Question about Acer 5560g-6346g75mnkk Aspire 1400 Mhz Amd A6 A6-3400m 4 Mb Amd A
Trying to install bluetooth on my acer aspire 5560G it's not working is it suppose to
Bluetooth. is bluetooth able for use on this model
SOURCE: bluetooth and wlan not working
This may sound like a stupid question but does your notebook computer have a WLAN/Bluetooth switch somewhere. This can be a touchsensitive "button" with some kind of antenna icon on it or a real switch/button.
If it's turned off, turn it on.
I hope this helps. Please rate.
Greetings,
DarkNeogen.
Posted on Jan 28, 2008
Bappa170873
  • 505 Answers
SOURCE: acer aspire 5500z driver bluetooth
First of all check if your Laptop has the bluetooth feature. If it has then the driver should have been automatically installed. There is a button in your laptop, make sure that the bluetooth is on.
Thanks
Posted on Jan 02, 2009
SOURCE: Acer aspire 6920 bluetooth problems
hi,
just try to check with drivers, which is provided with the laptop..
if this not help then take it to service station and ask them about the circuit of bluetooth. if it is available then tell them to put appropirate drivers.
cause in many acer model they give an option of bluetooth but there is no bluetooth. they provide u and slot for that. for ur future options
this might solve ur problem
Posted on Jan 10, 2009
I had this problem too and I called acer and found out that the software is not on the computer. You have to buy the usb bluetooth connector thing. I thought it was stupid of them to put this button on the computer and there is no use for it. Just a thought. If anything, call acer yourself and they will explain it better than I can.
Posted on Apr 13, 2009
fossildude
  • 832 Answers
SOURCE: bluetooth device not detected in aspire 4710G
hi thanks for using fixya!
As I wanted to provide suggestions to you, but on this case, I will suggest if you can bring your laptop to a service center and have it fixed. There are so many reasons why it is not working properly and some errors within. It could help a lot if you will bring it and a service technician will see it personally.
Regards!
Posted on May 08, 2009
Acer Aspire 5560G booting problem
could you please tell me what kind of problems you faced ?
is there any message appear ?
Oct 10, 2015 | Acer Aspire 5560G 15.6 Inch Laptop Amd...
My acer aspire 5553G has no sound
ensure that sound is not muted. if it is not go into device manager and check that the sound and video drivers are properly installed
Jan 31, 2014 | Acer Aspire 5552 5552g 5553 5553g 5560...
My Acer 5552G won't turn on.
try a system reset see below link
http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
Jan 20, 2013 | Acer Aspire 5552 5552g 5553 5553g 5560...
Acer aspire 5552g wont start
see below, if that is no good add more detail please and resubmit
Jan 18, 2013 | Acer Aspire 5552 5552g 5553 5553g 5560...
Acer aspire 5552g format
to reinstall from recovery partition see below link, it it is of no use to you please add more detail and resubmit your query
Dec 05, 2012 | Acer Aspire 5552 5552g 5553 5553g 5560...
I have an acer ms2319 and want to know how to turn bluetooth on
all you need to do is find bluetooth in control panel and activate it. If you have windows 7 just hit the start button and type in bluetooth and go to the network sharing screen
Sep 24, 2012 | Acer Aspire 5552 5552g 5553 5553g 5560...
I hav e an Acer Aspire 5742G model. The Wi-Fi works well, but then I can't get the bluetooth to work. What might be wrong?
Hello there,
The bluetooth of the acer aspire 5742g model does not work on its own. It requires you to connect a bluetooth dongle on to it via the usb port. Then you will be able to use the bluetooth of the laptop.
Try it out and see.
Hope this was helpful to you. Goodluck Elect_Comp
Aug 30, 2011 | Acer Aspire 5742Z-4200 Notebook
How do I get bluetooth to work on my Acer Aspire 5742. Do I need to install a driver or something? Thanks Sam
Probably your laptop dosen't have bluetooth hardware in it.
Confirm it by following process
Right click on My computer and click Manage
then click on device manager on left panel
A list will appear which shows the hardware content of your laptop.
If the list dosen't contain bluetooth device then it is confirmed that your laptop dosent have bluetooth hardware.
Try using external USB bluetooth device for your laptop. Cost couple of dollars.
May 17, 2011 | Acer Aspire 5742Z-4200 Notebook
Boutht new Acer4738 laptop recently. I tried to install Bluetooth driver which came along with driver CD . However, I'm getting No Bluetooth device was detected error. Also, Fn+F3 also not working.
Your computer may not actually have Bluetooth capability. Bluetooth is one of those features that is "on certain models only", according to Acer's site. My daughter's Aspire has a Bluetooth switch on it, and Bluetooth drivers on the CD, but no Bluetooth card is installed. I discovered this when I opened her computer to see why the Bluetooth wasn't working. I've found this to be true for several other models since. This strikes me as misleading and possibly false advertising, but I'm not an attorney.
The only way I have ever found to be sure if the computer has Bluetooth is to open it up and look on the board. Depending on how new "new" is, your computer might still be under warranty so you probably shouldn't bother. Instead, you can try contacting the retailer where you purchased the machine and see if they offer warranty service. Or follow the process given in your manual or on Acer's site for obtaining service. Then if your model does have Bluetooth installed they can fix it, or you'll know for sure it wasn't installed. Then you can buy a USB Bluetooth adapter.
Apr 24, 2011 | Computers & Internet
Bluetooth not working on acer aspire 5738
Hi tallyman,
you lost bet ...when it has a bluetooth switch it will have a hardware installed.
Best solution is got is a simple call to acer service support,the problem very very simple in 5738 machines they installed foxcom bluetooth device a very much updated version.But the drives in your cd will be broadcom drivers install aspire 3810T model bluetooth drivers.
regards
Ar.Praveen(Architect)
ardesarchitects@yahoo.co.in
Oct 01, 2009 | Acer Aspire 5720-6661 Notebook PC
Acer 5560g-6346g75mnkk Aspire 1400 Mhz Amd A6 A6-3400m 4 Mb Amd A Logo
308 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
