifi with
Unofrtunatly with compaq as well as several other brands of laptops these buttons were notorious for failing and need servicing to be fixed. the best solution for this problem is to simply purchase a USB wireless adapter from a site like newegg.com
Posted on Jun 26, 2011
Turn up volume on nc6000 laptop
Well one way is to go to the sound icon in the taskbar nodification area, click and adjust. another is to use the keyboard keys or a combo of keys.
Nov 10, 2012 | HP Compaq nc6000 Off-Lease Notebook PC -...
Wireless connection problems
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Apr 19, 2012 | HP Compaq nc6000 Notebook
How to connect wifi with compaq nc6000. I dont know is there a inbuilt wifi card. how to see it. also marked wireles button doesnt give any response. pls give me quick answer
Jun 26, 2011 | HP Compaq nc6000 Notebook
My hp nc6000 wifi is not working as no light turns on even
try to reinstall your Wireless network setup
here's the link of your laptop driver
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=367369&prodSeriesId=367367&swLang=8&taskId=135&swEnvOID=1093
Jan 17, 2010 | HP Compaq nc6000 Notebook
Compaq nc6000 can not connect to my 2wire modem
wants internet sure.
2 wire, what is that? no modem model stated
no ISP stated, is this an old DIAL up? modem, 2 wire POT telephone land line , modem or DSL line, it too is 2 wires.
actually even cable is. 2 wires, center and shield.
NC6000
No OS stated windows what
NO ISP stated..
no connection stated, wired ethernet or wifi, or router,
tell more get more, please.
Dec 28, 2017 | HP Computers & Internet
I can't get wifi on my HP Compaq nc6000
Jul 16, 2009 | HP Compaq nc6000 Notebook
How to turn down volume on compaq nc6000
You probably have to press the function button on your lap top and find the key that looks like a speaker with a up and down error.
Jul 08, 2009 | HP Compaq nc6000 Off-Lease Notebook PC -...
I have a hp compaq nc6000 no wireless option
if u truely wanna see u have a wifi then go to device manager from my computer and click device manager and go to network adapters and explore it u must see it there and to get connected to awireless network, get closer to atmoast 100m from a wireless source and the network connections tab will give a message if not then u lack driver
Apr 19, 2009 | HP Compaq nc6000 Notebook
Compaq NC 6000 on XP SP3 - Ethernet Drivers & Wireless Drivers
Limited connectivity means your pc not able to connect to the preffered network.................
wi-fi also not working....................
there is a problem with your router not from pc.
Apr 05, 2009 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
66 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
