Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
I just replaced the motor coupler on my Whirlpool Ultimate Care but it's still making that grinding sound when I set it on a spin cycle (to a lesser degree when agitating). The coupler was defini
A few days ago, my washer started making a loud grinding sound. I checked it out and found that the machine wasn't agitating or spinning. I took it apart and found the busted motor coupler. I ordered a new part (a higher quality one with the metal ring, not all plastic) and installed it. The machine seems to be agitating and such, but it's still making that sound. Also, I ran it through various parts of its cycle more-or-less at random to test it out, and now there's a good deal of water sitting in the bottom. Should that have drained? I've never repaired or troubleshot a washer before, so I'm not sure what I should be seeing.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
You will need to replace the drive block.
Posted on Dec 07, 2012
  • 351 Answers
SOURCE: Whirlpool Washer won't drain or spin
check the lid switch operation,not sure what the noise could be maybe somthing stuck in the pump? hope ths helps unless the contacts in the timer are faulty i have opened up a few timers and fixed the contacts short term.
Posted on Mar 09, 2008
  • 3 Answers
SOURCE: washer won't drain, makes loud noise
This problem, or some variation thereof evidently is very common with these Whirlpool Washers!  I have same problem.  So far, best I have found is at  http://applianceguru.com/forum2/5958.html#
diagnosis by someone who knows.  What William Burk says there makes sense.  However, to get to the drive block there's quite a bit of disassembly required.  I am stopped because I cannot get the spanner nut off.  Hope this gives you some help toward finding a more comprehensive answer
Posted on Jul 05, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool washer Ultimate Care II
The coupler would be an easy assessment to consider. The following link explains how:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
I posted the link that explains how to replace a coupler, because it also explains how to get to it. It is common for these couplers to break over time. Either, the plastic pieces break, or the rubber bushing shears apart. A common sign is to find black filings under the washer. Another common problem with earlier models, is the center hole in the coupler rounds out and begins to slip on the transmission or drive motor shaft. The manufacturer has come out with an improved coupler that has a steel grommet in the center. The part number is provided with the link. I hope this helps you. Let me know if you require further assistance.
NOTE: If it is determined that the coupler is NOT bad, the gearcase (transmission) would be your next logical choice. I can also explain how to replace one of these (if required). It's not a difficult job.
Posted on Dec 12, 2008
  • 113 Answers
SOURCE: Whirlpool Ultimate Care II LSQ8543JQ0 WON'T SPIN
really sounds like a coupler issue. May look fine but if one of the teeth are busted it will do this. You can get a tutorial for fixing this here. http://www.shop.washermd.com/category.sc?categoryId=4
Posted on Jan 08, 2009
aborcass
  • 2651 Answers
SOURCE: WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Posted on Jan 25, 2009
My Whirlpool Ultimate Care II washer goes thru all cycles but will not spin, so clothes are wet. We replaced the motor coupler but will only spin without clothes. Once you put clothes in the tub does
sounds like direct drive gears are bad.. there is a slip coupling that goes over the shaft of the transmission adn assist turning the tub that could be worn or broken. you will have to remove the agitator and check the nut on top of the tub to see if it is tight or to remove the nut and check that coupling.
Dec 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
AGITATOR WILL NOT SPIN, WATER WILL DRAIN BUT NO SPIN
Does your motor sound like it is running in the agitate or spin cycle or is it quite? If the motor makes no sound, then you need to replace the lid switch with this part.
If you hear the motor running in the agitate or spin cycle but you don't see any action, then replace the motor coupler with this part.
Dec 25, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer will wash, rinse and spin but after it spins it makes this really LOUD grinding noise and shakes. What could it be?
Rebuilt transmission or bad coupler, to check coupler remove pump & motor from
transmission see if it is toast.
May 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
The washer agitates but when it gets to the spin cycle it sits there and makes a rapid clicking sound
The motor coupler is broken. Part # 285753A. Go to you tube for explaination of how to replace.
May 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Super Capacity Plus
If it doesnt agitate and makes a grinding sound replace the coupler.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Have to hand start the last spin cycle
sounds like carbon brushes in the motor are not making perfect contact,take out inspect,clean or replace clean up commutator
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Machine wont wash
needs a new motor coupler. small round rubber piece between the motor and transmission. easy to replace
Oct 29, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
76 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
