Anonymous Posted on Dec 07, 2012
Where could i find the dimmable t8 led tube for a good price?
We are ready to buy large amounts of dimmable t8 led tube, please give me some suggestion. thanks in adv.
Lisa Robert
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 16, 2013
Lisa Robert
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
431
Points
You can buy T8 LED tubes from Lumenorenergy because its a solid state lighting manufacturer and retrofit company specializing in commercial and residential lighting upgrades. Buy from here : http://www.lumenorenergy.com/
1 Related Answer
Anonymous
  • 17 Answers
  • Posted on Nov 02, 2012
SOURCE: Where can i buy some t8 led lighting and bring it my shop quickly?
I suggest you go to the local factory, but if you consider the words of the cost savings, u can purchase t8 led lightinging abroad
LED Driver for Allen + Roth 20268-000 Valleymede
Here (main three links) possibly, but spares are not listed anywhere, and their main business appears to be Gazebos! My first thought was return it under warranty as LED units are supposed to have a life of 7 to 10 years.
https://www.google.com/search?q=Allen+%2B+Roth+20268-000+parts
Triac dimmable LED Driver OEM - LED Driver 50w
Ad·https://www.smartspower.com/
SMARTS Power sole focus on Production R&D Triac/0-10V/Dali/5in1 Dimmable LED Driver. 12/24V dimmable LED Driver Factory direct sale, Save up to 30% of the cost price.
‎Triac Dimming LED Driver · ‎0-10V Dimming LED Driver · ‎Tria&0-10V(5 in 1)dimming
Triac dimmable led driver - UL listed LED driver 12V 24V
Ad·https://www.hideapower.com/
UL listed Led strip light driver 0-100% flicker free dimming Compatible with most dimmers. hidea power produces Triac & 0-10V(5 In 1) Dim LED Driver from 30 to 384W. High PFC LED Driver. 24h Online. In Stock Can Be OEM. Energy-saving lighting.
‎LED Drivers · ‎Dimmable LED Transformer · ‎UL Listed Power Supply · ‎Contact Us
LED Driver 2-7 years warranty - LED Drivers For Sale
Ad·https://www.swinpower.com/12_24v_dimmable/led_driver
UL 277V Triac 0-10V DALI Dimmable drivers delivers smooth, stable, flicker-free dimming. 6-384W ac to dc LED driver Constant current and constant voltage optional. OEM Brands.
‎Non-Dimmable LED Driver · ‎Dimmable LED Drivers · ‎Product Gallery · ‎About Factory
Nov 03, 2022 • Home
2helpful
Will a dimmable LED 50-100-150W equivalent bulb work in my touch-lamp which currently uses a 50-100-150W incandescent bulb? Do they make them? A non-dimmable LED 3-way didn't work at all.
Your lamp is a three level dimmer as opposed to a 3 position switch.
The 3 level dimmer chops the voltage where as the 3 position switch powers 2 separate filaments (50, 100) inside the bulb either separately or all at once.
The 3-way bulb should not be necessary for an electronic 3 level dimmer. Any incandescent, or dimmable CFL or dimmable LED bulb should work.
My led lights start to strobe when I turn on exterior light that is fed from the same line circuit. Solution?
There are two things coming into play here; the lamps and the dimmer(s).
First; LED and CFL type lamps that are to be used on a dimmer switch - must be identified for that use. Looks for the word dimmable on the packaging or bulb itself. These lamps are generally a little more expensive than their non-dimmable counterparts. If it does not indicate it is dimmable, then it isn't - and should not be installed on a circuit controlled by a dimmer switch.
Second; a dimmer switch that will be used to control LED and CFL bulbs (that are identified for use with a dimmer) must also be identified for use with dimmable LED and CFL bulbs. Again, these dimmer switches will be identified for this use and will cost more than those that work with standard filament type bulbs.
Lutron has dimmers for your circuit called a "C•L™ Dimmer" and supports Incandescent / Halogen, Dimmable Compact Fluorescent (CFL) and Dimmable Light Emitting Diodes (LED) type lamps. have a look here:
Lutron Maestro Dimmer and Switch Models
Also, be wary of the total load (wattage) of the lamps being controlled. If you have multiple dimmers in the same box, derating of the switch's wattage capacity (due to increased heat) will be required.
4answers
Where can i find a good led online store that sells T8 LED Light Tube?
You can buy T8 led light tube by a website of foreign country.Below is the best site where can help you buy the best T8 led light tube.http://www.ervan.cn/products/L05G-I33V-Emergency-LED-tube-.htm
 Grubhead
Grubhead
SmartAviator
SmartAviator
