Question about Hoover HDC6 Electric Dryer
Hoover TCE660 tumble - no heat
I have just had engineer in to fix problem - part of wiring needed replacing at back of machine - when left found that the sensor heating did not work properly ran for 5 minutes then went onto cool - engineer came again - was going to order new sensor which is found near filter backet - however took top off of machine and cleaned all wire connectors etc - seems to be working ok now!!!! However wasnt sure whether heat setting button should be pushed in or out for high heat - cannot find manual and cant remember!! Do you know please - Thanks
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Posted on Jan 13, 2010
How do I change the heating element on a hoover vhc 691 b tumble dryer?
Many of the heating elements can be seen and changed by laying the dryer on its back...the element is usually visible from the bottom. I found the part on the link I am incuding for you. Hoover VHC 691B80 Dryer Element 2100W
Dec 15, 2014 | Hoover Dryers
The tumble dryer function on my Hoover Performa 1100 WA 110 isnt heating up
The machine has a overheating protection that is blown. But you can reset it. Take if the top cover. You should ser a small black round temp sensor with two wires. And a red button in the middle. Push the red button. It should work. If not it could be many reasons for this
Nov 11, 2013 | Washing Machines
My hoover tumbledryer condenser vhc381 wont work when it is switched on there is a humming noise,the filter care light is also flashing,ive emptyed the water,hoovered it right through the vents and...
Fixed: dryer not heating up (Hoover vision hd 381)
Just fixed a hoover vision hd 381 tumble dryer. Thanks to the help on this site and others. Thought I would share my experience here. Problem was tumbledryer not getting hot. Traced it fairly quickly to a blown heating element. Took the back heater cover off (bulging silver panel), unscrewed heater, peered inside and it was somewhat charred (tested the thermostats which were fine). Dryer works now.
The really tricky thing was unplugging the heating element to replace it. The plugs are located inside the main housing.
However, the advice found on much of the internet to how to do this is incorrect. In particular the advice to remove the drum is not correct.
The way you access the plugs is by pulling the main heating wire through the hole in the unit, and feeding the plugs through one by one.
Then you can simply unplug the old one, plug in the new one.
Two things are necessary for this:
i) Remove the rubber collar keeping the main wire secure in the hole into the main unit.
ii) Pushing the plastic grommet through the small hole in the main unit. This grommet immobilises the main wire - you won't feed it through without it being released. You'll see quickly what this looks like on the replacement heater you should already have. The white plastic grommet protrudes a little out of the back of the unit close to where the heating wire enters the unit. Pinch it with a pair of pliers and push it back into the unit. The wire will then be free to pull through, and one plug at a time will fit through till you have all four. Then just pull the plugs off (pushing the new ones on requires quite alot of force).
In fact it is not necessary to strip down the unit at all to do this, apart from one thing: putting the grommet back for the new heater. It needs to be pushed from the inside. This probably isn't strictly necessary (I say probably), but I did it anyway. I suspect the grommet is there so that if the heater hangs free, it doesn't pull the wire up and stress the plugs. But I wanted to put the thing back exactly like I found it.
However, you still don't need to take the drum out to do this. You do however need to take the plastic mounting off that supports the drum. Then you can reach in with your hand and manouver the grommet into place.
So the repair ideally should be firstly to replace the heater in the way described above. Then put the cover back on as you'll need the unit on its back later.
Briefly, instructions for stripping down the unit:
i) Unscrew the 3 top screws located on the back of the unit holding the top of the unit on. Slide the top back and lift it off.
ii) Disconnect the door by undoing the allen key screws. Once these are off, lift the door off.
iii) Unscrew the plastic faceplate from the top (2 screws), to reveal two of 8 screws holding the metal front in place. I wired the plastic faceplate (with control knobs) onto the unit so I could still access these 2 screws, without the faceplate hanging free and risking disconnecting something.
iv) Unscrew the remaining 6 screws (4 near the rubber seal, 2 at the very bottom). Remove the rubber seal carefully.
v) Lift the metal front off, and disconnect the wires (keep track of which goes where!) Place the machine on its back (support it with blocks where the bulging heating element is).
vi) Unscrew the four nuts holding the plastic mounting which supports the drum.
vii) Slide the plastic mounting up by about 10mm and hinge it out from the bottom. This lifts the felt seal off the drum. The machine needs to be on its back so the drum which is now only held on to the back plate doesn't stress itself under its own weight. Make sure you know where the wires need to be fed. I took videos and pictures on my phone at each step.
viii) It should now be possible to reach in past the drum and click the grommet back in place.
cheers
Mat
(matskm@gmail.com if anyone wants to ask questions).
Sep 26, 2011 | Hoover VHC391 T-80 Dryer
How to work the hoover vision hd vhv 381 tumble dryer?
This may not be exactly what you want, but is useful information for anyone wanting to work on their hoover dryer, vision hd vhc 381 dryer.
cheers
Mat
Aug 02, 2010 | Hoover Dryers
Hoover Tumble Dryer trips out
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Whenever this fuse goes bad it'll either trip the circuit breaker or the dryer wont heat. You can also check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Hoover HW5 513M Front Load Washer / Dryer
My hoover tumble dryer Hnc175 wont heat up,is still working as normal, just no heat, i have cleaned out the filters and still not working
Heating elements can fail. These are relatively easy and economical to replace. The heating element is not necessarily the culprit if your tumble dryer does not get hot, however. There are thermal overload cutouts fitted to many machines. If they fail, the current will not be passed to the heating element. Replacement is again, fairly straightforward.
Tumble dryers will often have thermostats fitted. A heater control one, and an exhaust thermostat. The first keeps the temperature correct. The second, as its name suggests, monitors the temperature of the exhaust (in case the airflow in the machine is impeded) Once again, replacement is not too much of a problem.
http://www.repairclinic.com/Dryer-Troubleshooting
Please look, at the link above, it will show you how to perform troubleshooting. procedures and repair.
If you feel you don't want to do it yourself, please call a Hoover Tech, and get it looked at. Ask for a "Quote" for the repair, so you get an idea of whats what.
Apr 08, 2010 | Dryers
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Hi, I've got an older Hoover Apollo 411 tumble dryer which has just stopped heating. It still spins but obviously doesn't dry without heat. I presume that it is some sort of element or heating coil that...
A good Start to clear it up is "repair clinic.com" Sounds like a heating element. Repair Guru will let you know if it is a real problem to fix.
Jun 25, 2008 | Hoover Dryers
Hoover OHNV171X Vented Tumble Dryer
It could be the temprature sensor located behind the front cover, it has 2 red wires and is an easy replacable and cheap part.It will need the top removing,front switch cover removing and then the screws for the front cover but not the screws securing the door as this will come off as one. Hope this helps
Apr 26, 2008 | Hoover HDV7FM Electric Dryer
Dryer stuck in sensing mode
Since no help was available without premium assistance, I actually contacted a repairman. He performed all the tests again and told me the problem was the control board. Then wanted $600 to fix. I found the part online for $150 and fixed it myself in about an hour. Instructions were easy.
Sep 08, 2007 | Hoover HDC6 Electric Dryer
Hoover HDC6 Electric Dryer Logo
486 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
